+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Like Tree1Likes
Thread: Deep RICH Smoooooth Color. Only a few people I have seen master this. Help!
  1. #16
    Join Date
    Dec 2011
    CT
    Posts
    12
    My Gallery
    (0)
    Liked
    1 times
    Heres the result from Photomatix, which I supprisingly like better. http://www.topendproperties.com/12r/...nemapped-2.jpg .. but still dull :\
  2. # ADS
  3. #17
    Join Date
    Nov 2011
    Posts
    680
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    148 times
    Quote Originally Posted by topendprops View Post
    Flag pole looks fine to me :\ (assuming its supposed to be slightly wider at the base)
    Downloading Nik Dfine and HDR now to see if I can mimic the clarity of the examples. If anyone thinks they can make it happen with my photo .. I would love to see it! So far the noise reduction i've used in photoshop reduces detail sharpness considerably.
    Actually my bad the flag pole is fine
    Just remmber no matter which software you use and HDR Efex Pro and Photomatix both look very different. They are not the end of the game and Images should be finished in Photoshop or lightroom.
    Plus you shot late under very flat light which is good for tone...But it still gives you very flat light look
  4. #18
    Join Date
    May 2011
    Posts
    120
    My Gallery
    (19)
    My Photos Are OK to Edit
    Liked
    8 times
    Don't spin your wheels with Photomatix or Nik. For architectural work just like the examples you linked to in your OP, try out Photoengine from Oloneo.com.
    Regards, Murray
  5. #19
    Join Date
    Nov 2011
    Posts
    680
    My Gallery
    (0)
    Liked
    148 times
    One thing that is really making your images look flat online is that you have them in Adobe RGB and that doesn't look good in most Browers. You should convert the images to sRGB and they will look alot better on the internet
    The image looks a lot better in Photoshop, whcih is color managed, then they do online
  6. #20
    Join Date
    Dec 2011
    CT
    Posts
    12
    My Gallery
    (0)
    Liked
    1 times
    Yes I did shoot late in order to avoid nearly all shadows (I'm anti-shadow). I was hoping to bring back the brightness in lightroom/photoshop.
    Also I believe the DigitalCoast images are processed using just Enfuse and Lightroom/Photoshop. I just cant figure this out. Theres just something different. I feel like their images are smooth and sharp at the same time and their color seams rich and perfect every time.
    EchoingWhisper likes this.
  7. #21
    Join Date
    Dec 2011
    CT
    Posts
    12
    My Gallery
    (0)
    Liked
    1 times
    I may be onto something here. Using 2 photos of the same exposure the blending programs can totally eliminate noise. I'm thinking if I take two 9-exposure bursts instead of 1 .. then blend each of the the identical exposures for for noise reduction .. THEN blend the exposures for HDR .. I will have a crystal clear image. Hope to find out tomorrow
  8. #22
    Join Date
    Jan 2011
    Posts
    284
    My Gallery
    (0)
    Liked
    13 times
    The images in the original post appear to have been run thru a Topaz filter. You'll see similar crispness and coloration in the wide angle shots recently posted here by janok.
    An additional trick for smooth color is to adjust the WB of each of the raws before you process them thru your HDR processor. Doing so helps to keep the individual color channels from getting blocked. You'll end up with richer color without having to artificially crank up the saturation.
  9. #23
    Join Date
    May 2011
    Posts
    120
    My Gallery
    (19)
    Liked
    8 times
    There really isn't a need to over-complicate the process. Getting the "even / flat" look like HD Estates photos involves a tone mapper that allows you to brighten the shadows and attenuate the highlights until almost everything in the image is in a mid tone range. The way to eliminate the noise is to set the camera to aperture preferred and lock the ISO to its lowest level so you eliminate the noise in the source exposures. Some HDR s/w does not do well for architectural scenes. For example the output from Photomatix's Detail Enhancer tends to be "fuzzy". Some HDR apps have difficulty eliminating halos. Others enhance contrast of edges of fine and course radii, differently. To produce images like HD Estates, you need a combination of good photography, good HDR s/w, and careful processing. Even with all that, you still need to pay attention to detail. For example, if you look at HD Estates image lg010 (the bathroom), the view thru the 2 main windows is nice. However the window which is reflected in the mirror (the left window) is badly blown out.
  10. #24
    TPF Junkie!
    Join Date
    Aug 2011
    Malaysia
    Posts
    1,503
    My Gallery
    (0)
    Liked
    53 times
    Quote Originally Posted by SlickSalmon View Post
    Which Topaz filter? Adjust or Detail?
    Call me Michael.
    Nikon D5100 | AF-S Nikkor 18-55mm 1:3.5-5.6G DX | AF-S NIKKOR 55-200mm 1:4-5.6G ED DX | AF-S NIKKOR 50mm 1:1.8G
  11. #25
    Join Date
    Jan 2011
    Posts
    284
    My Gallery
    (0)
    Liked
    13 times
    Quote Originally Posted by EchoingWhisper View Post
    I'm not sure. They just have that 'Topazed' look. You might ask janok for his opinion.
  12. #26
    TPF Junkie!
    TPF Supporter
    Join Date
    Feb 2008
    Just outside Toronto Canada
    Posts
    1,999
    My Gallery
    (0)
    Liked
    191 times
    Quote Originally Posted by mistermonday View Post
    That would indicate to me that the two main windows were cut and paste from another image that exposed for the windows otherwise all 3 windows would be have the same look. There are so many ways to come up with a good image, but the trick is coming up with the right combination to give you the best image.
    Sigma 28-300 f3.5 • 28mm f1.8 • 10-20mm f5.6
  13. #27
    Join Date
    Dec 2011
    CT
    Posts
    12
    My Gallery
    (0)
    Liked
    1 times
    Yes the windows are probably a different layer from the lower exposure image. My problem is getting the image clarity and color. I'm wondering if its the lens? :\
  14. #28
    Join Date
    Dec 2011
    CT
    Posts
    12
    My Gallery
    (0)
    Liked
    1 times
    Ok enough of the guess work. Lets put the tires to the pavement. I'de like to see somemone post a similar quality photo
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Replies: 2
    Last Post: 04-19-2010, 01:01 PM
  2. Color C&C from calibrated people
    By cnutco in forum Photography Beginners' Forum
    Last Post: 04-19-2010, 12:07 PM
  3. People in color
    By Stillwater in forum People Photography
    Last Post: 11-13-2008, 02:00 PM
  4. Any Weston Master / Euro Master users here?
    By Lol999 in forum Beyond the Basics
    Last Post: 01-03-2006, 04:05 AM
  5. Are You a Master at Color?
    By SWFLA1 in forum Off Topic Chat
    Last Post: 04-02-2005, 08:36 AM
deep rich colors lightroom
deep rich colours lightroom
examples of hdr photography for real estate
how do i get deep rich colors in my photos
how to create rich deep color in photoshop
how to do a deep rich edit in photoshop
how to do deep tones in photoshop
how to get deep rich color in photoshop
how to get deep rich colors in photoshop
how to get deep rich photos
how to get deep shadows and rich color with photoshop
how to get deep tones photoshop
how to get rich tones in photoshop
photoshop photo editing rich color
rich smooth colors photoshop
Tags for this Thread
