Results 1 to 4 of 4
Thread: Flash help!
  1. #1
    Join Date
    Nov 2011
    United States
    Posts
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Flash help!
    I've never worked with a flash before, and have been having some trouble. I have a Nikon D5000 and am using a Sunpack auto 433D. When I take a photo (just to test the exposure) every single on comes out with a horizontal line down the middle, as if to split the photo in half, where the top half is affected by the flash and the bottom is not. Anybody know what I'm doing wrong/can help me out? Thanks so much!
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Sep 2011
    Kenilworth Warwickshire
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    It could be several things but my guess you have a shutter setting faster than your camera instructions recommend. This means the shutter is to quick to get the entire flash in EI
    one half OK the other no flash. This only happens on a focal plane shutter which you have. Most modern camera's the maximum speed is usually about 125 of a second you could try a lower shutter speed. On saying this most modern focal blade shutters work from top to bottom so what I,ve said would not follow. I do not know your camera so you need to check if your shutter goes from side to side or to to bottom. If your shutter goes top to bottom,and you have one side of your picture flashed and the other non flashed. I would guess you may have a fault in your camera.
  4. #3
    TPF Junkie!
    Join Date
    Oct 2011
    NY
    Posts
    6,763
    My Gallery
    (28)
    My Photos Are OK to Edit
    Liked
    1380 times
    Your shutter speed needs to be below the camera's max sync speed. It's probably 1/200 or 1/250. Otherwise the shutter and the flash aren't firing at the same time... You are getting half of the flash.
    Canon FanGirl Extraordinaire
  5. #4
    KmH
    KmH is online now
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    28,790
    My Gallery
    (1)
    Liked
    2812 times
    One of the shutter curtains is still covering part of the image sensor when the flash fires.
    Your D5000 comes with the default set to sync the flash unit when the front shutter curtain is fully open. In the menus you can have the flash sync with the moment when the rear shutter curtain starts to close. (See page 71 of your D5000 user's manual).
    The flash x-sync speed is the fastest shutter speed at which both shutter curtains are fully open. At faster shutter speeds one or both shutter curtains cover a portion of the image sensor. In other words the 2 shutter curtains form a slit that moves across the image sensor. The faster the shutter speed, the narrower the slit is.
    The lens projects the scene onto the image sensor upside down. So if only the top portion of the photo is obscured by a shutter curtain, it has to be the front curtain and the flash is set to sync with the instant the rear shutter curtains starts to close.
    If only the bottom portion of the photo is obscured by a shutter curtain, it has to be the rear shutter curtain and the flash is synced to fire at the instant the front shutter curtain is fully open. This is what you are seeing in your photos.
    It really helps if you understand how your camera works.
    The D5000 cannot do it, but the more expensive Nikon's and Nikon flash units can do what is known as FP sync mode.
    In FP sync mode the flash unit fires several times during the making of an exposure in time with the slit the 2 shutter curtains make, so the entire image sensor is equally exposed to the strobed light during the exposure.
    FP sync uses up flash unit batteries in a hurry, and the flash unit has to fire each time at much less than full power so it can re-cycle fast enough.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Replies: 9
    Last Post: 10-16-2011, 03:34 PM
  2. Replies: 3
    Last Post: 09-26-2011, 08:47 PM
  3. Replies: 0
    Last Post: 06-26-2011, 07:35 AM
  4. Question about flash diffuser and on-flash bounce card
    By jenn76 in forum Photography Beginners' Forum
    Last Post: 03-23-2009, 11:17 AM
  5. Semi related flash question...fill flash for Canon 10D
    By Alison in forum Beyond the Basics
    Last Post: 08-06-2004, 06:35 AM
