Results 1 to 15 of 17
Thread: Lighting question
08-17-2012, 08:42 PM #1Been spending a lot of time on here!
- Join Date
- Oct 2010
- Location
- Delaware
- Posts
- 228
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 9 times
Lighting question
Have been playing with my strobes over the past week. One thing I am struggling with is that as I try to alter my DOF it requires me to take a ton of test shots to tune the exposure back in. Are there any tricks to make it quicker/smoother? If I set my exposure at say 1/250. F/5.6 and use EC to tune it, will I be able to use my meter to quickly capture the proper exposure moving forward since I have compensated for the strobe lighting?
Nikon D7000/D80/D300 Sigma 18-200 f/3.5-6.5, Nikor 18-200 F3.5-5.6 VR, Sigma 28-105 Nikor 50mm 1.8 Sigma 70-200F2.8, Nikor 10.5 f2.8, Nikor 35 f1.8, Nikor 12-24 f4, SB800, SB600
08-17-2012 08:42 PM # ADS
08-17-2012, 08:58 PM #2Helping photographers learn to fish
- Join Date
- Apr 2009
- Location
- Iowa
- Posts
- 29,022
- My Gallery
- (1)
- Liked
- 2860 times
You can recalculate the exposure on the basis of stops.
If you stopped the lens down 2 stops you need 2 stops more light from your strobes if you want to maintain the same lighting ratio.
I recommend using a decent hand held light meter that can meter strobed light.. . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
For Sale: Stay tuned!
08-18-2012, 02:19 AM #3Been spending a lot of time on here!
- Join Date
- Oct 2008
- Location
- Newcastle Australia
- Posts
- 201
- My Gallery
- (0)
- Liked
- 26 times
I use a light meter but I also change my setting through out my shoot, these are the setting I use, 1/160 F2.8 ISO 50 | 1/160 F 3.5 ISO 100 | 1/160 F 5.6 ISO 200 | 1/160 F8 ISO 400 and so on, I have found using a shutter speed of 1/160 works better fo me that 1/200 as this couses a curtain shadow on some photos as the stobes are not consistent.
Hope this helps
08-18-2012, 07:10 AM #4Been spending a lot of time on here!
- Join Date
- Oct 2010
- Location
- Delaware
- Posts
- 228
- My Gallery
- (0)
- Liked
- 9 times
I guess my question since I dot have a light meter is, can I just use EC to compensate so my exposure meter on camera is reflecting proper exposure?
08-18-2012, 08:08 AM #5Helping photographers learn to fish
- Join Date
- Apr 2009
- Location
- Iowa
- Posts
- 29,022
- My Gallery
- (1)
- Liked
- 2860 times
Your camera light meter cannot meter the strobed light, unless you're using an iTTL flash mode.
What kind of strobes do you have?. . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
08-18-2012, 08:31 AM #6TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1381 times
I am with Keith on recalculating, but the numbers get me sometimes so here's my "stupid" method... I am praying it doesn't confuse you in writing because in action it's so incredibly simple.
I think in terms of clicks. Each click of shutter or aperture is 1/3 of a stop plus or minus light. Every 3 clicks is one stop. If I increase my aperture by 3 clicks I have to increase my light by one stop somehow.
If you are changing aperture AND shutter speed you need to keep a running tab: Increase 3 clicks in aperture and decrease 1 in shutter is taking away 2 clicks of light meaning you need to increase your light equal to 2 clicks. Your camera increases to the right and decreases to the left when changing settings-so do my strobes. If I go 6 to the right in one and 2 to the left in another then I have to go 4 to the right on the strobe or 1 1/3 stops.
So if you start out at your strobe on full power at f/6.3, shutter of 1/50 and you decide to decrease to f/2.8 that is 7 clicks or 2 1/3 stops to the left. You have to make your light equal 7 clicks or 2 1/3 clicks to the left. Depending on your strobe you may only be able to do full stops, but I know mine I can go in between.
If you decrease to f/2.8 but (-7) but increase your shutter to say 1/125 (+4) you then need to decrease your light by -3 clicks or one stop.Canon FanGirl Extraordinaire
08-18-2012, 09:29 AM #7Been spending a lot of time on here!
- Join Date
- Oct 2010
- Location
- Delaware
- Posts
- 228
- My Gallery
- (0)
- Liked
- 9 times
Great info! Where I get a bit confused is identifying exactly what is a full stop on the lights. Assuming I start at full power, if I need to drop one stop on the strobes what setting would I dial down to?
image-213475781.jpgNikon D7000/D80/D300 Sigma 18-200 f/3.5-6.5, Nikor 18-200 F3.5-5.6 VR, Sigma 28-105 Nikor 50mm 1.8 Sigma 70-200F2.8, Nikor 10.5 f2.8, Nikor 35 f1.8, Nikor 12-24 f4, SB800, SB600
08-18-2012, 09:34 AM #8TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1381 times
Each of those measurements is a full stop. The ticks in between are your partials.
If you are at 1/1 or full power and you want to drop one stop you'd go to 1/2Canon FanGirl Extraordinaire
08-18-2012, 09:55 AM #9Been spending a lot of time on here!
- Join Date
- Oct 2010
- Location
- Delaware
- Posts
- 228
- My Gallery
- (0)
- Liked
- 9 times
Thanks. I will continue practicing with them using this method, all great info! Last question, are there any good rules of thumb to make dialog in the proper exposure when first setting up quicker or is it just practice and knowing the numbers over time?
08-18-2012, 10:02 AM #10TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1381 times
The guys may give you a rule of thumb, but for me-no. It all depends on the image I am trying to create how I set up.
08-18-2012, 10:56 AM #11TPF Junkie!
- Join Date
- Sep 2007
- Location
- Hell's Kitchen, New York
- Posts
- 3,201
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 409 times
Some strobes are marked in light output, some in power (actually energy, but we call it power). Sometimes the two vary together, sometimes they don't. Going from 1/1 to 1/2 should give you one stop less of light, but it may not. It's a starting point, but don't trust it. The theoretical stop differences are 1/1 - 1/2 - 1/4 - 1/8 - 1/16 - 1/32 (sorry for stating the obvious). With some strobes as you turn the variator right down, not only does the light output not change in the proportion you would expect, but the output can become variable - ie two successive shots at 1/32 may not be at the exact same light output. This does not happen with strobes that switch capacitors in and out to vary the output, it only happens with some strobes that have variators. Neither of these are huge problems, just something to be aware of.
08-18-2012, 11:31 AM #12Helping photographers learn to fish
- Join Date
- Apr 2009
- Location
- Iowa
- Posts
- 29,022
- My Gallery
- (1)
- Liked
- 2860 times
A 'stop' is 2 times more, or 1/2 as much.
Lens aperture stops are based on the square root of 2 (1.4142) because it's the lens apertures total area that changes, not the lens opening diameter. f/2 lets in 2x more light than f/2.8 does (2 x 1.4142 = 2.8).
Stops of shutter speed, ISO, or light output are times 2 or divide by 2. 1/2 power makes 2x more light than 1/4 power does. 1/1000 lets in 2x more light than 1/2000 does, ISO 1600 is 2x more sensitive to light than ISO 800 is.. . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
08-18-2012, 11:39 AM #13TPF Junkie!
- Join Date
- Sep 2007
- Location
- Posts
- 3,201
- My Gallery
- (0)
- Liked
- 409 times
08-18-2012, 11:41 AM #14TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1381 times
08-18-2012, 11:47 AM #15Chief Free Electron Relocator
- Join Date
- Mar 2011
- Location
- Iowa
- Posts
- 11,660
- My Gallery
- (0)
- Liked
- 2839 times
Go forth and actuate!
Your help is requested in (charitably) tossing me off the 345-foot Financial Center.
TPF's biggest secret.
Similar Threads
Lighting Question
By dgadams2 in forum Photography Beginners' ForumReplies: 3Last Post: 07-13-2011, 07:48 AM -
Lighting question
By 97desmoSP in forum Beyond the BasicsReplies: 3Last Post: 09-16-2010, 01:29 PM -
Lighting question
By 97desmoSP in forum Film Discussion and Q & AReplies: 1Last Post: 09-15-2010, 09:28 PM -
Lighting Question
By UncleRico in forum Photography Beginners' ForumReplies: 6Last Post: 02-14-2009, 10:14 AM -
lighting question
By ryan7783 in forum Beyond the BasicsReplies: 6Last Post: 07-26-2008, 04:15 PM
d7000 and sigma 18-200 pictures problems
LinkBack URL
About LinkBacks
