Results 1 to 15 of 26
Thread: Basic Bright White Light Needed
09-19-2012, 05:27 PM #1
I mainly take macro photos outside and the sunlight is just too inconvenient. The season is changing and the sun is become more unreliable. I need help in finding a good lighting source, for beginners, that provides bright white light. I've looked into strobe lights but I don't know if they are any good for what I need to get done.
Here are some examples of photos I usually take:
http://www.touchtip.com/wp-content/u...s2-542x406.jpg
http://www.touchtip.com/wp-content/u...ps-542x406.jpg
http://www.touchtip.com/wp-content/u...up-542x406.jpg
I want something that will give me consistent level of brightness in my photos. I'm using a basic point and shoot which is all I need for now.Last edited by unidh4x0r; 09-19-2012 at 05:40 PM.
09-19-2012 05:27 PM # ADS
09-19-2012, 05:37 PM #2I spend too much of my life on TPF!
- Join Date
- Apr 2011
- Location
- Pittsburgh, Pa.
- Posts
- 438
- My Gallery
- (2)
- My Photos Are OK to Edit
- Liked
- 58 times
I thought all lightning provided bright white light.
09-19-2012, 05:39 PM #3
Some lighting tends to give off that yellowish light. You've never seen that?
09-19-2012, 05:45 PM #4TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1380 times
Does your point and shoot have a way to trigger and expose properly for external lights?
Constant lighting would require very long shutter speeds in order to get enough light.
A 100W bulb is giving off 100 watts of light over one full second. If you are shooting at a fast shutter speed you are only shooting at maybe 1/500th of a second. You would only be getting .2W of light. In order to actually get 100W of light you would have to have 500 each 100W constant bulbs.
SO... to answer your question about strobes or speedlights/speedlites: Yes, they're the best option as far as bright white light goes.
If you are using a tripod, trigger and always inanimate objects a constant light source would work.
Light that gives off a color is fine-as long as it is all the same color light. You can then use a custom white balance which would fix that problem. All light has a color temperature to it. The yellow is just one you happen to notice often because it's the color of household lights and it's a PITA.Canon FanGirl Extraordinaire
09-19-2012, 05:48 PM #5
09-19-2012, 06:04 PM #6TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1380 times
What camera are you using? Need to know in order to get what you'll need.
Speedlites are the cheapest and easiest solution. The YN series by Yongnuo are incredibly inexpensive. I'd want to have a light tent for what you are doing too. Those are cheap too. WHat's your budget?Canon FanGirl Extraordinaire
09-19-2012, 06:10 PM #7
09-19-2012, 06:12 PM #8
Also, I rather have a lighting source that connects to an outlet. I don't think the point and shoot can use the speedlites.
09-19-2012, 06:16 PM #9TPF Junkie!
- Join Date
- Apr 2011
- Location
- Tampa
- Posts
- 6,792
- My Gallery
- (0)
- Liked
- 979 times
lowes.com
look at the LED or "day-lighter" fluorescent lightsD800 |Nikon 24-70 | Nikon 70-200 VRII | 50mm f/1.4 | Manfrotto | pocketwizards | flashes
09-19-2012, 06:22 PM #10TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1380 times
09-19-2012, 06:39 PM #11TPF Junkie!
- Join Date
- Apr 2011
- Location
- Tampa
- Posts
- 6,792
- My Gallery
- (0)
- Liked
- 979 times
09-19-2012, 06:41 PM #12
Thinking of getting this:
Amazon.com: Feit Electric ESL40TN/D 42-Watt Compact Fluorescent High-Wattage Bulb, Daylight: Home Improvement
One issue I'm concerned with is the lamp I plan to use it with. It has a maximum limit of 60 Watt type A bulb. The product specs of the bulb says it's equivalent to a 200W incandescent light bulb.. I can't use the lamp right? Also, thanks so far
//Also, already have a tripod. Don't understand why I would need it. Sorry guys, I'm new to this stuff.
09-19-2012, 06:47 PM #13TPF Junkie!
- Join Date
- Oct 2011
- Location
- NY
- Posts
- 6,763
- My Gallery
- (28)
- Liked
- 1380 times
We'll say that bulb is the equivalent of 200Watts. If you use a shutter speed of 1/125 (slowest I'd recommend for hand held) you would only be getting 1.6 watts of light per bulb in your camera. That's like a christmas light. You would need to have 125 of those bulbs in order to get a 200 watt light.
In order to get exposure with one, two or 10 of those in a normal setting you're going to need a very slow shutter speed to get exposure. If your shutter stays open for a long time you can shake it, move, etc. If it is on a tripod it's perfectly still. You will also need a way to either time it so that the shutter goes off a second AFTER you push the button or you will need a remote of some sort for it.
Try taking a shot in your brightest lit room in your house. Light it up like you own the electric company. Turn your flash off and take a shot. See if the image is blurry. That's what you will get without a remote and tripod when using constant lights.Canon FanGirl Extraordinaire
09-19-2012, 06:55 PM #14
09-19-2012, 07:00 PM #15TPF Junkie!
- Join Date
- Sep 2007
- Location
- Hell's Kitchen, New York
- Posts
- 3,182
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 403 times
It is usually OK to use a 42 W CFL in a fixture rated for a 60 W incandescent. The 200 W equivalent figure is for light output, not for heat output or electrical power input.
You may, however, have problems with brightness and colour temperature if you use this outside in daylight. It is very likely that the colour of the light ("Correlated Colour Temperature" or CCT) does not match daylight exactly. It may be quite dim compared to daylight. To give some perspective, we use 12.5 kW and 25 kW lights to match daylight - you will not need that much, but 200 W would be a struggle.Last edited by Helen B; 09-19-2012 at 07:13 PM.
Similar Threads
Need advice on bright white backgrounds
By jrizal in forum Photography Beginners' ForumReplies: 2Last Post: 05-31-2012, 09:18 PM -
How to get the white background bright
By brothersanju in forum Photography Beginners' ForumReplies: 61Last Post: 02-05-2012, 08:44 AM -
Basic DSLR needed
By YorkPhotoWorkshops in forum CanonReplies: 3Last Post: 11-17-2011, 11:23 AM -
how can I avoid over exposure of a white car in bright sun?
By NM Rich in forum Photography Beginners' ForumReplies: 12Last Post: 02-26-2009, 09:57 PM
LinkBack URL
About LinkBacks
