+ Reply to Thread
Results 1 to 4 of 4
Thread: TLR film help
  1. #1
    Join Date
    Feb 2006
    Beaumont, TX
    Posts
    23
    My Gallery
    (0)
    Liked
    0 times
    TLR film help
    I have a Seagull TLR and I'm having trouble with the film. The exposure counter has never worked so I just shoot film until I can tell it's out. First I ran a roll through just to see if it was working properly. The film came back with exposures on every other spot. So i got 6 pictures on a 120 roll instead of 12.
    I fixed that by cranking it halfway and then rewinding it with the multiple exposure button. After I ran another roll through I found out that the film didn't start when I started taking pictures and that I didn't take exactly 12 pictures (I wasn't really counting, though I should have).
    I'm loading the film up till where it has those arrows on the film by the way. I like the camera because it's sharp so I'm trying to find a way to save this. I just can't use it for anything practical because I never know when the first picture is taken.
    Is there a way to fix this?
  2. # ADS
  3. #2
    Join Date
    Nov 2007
    Woodside, NY
    Posts
    49
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    I dont know if this will help at all, but i figured I might as well chime in.
    I've had a similar thing happen while shooting with my Bronica, which is a 120 SLR, unlike yours which is a TLR.
    I took it to a local photoshop and the man there was explaining to me what was happening with my exposures, why one was exposed and the next one was not. Turns out it had something to do with the registration pins on the backside of the lens that was not engaging when I clicked my exposure. It would only register every other time.
    Turns out it was not very much to get it repaired.
    Your TLR and my SLR Bronica are different in how they shoot images so I'm not sure if this applies to your camera. Maybe this will help thou.
    Also thou, once you load your film into the arrow mark, remember that it still will take a few rotations of the crank to make it to the first exposure.
  4. #3
    Join Date
    Dec 2006
    Thunder Bay, ON, Canada
    Posts
    266
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    What model seagull do you have?
    Hi, my name is Bob and I'm chemically dependant. Metol, Hydroquinone, Thiosulfate, whatever I can get really.
  5. #4
    Join Date
    Nov 2010
    Crossville, Tn
    Posts
    14
    My Gallery
    (0)
    Liked
    1 times
    If it's like my Rolleiflex, you have to slide the film under the first roller or I don't believe it will register. Do you have an instruction manual?
    DaveO
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Modifying Current Film to Fit 130 Film Size Camera
    By Fragomeni in forum Collector's Corner
    Last Post: 10-02-2010, 10:46 AM
  2. Replies: 1
    Last Post: 04-15-2006, 11:20 AM
  3. Classic Camera Film Sizes, Sources, and Film Adapters
    By Mitica100 in forum Collector's Corner
    Last Post: 02-04-2005, 06:23 PM
  4. Emergency!! Difference between print film and negative film?
    By japmula in forum Beyond the Basics
    Last Post: 08-08-2004, 05:33 PM
  5. Film, Film, Film! (35-mm, color print)
    By 5th in forum Photography Equipment & Products
    Last Post: 12-28-2003, 05:06 AM
photo of film help
taking pictures with a tlr
tlr film
tlr film size
