+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 23
  1. #1
    Join Date
    Sep 2011
    Cape Cod
    Posts
    5
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Mamiya RB67 Film Winding Issue
    I recently got an RB67 ProS and I love the prospect of using it in portraiture along side my digital cameras.
    So, after setting it up, I shot a polaroid using the polaroid back and got a real nice polaroid. Then I (I think I did it properly) loaded the film back w/120 film. I cocked the shutter and exposed the first frame (I thought). Once I did that, I re-cocked the shutter for the next exposure, and tried to wind the film to the next frame, but the film would not wind. I looked everywhere but could not see what was causing it. I loaded another back w/film and tried again. The same thing occurred. Am I missing a locking mechanism or something? I have pulled the light-blocking slide every time I am about to shoot, so I know it's not that. Any help would be appreciated. This is starting to get frustrating. I hope it's just something I forgot to do.
    Jorge
  2. # ADS
  3. #2
    Join Date
    Mar 2010
    Noosa, Australia
    Posts
    98
    My Gallery
    (0)
    Liked
    6 times
    The Mamiya RB 67 Pro S has many subtle interlocks preventing double exposures or blank exposures. Downloading a manual is the way to go. In the meantime check this:
    Do you have a Pro back or a ProSD back instead of a Pro S back?
    Is the mirror-up function engaged?
    Is the revolving adapter turned to the click stop position?
    Did you re-cock the shutter after the first exposure but without advancing the film?
    Is the double exposure function engaged?
    Is the shutter release button on the camera body locked?
    Is the slide lock on the revolving adapter not fully home?
    Is the camera fitted with a R-lock or G-lock revolving adapter?
    Those are the things I would check first but that's only the start. Having the manual is good!
  4. #3
    Join Date
    Sep 2011
    Cape Cod
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    RB67 Film not Winding issue
    Thanks so much for the response. Let me see if I can follow the items and check them on the response.
    Do you have a Pro back or a ProSD back instead of a Pro S back? R: the film backs I have (3 of them) are Pro S
    Is the mirror-up function engaged? R: No it's not.
    Is the revolving adapter turned to the click stop position? R: look and feels secured. I would say YES.
    Did you re-cock the shutter after the first exposure but without advancing the film? R: I think I did so. Later I read in the manual (I understood it) that it didn't matter the order. Perhaps it does?
    Is the double exposure function engaged? R:I don't think so, I also played with that but to no avail.
    Is the shutter release button on the camera body locked? R: NO
    Is the slide lock on the revolving adapter not fully home? R: I don't think so.
    Is the camera fitted with a R-lock or G-lock revolving adapter? R: I have no clue. How do I verify that?
    I have reviewed the manual somewhat. BTW - It's online at the Mamiya website in the support page - as a PDF file download. I figured that it is sometimes easier and quicker and many times better to ask folks with the experience directly. But I will review the manual again though.
    It would be such a shame to have to take this thing to service when there could be a solution right in front of me on the camera itself. Just the polaroids that I took already tell me that the potential for some great pics is there. Totally!
    Jorge
  5. #4
    Join Date
    Sep 2011
    Cape Cod
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    On thing noticeable, maybe irrelevant is that I can continue to cock and trigger the shutter. When I go to wind the film, it just doesn't move.
    When I loaded the film I took very good care to follow the loading instructions. And moved it up to the first exposure and everything. I also loaded a second film back to see if perhaps was the back itself. But so far 2 out of 3 don't work? Gees!
    The question really can prevent the film from winding?? Is there a feature that does that or is something broken?
  6. #5
    Join Date
    Sep 2011
    Cape Cod
    Posts
    5
    My Gallery
    (0)
    Liked
    0 times
    OK - I fixed it! And this may help someone else out there.
    So I analyzed the operation of the winding and shutter mechanisms on the camera a little bit more and figured out by reading the manual too, that there is a pin, that, when the shutter is pressed, pushes an unlock mechanism on the film back corner (same as the multiexposure mechanism). If that pin is a millimeter off, it may not travel far enough to push into the film back properly thus the film won't want to wind when you crank the lever. So in my case, with a small (watch repair size) alligator-nose pliers and a tiny bit of straightening (it was bent ever so slightly) of the wire that actuates the pushrod.. That did it! Nevertheless, I will monitor how it works now to see if it may need any additional tweaking. I also do want to make sure that my other film backs will still work. I am sure that will be the case. Either way I feel triumphant on this one... :-)
    Jorge
  7. #6
    Join Date
    Oct 2003
    NYC
    Posts
    474
    My Gallery
    (0)
    Liked
    1 times
    Good find.
    Very common problem. Those pins seem to always get bent or full of dirt because when changing lenses or working on their cameras, many people lay the camera on those pins. Also, not clicking the rev back in properly will prevent normal operation.
    Anyone can make a digital print, but only a photographer can make a photograph.
    paul ron automax1@juno.com
  8. #7
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,308
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    802 times
    Thanks for posting the solution to your problem. I've got an RB67 and I haven't had a chance to try it out yet. I've read the manual but the whole procedure of shooting this thing is still a bit of a mystery for me.
    What lenses do you have?
    The camera makes everyone a tourist in other people's reality, and eventually in one's own. - Susan Sontag
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  9. #8
    Join Date
    Oct 2003
    NYC
    Posts
    474
    My Gallery
    (0)
    Liked
    1 times
    Awe come one now, it's not all that complicated.
    Load film in the back as per manual instructions.
    Cock the film back till it stops at the first frame.
    Now the complicated part...
    Set the shutter speed n F stop on the lens.
    Cock the camera body lever which arms the lens shutter.
    Look in the WLF, set up your shot, focus diligently...
    Carefully n with a steady hand, press the fire button on the front of the camera.
    **Don't move yet because you heard the mirror go up, wait a second more so the shutter has a chance to finish firing.
    Now advance the film frame n cock the body once more for your next shot.
    Congratulations, you can do it!
    Once you get the hang of it, you'll never go back to another camera ever agin... you'll miss all the attension this one gets you on the street!
  10. #9
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,308
    My Gallery
    (111)
    Liked
    802 times
    Don't you have to do something with the dark slide?
  11. #10
    Join Date
    May 2011
    Austin, TX
    Posts
    142
    My Gallery
    (0)
    Liked
    12 times
    Hahaha, you are correct mike. The camera wouldn't have fired if you had followed PaulRon's instructions to the t. I am actually purchasing one of these beasts today after work. I'm so excited to get back to film, especially with such glorious viewing space on that giant ground glass screen. I just really need my store to get more of the optech straps in so I can actually carry the tank around. I misloaded one roll on this camera already before downloading a manual, and now I have spent a whole lot of time reading and rereading the manual, so I'm ready for it finally. One of my backs has a stuck counter issue, and I have already downloaded the service manual for it and will be fixing that myself. This thing is going to be so much funn!
    "In the meantime, I just take a little more courage and a little more perseverance and quite frankly, take as many drugs as I can." Excerpt from Joao Silva's speech at the Bronx Documentary Center after losing both legs to a landmine in Afghanistan.
    Nikon D300s
    Nikkor 35/1.8 DX (For Sale)
    Nikkor 50/1.8 DX
    Nikkor 10.5/2.8 Fisheye DX
    Nikkor 18-105/3.5 DX (For Sale)
    Holga 120N (For Sale)
    Polaroid One-Button
    Borrowed Mamiya 7 w/ 80mm
  12. #11
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,308
    My Gallery
    (111)
    Liked
    802 times
    No kidding. I don't think I'll be carrying mine around. I bought it with a bunch of studio gear including a very large, very heavy Manfrotto tripod & head. When I do shoot with this thing, I'll be using the big tripod.
    I just really wish I had a wide angle lens for it. I think 50mm is the typical wide angle for this format. The only lens I have is the 100-200mm zoom.
  13. #12
    Join Date
    Oct 2003
    NYC
    Posts
    474
    My Gallery
    (0)
    Liked
    1 times
    AH HA so you do know how to use teh camera. I was testing you with th edark slide to see if you caught it. Only a guy that has faught with the camera would know what to look for if you followed my instructions to the T and it still didn't work.
    Congratulations you are now a graduate, here is your diploma...
    Now lets see some pics frum duh belly o da beast?
  14. #13
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,308
    My Gallery
    (111)
    Liked
    802 times
    Well, I've read the manual (or a manual for a similar model), but I haven't run any film through it yet.
  15. #14
    TPF Junkie!
    Join Date
    Oct 2007
    Greenville, Texas
    Posts
    11,791
    My Gallery
    (4)
    Liked
    579 times
    Quote Originally Posted by Big Mike View Post
    You'll be a film junkie soon enough.
    I can see it now - For Sale: Brand new Canon 5DmkII. Comes with manual, cords, CD, battery, and charger.
    -Josh
    Flickr
  16. #15
    Join Date
    May 2011
    Austin, TX
    Posts
    142
    My Gallery
    (0)
    Liked
    12 times
    haha. There might be a d300s right above that too.
    Nikon D300s
    Nikkor 50/1.8 DX
    Polaroid One-Button
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. FT: Mamiya RB67
    By John16 in forum Buy and Sell
    Last Post: 07-21-2010, 05:28 PM
  2. Just got a Mamiya RB67
    By Buckster in forum Collector's Corner
    Last Post: 12-21-2009, 08:13 AM
  3. MAMIYA RB67 kit
    By samuelpeter in forum Buy and Sell
    Last Post: 05-19-2006, 10:34 PM
  4. Mamiya RB67 Pro SD
    By crotograph in forum Photography Equipment & Products
    Last Post: 11-27-2005, 10:20 AM
  5. Hasselblad winding issue?
    By DIRT in forum Beyond the Basics
    Last Post: 05-09-2005, 06:46 PM
austin tx mamiya rb67
can i advance film twice on mamiya rb67 back
crankshaft on rz67
lens jambed on rb67
mamiya rb67 pro s film back issues
mamiya rb67 prosd not advancing film correctly
mamiya rb67 switch near film winder
mamiya rz67 mirror wont release
mamiya rz67 wont wind
rb67 back not advancing
rb67 film advance
rb67 film back
rb67 film back manual
rb67 pro s film back lever
rb67 wont advance
Tags for this Thread
