+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Join Date
    Dec 2008
    Posts
    4
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Macro lens recommendation
    Hello all,
    This is my first post with this community and I am sure it won't be my last. I am attempting to locate a decent macro lens for my wife to utilize with her newly acquired Canon EOS 50d DSLR Camera. Right now, it has the lens listed in my profile, the EF-S 18-200mm f/3.5-5.6 IS Standard Zoom Lens, and she is looking for a good lens to use for up-close nature photography similar to the photos in this thread.
    Does anyone have a good recommendation for a Macro lens she can utilize for this purpose which will provide decent photos? She loves taking pictures of wildlife (insects) and flowers and as such, a good blurring capability for the background is preferrable. Anyways, Let me know if anything else is needed as far as other requirements or information.
    Thanks!
  2. # ADS
  3. #2
    tpe
    tpe is offline
    Join Date
    Nov 2005
    Copenhagen Denmark
    Posts
    941
    My Gallery
    (0)
    Liked
    5 times
    The lens used in that thread is a great lens and for insects it is usefull to go up to its maximum magnification of 5x lifesize. It is a bit costly though. Personally I would go for a 70 or 100mm dedicated macro prime and some cheap extention tubes. The Sigma 105 (or the new 70mm) and the tamron 90 both provide excelent sharpness at a mid price point. If you want to a little higher in price then the canon 100mm or cheaper would be the vivitar or cosina (plastic fantastic) 100mm. My choice was the sigma, my second would be the tamron then the canon and the cosina last. After them i would take a 50mm macro. Get a cheap extention tube or tube set too, then you can get about 3x with a 100mm lens. Stear very wide of any zoom that claims to be a macro because generally they are not and the image quality is way off even the cheapest of the lenses above.
    tim
    OTE CnC welcome, in fact if you are having a bad day take it out on my pic please. Otherwise just have a good one
    http://www.scientificillustration.net
  4. #3
    Keeper of the Padlocks Site Moderator
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    13,907
    My Gallery
    (0)
    Liked
    674 times
    I agree with tpe - avoid the MEP 65mm macro for now - its a fantastic macro lens but its one of the hardest lenses to learn how to use (distance from lens to subject can be only about 4cm when at max magnification!). Its also a macro only lens - it will not focus on anything but macro subjects, which can be a bit limited when out in the field - it also needs proper flash lighting to work well - idealy the twin positional macro flash head since it has a lights on feature which activates the flash for a period of time - this is important as the lens can be very dark to see through so the added light is important - together both items make for an expensive package
    As for "normal" macro lenses there is a great selection of choice:
    Canon EFS 60mm macro - the only downside to this lens is that its EFS which means it will fit crop sensor cameras only, a full frame camera (like a 5D) will not work with this lens - this is only a limitation if you are thinking of moving to full frame cameras and want to keep your lenses -the 50D will work well with this lens. Its build and sharpness are great.
    Canon 100mm macro - this lens is another strong choice, a good focal length and great optics make it a sharp lens for macro work. It's a popular choice for many; its only downside is that lens hood and tripod collar are not included in the price or package - they have to be got extra as additions. A lens hood is essential and really should not be left off so its a must addition, the tripod collar is only important if your going to mount the lens on a tripod, for this use the collar is very important as it really helps with weight distribution. The camera mount can suffice, but its going to put a lot of load on the front of the tripod which might cause dipping (only visable at macro level) and be a pain for framing a shot
    Tamron 90mm macro - a good budget macro lens - again sharp and well built. It does not have innner focusing so the lens will extend as it focuses
    Sigma 70mm macro - reportedly their sharpest lens, this is another strong choice and a good one for budget purchasers. Note that this lens is not listed as compatable with sigma teleconverters, but I have read that users of this lens have found that it will fit a sigma 1.4 teleconverter. It does not have innner focusing so the lens will extend as it focuses
    Sigma 105mm macro - very much like the canon in use and optical quality. It does not have innner focusing so the lens will extend as it focuses
    Sigma 150mm macro - this lens, and the sigma 180mm macro are a class above the other 2 sigma options; HSM focusing motors, inner focusing (lens remains the same length no matter how you focus - movements happen internally) and also compatability with sigmas line of teleconverters - both the 1.4 and 2*. It also includes both hood and collar in the set - and its price is similar to the canon 100mm if bought with both hood and collar. This lens is also the longest (focal length) lens that can be used handheld without trouble. Again this is a well built and sharp macro lens
    Sigma 180mm macro - as above this is the top line macro lens from sigma, its offers a long focal length and also is able to give the same optical quality as the Canon 180mm macro, whilst being a lot cheaper. The only downside is that users of this lens tend to regard it as being a bit too heavy for prolonged handheld use for macro work - for tripod work though its one of the best choices.
    Notes: Focal length - the longer the focal length of a macro lens the longer the working distance - distance from camera to subject. When working with insects you idealy want the longest length you can get so as to put as much distance from you and your subject; this lessens the chances of spooking the insect. Generally lenses greater than 90mm are recomended for newer macro insect photographers.
    Also note that the longer the focal length the greater the degree of background blur in a shot - often a desirable feature in macro work.
    Auto Focusing - macro lenses on the whole are poor auto focusers because macro work is done almost totally in manual focusing - the canon 100mm, sigma 150mm and 180mm with their better motors tend to be the better when using their auto focusing - however all are prone to hunting at times.
    Inner focusing - note that macro work tends to be done with the lens at a fixed focus point and the camera and lens are then moved to achive focus on the subject, so whilst lenses that focus normally (ie they extend/contract as focused) will be longer at the maximum magnification it will be a fixed distance (mostly, sometimes adjustments are needed to get the desired framing of the subject).
    Note that I have left out the 50mm options as they tend to be poorer lenses, often aimed at the budget level and thus tend to be of lesser quality. Also note that some 50mm lenses require filteres to be added before they are able to work as proper macro lenses - instead they offer a lesser magnicication than standard without the filters.
    Teleconverters - note that adding a teleconverter will not only increase focal length (and thus working distance) but also will increase magnification of a shot and will also reduce your plain of focus. A 1.4 Teleconverter is a good investment as it will let you get that little bit closer to smaller bugs without compramising image quality nor making macro work much harder. A 2*TC is much harder to use well as the plain of focus is very very thin (which makes it very hard to focus the lens) and also will compramise image quality noticably. Some 3rd party teleconverters will work with lenses like the canon 100mm, but I do not know which makes and models do
    In the end its very hard to make a bad choice and any of the above will work very well at macro work - the biggest factors tend to be focal length and price .
    How to get critique and feedback on your photography!
    The Mentor Scheme mentoring on TPF all are welcome to read and apply
    Best photos on the net!
    well at least I like to think so - sometimes
  5. #4
    Join Date
    Apr 2008
    land of the long white clown
    Posts
    77
    My Gallery
    (0)
    Liked
    2 times
    Great info there
    For a first macro I would go for one the three around 90-100mm, that is the Tamron 90mm, Sigma 105, or the Canon 100mm. All three have about the same IQ so the difference between them are only a few small features, price, and of course brand.
    As a bonus they also make great portrait lenses.
    I would also recommend a decent flash, the basic 430ex would do nicely as you are often working with small apertures and need the extra light.
  6. #5
    Join Date
    Dec 2008
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    I appreciate all of the input I have received. It appears that my looking into Sigma will be my next project for my wife. She is a huge nature photographer (It's her passion) and as such I feel a macro lens is a worthwhile investment.
    Overall, if you were to choose, which two or three would you put your choice in for comparison? What is an IDEAL focal length for a lens doing macro photography?
    One thing I am running into is that some macro lens have what is referred to as an "aspherical" lens. Is this a good choice? They are quite a bit cheaper so it makes me wonder about quality. What is the primary difference between an ASP lens and say an HSM lens?
    Thanks for the input!
  7. #6
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    13,907
    My Gallery
    (0)
    Liked
    674 times
    HSM is Hypersonic Motor - its basically means that the auto focusing motors in the lenes are faster (generally) much quieter and generally far better than normal lens motors.
    The glass part I have no idea, but I assume it to be a coating or glass type.
    The tricky part is that lens names get hacked up by different websites, so the full details are sometimes not presented in a title - also names of glass coatings are very showy but not at all informative to those far newer to the game.
    Basically image quality wise - the lenses on offer have very little difference in quality and in the field the difference is even harder to tell apart.
    As for which is the best - there ain't one . Generally a longer focal length helps with insects - as for tripod or handheld that is a personal preference. Overall I would look at the 90mm options or greater - myself I considered the 2 sigmas and the canon - 150mm and 180mm and the canon 100mm. However the best person to choose is really your wife = choosing lenses is a bit like shoes -- one size does not fit all
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Macro lens recommendation?
    By Breanna in forum Photography Beginners' Forum & Photo Gallery
    Last Post: 02-04-2009, 09:13 AM
  2. Recommendation for a Macro Lens for Canon Rebel XT
    By rip555 in forum Photography Beginners' Forum & Photo Gallery
    Last Post: 04-24-2008, 04:37 PM
  3. Macro Lens Recommendation
    By dEARlEADER in forum Photography Beginners' Forum & Photo Gallery
    Last Post: 04-22-2008, 10:02 AM
  4. lens recommendation
    By brighteyesphotos in forum Photography Equipment & Products
    Last Post: 05-12-2007, 08:36 PM
  5. Recommendation for wide angle and macro lens for the Rebel Xti?
    By Turando in forum Photography Equipment & Products
    Last Post: 02-14-2007, 05:05 PM
canon 50d lens recommendation
canon 50d macro lense recommendation
canon 50d macro lenses
canon lens recommendations for beginners
canon macro 100mm too much blur
canon macro lens for outdoors recommendation
canon macro lens recomentation
canon macro lens recommendation
canon macro lens recommendations
canon macro lenses recommendation
canon micro lens recommendation
canon recommendation for macro lenses
canon wildlife lens recommendations
comparison of canon 100mm and180mm macro lens
cosina 100mm
lense recomendation macro insect
macro canon lens recommendation
recommendation all purpose canon lens
recommendation for macro lens for canon
recommendation macro lens for canon hf s21
