Chief Free Electron Relocator
Originally Posted by
Patrice
Tony S
How close are you to your subject? The closer you are the worse this will be. Figure out with some test shooting how far away your subject has to be for the flash to shoot over the lens. Then at least you will have an idea of when you can use the pop up flash without the shadow.
This is a tad misleading.
For example if the lens casts a shadow in the bottom third of the frame because the pop-up is too close to the lens axis, then that shadow will be present in the bottom third of every frame, regardless of what is in the frame.
If you get a shadow in an image of a wall caused by the lens shadowing the pop-up flash, that shadow is not going to go away by stepping further away from the wall.
Yes it will. If the wall is .01 inches in front of the lens, the shadow will cover 99.99999999% of the frame, if not 100%. If the wall is 100 miles away (by now it's a theoretical wall), the flash (although incredibly dim by then) will cover it. It's called parallax.
My toys: Nikon D60 & gripped D7000: Nikkor 10.5 fisheye, 10-24, 18-105, 70-300, 105 Micro: Tokina 500: Sigma 600: Celestron 2000: auto macro tube set: SB600: Manfrotto 055XB/390RC2 & 560B-1: Gossen Starlite: Easy-Up AP1500: 40' WonderPole
12-08-2011 06:53 PM
# ADS
The only time I use my popup flash on my D200 is to trigger my SB-700 off camera. Other than that..........it's useless.
Fyi you dont need to spend $300+ on a new nikon speedlight. There are cheaper alternatives, like an older manual flash or a third party flash.
Also your popup flash should work fine at 50mm or longer.
Pop up flash doesn't work at either at 10mm or at 200mm for me. DOH!
James
"Photography is the art of exclusion"
Nikon D80, D7000, D800.
Nikkor AF-S 24-70mm f2.8, AF-S 70-200mm VR2 f/2.8, AF 35-70mm f/2.8D, AF 50mm f/1.8D, AF-S 18-105mm f/3.5-5.6, Tamron 10-24mm f/3.5-5.6.
SB 800's, SB 600's, YN560's, Sekonic L358, Pocket Wizard PlusIII's, Color Checker Passport, colored gels, softboxes, shoot through umbrellas, reflective umbrellas
All I need now is a great imagination.
haha what a good bit of info thanks for the thread, would have never thought of that. it being the lens and all... pop up flash sounds pretty lame, why do these cameras even have them?
Audible_Chocolate
Because they trigger OCFs via Nikons CLS.
Neither of my cameras have pop-up flashes.
Facebook
http://tylerdrummphoto.com/ (COMING SOON)
Girl, I like that you don't have AIDS, and that you covered the rent when I don't get paid. The dinner that you simmer-sauté'd made it so I haven't been to Taco Bell in like DAYS.
The less expensive consumer grade camera bodies have them because quite a few people find them acceptable.The pro bodies exclude them for obvious reasons.
i never had a problem with no lens hood and the kit lens, then drop a big lens on the camera yeah, it happens, its just not high enough.
Derrel
(read the fine manual)
Really!
The other day I was testing the pop up flash on my D70S coupled with a 18-70mm lens & shade for close up floral work, where I really didn't want a powerful flash, nor any higher angle then necessary. Using the 70mm focal length caused caused the shade to intrude in the flash pattern. When I removed the lens shade, the issue was resolved.
Joel
Your eye/brain is the difference between
a photograph and a picture, not the camera.
My Flickr: http://www.flickr.com/photos/72485364@N08/
