Results 1 to 12 of 12
  1. #1
    Join Date
    Apr 2012
    Los Angeles, CA
    Posts
    572
    My Gallery
    (1)
    My Photos Are OK to Edit
    Liked
    30 times
    Macro extension tubes or diopters? Need advice
    I have a D3100 with the 18-55mm lens kit and a 55-200mm zoom. I am torn between whether to use extension tubes or diopters for my macro shots. (Obviously, I do not have the budget for a dedicated macro lens. I still have to buy a prime lens for other purposes too.) My main concern is that I've read that lenses must have an aperture ring when used with a macro tube. Since there will be no contact for my AF-S kit lens to the camera itself, AF will be disabled needless to say. I've read further that the aperture due to this is set back to f22 resulting to dark photos unless lighting is considered. Is there any practical workaround (meaning affordable or simply cheap) on this? Macro lighting of course is an option. Or am I simply better off using a set of diopters? Your opinions will be greatly appreciated.
    PS Since these are not exactly lenses but somewhat related, the moderators may freely move this to accessories or photography equipment if necessary.
  2. #2
    Watch the Birdy! Site Moderator
    TPF Supporter
    Join Date
    Jul 2005
    Southern Vancouver Island, BC
    Posts
    22,924
    My Gallery
    (26)
    Liked
    4840 times
    Thanks for the permission to move the thread!
    I assume by "diopters" you refer to the screw-on close-up "filters" that mount to the lens just a regular filter? If so, you'll be MILES ahead with the extension tubes. As there are no optices in them, there's nothing to degrade your image, and while the filters will give you a sharp-ish centre, the periphery is often horrible.
  3. #3
    Join Date
    Apr 2012
    Los Angeles, CA
    Posts
    572
    My Gallery
    (1)
    Liked
    30 times
    Yes, I have read about those. IQ is somewhat degraded using diopters even with the high quality ones. But my main issue would be aperture. Do note that I have a D3100 with the kit lens. And aperture will be set to f22. I've read that the only way to adjust aperture is to adjust the aperture mechanism inside the 18-55mm lens by inserting a small rubber band inside the lens. Any comments on these. Are there D3100 and D5100 users out there who have used extension tubes and gotten good results? Again thanks.
  4. #4
    TPF Supporter
    Join Date
    Jul 2005
    Posts
    22,924
    My Gallery
    (26)
    Liked
    4840 times
    If you buy the extension tubes made by Kenko, they have all of the electronic conacts that your lenses do. They support full lens functionality, so your focus and exposure will work just fine.
  5. #5
    TPF Junkie!
    Join Date
    Oct 2010
    Houston, Texas
    Posts
    1,386
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    174 times
    Tirediron does speak the truth on the Kenko tubes. I like my set even though I haven't used them in a long while.
  6. #6
    Join Date
    Apr 2012
    Los Angeles, CA
    Posts
    572
    My Gallery
    (1)
    Liked
    30 times
    I've done some further research and it seems the Kenko tubes have the necessary circuitry to support TTL. Unfortunately, it is way above my budget as I still am prioritizing my purchase of a prime lens. Maybe for the time being, I'll go with the diopters and when I have the budget I will reconsider them. The good thing is now I know more about extension tubes. Thanks for the input.
  7. #7
    Chief Free Electron Relocator
    TPF Supporter
    Join Date
    Mar 2011
    Iowa
    Posts
    14,660
    My Gallery
    (0)
    Liked
    4493 times
    If budget is a pressing issue, don't bother with the diopters and put the money you would have spent on them towards the Kenkos. Yeah, you may get close-ups, but you'll quickly outgrow the filters and want to get the Kenkos. If you get the diopters, you'll just be that much farther away from getting the Kenkos.
    I see dead pixels!
    Go forth and actuate!
    Lens Across America, ROUND 3!!!!
  8. #8
    Join Date
    Apr 2012
    Los Angeles, CA
    Posts
    572
    My Gallery
    (1)
    Liked
    30 times
    Quote Originally Posted by 480sparky View Post
    The Kenkos cost $200 and so is the Nikon 35mm prime. I haveeyeing the prime way before shooting macros. A cheapo diopter set cost around $10. Ok IQ is in question but I have seen sample pics and they seem decent to my amateurish eyes. As for my moment I can afford to "splurge" $10. All I have to do is not to eat at my local fast food joint which will also save me some unwanted calories. Meantime, I'll start saving on those Kenkos. Maybe if I no longer eat at fast food restos, I can soon buy those Kenkos. And it's much healthier too!
  9. #9
    TPF Junkie!
    Join Date
    Dec 2011
    WV
    Posts
    1,912
    My Gallery
    (30)
    Liked
    194 times
    Before I would pay $200 for the Kenko, I would save up for a macro lens.
    Nikon
    my flickr http://www.flickr.com/photos/79635199@N04/
    If it looks good, IT IS GOOD.
  10. #10
    Join Date
    Apr 2012
    Los Angeles, CA
    Posts
    572
    My Gallery
    (1)
    Liked
    30 times
    The Nikon 40mm f/2.8G AF-S DX is $280 and cheaper if used. I Just don't know how it will compare to the 35mm f/1.8 and further don't know if it's wise to have both. Also, the Sigma and Tamron 70-300mm zoom lens with macro capablities is also appealing to me obviously due to the "additional zooming" capabilities even if there is no IS/VR.
    I guess the real advantage of having a limited budget is that you tend to consider very carefully what equipment you are going to purchase and not just base it on a whim.
  11. #11
    TPF Supporter
    Join Date
    Jul 2005
    Posts
    22,924
    My Gallery
    (26)
    Liked
    4840 times
    Don't forget the best photo store of them all... Craig's List! A set of Kenko tubes were just on my local list for $100!
  12. #12
    Join Date
    Apr 2012
    Los Angeles, CA
    Posts
    572
    My Gallery
    (1)
    Liked
    30 times
    Quote Originally Posted by tirediron View Post
    That is always an option but unfortunately there are no extension tubes available within a 50 mile radius from where I am. eBay may be a better option to find a used one.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Macro Extension Tubes
    By blueguy20 in forum Photography Equipment & Products
    Last Post: 10-25-2013, 05:35 AM
  2. Macro Extension Tubes
    By EchoingWhisper in forum Beyond the Basics
    Last Post: 08-23-2011, 10:44 AM
  3. Need help with Macro Extension tubes
    By chvenkatarajesh in forum Photography Equipment & Products
    Last Post: 05-10-2011, 06:05 AM
  4. Macro Extension Tubes?
    By PerfectlyFlawed in forum Photography Beginners' Forum
    Last Post: 02-21-2010, 07:14 AM
  5. Macro lens, extension tubes, macro filter, or bellows?!
    By TamiyaGuy in forum Beyond the Basics
    Last Post: 11-15-2008, 03:28 AM
diopter for macro photography
diopter lenses vs extension tubes
macro photography diopters
nikon diopter macro
nikon extension tubes 40mm
nikon macro diopters
tips to adjust the aperture while using the extension tube
using diapters with macro photography extension tube diapters
what when i use an extension ring ahead of a lens
whats better between diopter and extension tube?
