Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Thread: Newby question
  1. #1
    Join Date
    Aug 2013
    West Tn.
    Posts
    9
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Newby question
    Hello all. I am new to the photography scene and I have a question. I bought a Nikon D5100 to record and take pictures of my daughter in marching band and her band competitions on football fields. My question is, which lens do I need to buy to be able to get the best picture and video quality without breaking the bank? I will be towards the top of the bleachers which is not very far away in a high school stadium. I was thinking a wide angle lens would work, but as I learn more, I think I am wrong. Any help would be greatly appreciated. Also, wondering where I might find a microphone for this camera that would be to sit at the bottom at the stands and record the band to my camera as I record the video. Trying to block out the noise of the people in the stands. Thanks in advance.
  2. #2
    Completely Counter-dependent
    TPF Supporter
    Join Date
    Dec 2006
    Mid-Atlantic US
    Posts
    13,314
    My Gallery
    (63)
    Liked
    5141 times
    what is your budget?
    How far away are you from the field - in yards?
    Lew
    An Approach to Post-Processing (a long article with two start-to-finish examples )
    11 Tips for Beginning photographers
    Pictures, etc at LewLortonPhoto.com
    Twitter feed @LewLorton
    Skype Lewis.Lorton
    Art is not a mirror, but a hammer: it does not reflect, it shapes.
    Leon Trotsky, Literature and Revolution(1924):
  3. #3
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,490
    My Gallery
    (111)
    Liked
    1679 times
    Welcome to the forum.
    Do you want to get more 'close up' photos of her, or do you want photos of the whole band as they are on the field? If you want to get close up, then you will want a telephoto lens...something with a longer focal length. 200mm, 300mm etc.
    The opposite of that would be a wide angle lens, which would give you a wider view. These have a shorter focal length, 10mm, 18mm etc.
    I don't know much about microphones, but a quick search turned up this comparison of wireless mics (I'm sure that a wireless set up could be problematic, but I doubt you want to run a cord through the stands).
  4. #4
    Join Date
    Aug 2013
    West Tn.
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    200-300 on a lens. I will be roughly 15-20 yards away fro the field and up higher. For the microphone, I wouldn't be opposed to running a cord down under the stands and up to railing.
  5. #5
    Join Date
    Aug 2013
    West Tn.
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Big Mike. I know this going to tough, but I want to get a close up of her and then zoom back out and watch the whole band. I have seen a macro wide angle lens and it is cheap, which scares me, because I want the images and video to be HD or as good as I can get them. I don't have the budget to buy a higher grade camera right now.
  6. #6
    Chief Free Electron Relocator
    TPF Supporter
    Join Date
    Mar 2011
    Iowa
    Posts
    15,710
    My Gallery
    (0)
    Liked
    5154 times
    Knowing how far you will be away, what camera you will be shooting with, and how large the subject is....... then it's simple math that will determine the optimum focal length.
    I own stock in FotoMat.
    Go forth and actuate!
    Lens Across America, ROUND 3!!!!
  7. #7
    TPF Junkie!
    Join Date
    Apr 2011
    Posts
    4,289
    My Gallery
    (5)
    My Photos Are OK to Edit
    Liked
    951 times
    Did your 5100 include a kit lens like the 18-55mm Nikkor?
    Do unto others as you'd have done unto you.
    Jesus
    My Flickr
  8. #8
    TPF Junkie!
    Join Date
    Dec 2006
    Campbellton, New Brunswick, Canada
    Posts
    2,322
    My Gallery
    (12)
    Liked
    358 times
    OP,
    I don't know anything about microphones but as for lenses did your camera come with a kit lens, something like 18-55 or similar? If so then use that for the wide shots, pair that with a 55-200 for the 'close up' shots, or 70-300 if you can find the funds. Gyms appear brightly lit but they really are not to a camera so don't be afraid to use the higher iso values of your camera. Better to have a properly exposed photo with a bit of sensor noise which can be dealt with, than an underexposed image with which you can't do much.
    Nikon Stuff
  9. #9
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,490
    My Gallery
    (111)
    Liked
    1679 times
    Quote Originally Posted by Vandergriff101 View Post
    When a lens says 'Macro', it just means that the lens has a shorter 'minimum focus distance'....so you could get the camera up close to a flower, for example.
    If you want close up, as in zooming in from far away, then you want a telephoto with long focal length. You really won't find many options in your price range. Maybe something like these
    Nikon AF Zoom Nikkor 70-300mm f/4-5.6G Lens (Black)1928 B&H
    Sigma 70-300mm f/4-5.6 APO DG Macro Lens for Nikon AF-D5A8306
    Tamron 70-300mm f/4-5.6 Di LD Macro Autofocus LensAF017NII-700
    So do you have the 18-55mm lens? Can you get a wide enough view with that lens? If so, you may just have to use two lenses and swap when needed.
    You could get a lens with a greater zoom range, something like 18-200mm so that you don't have to swap lenses, but keep in mind that these lenses typically don't give as much image quality as lenses with less zoom.
    There are plenty of options for wired microphones...you would just have to get an extension cord.
    Microphones | B&H Photo Video
  10. #10
    TPF Junkie!
    Join Date
    Dec 2006
    Posts
    2,322
    My Gallery
    (12)
    Liked
    358 times
    OP,
    A forum member is offering a 55-200 in the buy/sell board at a price well within your budget.
    Nikon Stuff
  11. #11
    TPF Junkie!
    Join Date
    Apr 2011
    Posts
    4,289
    My Gallery
    (5)
    Liked
    951 times
    Jesus
    My Flickr
  12. #12
    TPF Junkie!
    Join Date
    May 2012
    Posts
    1,105
    My Gallery
    (0)
    Liked
    300 times
    You can also get a refurbished 55-200 VR with warranty from Cameta for $125.
    If you can go outside of your budget by $50 i would HIGHLY recommend the 70-300VR. It will have better image quality and faster focusing. Its $590 new but you can get a refurbished one for $350!!! Its an amazing deal on a great lens (there is a non VR verstion that is much cheaper but is horrible.. make sure its the VR one)!
    Used Nikon AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED2161B
    Nikon 70-300mm f/4.5-5.6 G VR AF-S ED-IF Zoom Lens - Factory Refurbished includes Full 1 Year Warranty
  13. #13
    Join Date
    Jun 2013
    Canada
    Posts
    532
    My Gallery
    (0)
    Liked
    93 times
    I got my 70-300 vr for 416.00 plus taxes brand new. Just had to look out for a sale.
  14. #14
    Join Date
    Jun 2013
    Nashville, TN
    Posts
    75
    My Gallery
    (1)
    Liked
    7 times
    For daytime the 55-200 is a good suggestion. I do not think your budget will allow you to get good results at night under the lights on a football field.
  15. #15
    Join Date
    Aug 2013
    West Tn.
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by jwbryson1 View Post
    Yes it did.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Newby Question
    By Henrix123 in forum Photography Beginners' Forum
    Last Post: 06-25-2009, 07:47 PM
  2. Newby question...
    By linpelk in forum Photography Beginners' Forum
    Last Post: 02-15-2009, 12:15 PM
  3. Newby question
    By Applefanboy in forum Photography Beginners' Forum
    Last Post: 02-14-2008, 09:23 PM
  4. Howdy from DC area... newby, intermediate skill, question too
    By me2tall in forum Welcomes and Introductions
    Last Post: 12-31-2007, 03:20 PM
  5. Newby Question about Aperture...
    By roxysmom in forum Photography Beginners' Forum
    Last Post: 06-28-2007, 06:19 PM
i want to buy a nikon lence to video tape marching band
lens for football field band
marching band
son in marching band need good lens to get pics of him on the field
