+ Reply to Thread
Results 1 to 9 of 9
Thread: Custom WB
  1. #1
    Join Date
    Mar 2008
    Anchorage, Alaska
    Posts
    967
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    1 times
    Custom WB
    Do you have too keep reseting the custom WB every time like indoors n outdoors?
    www.flickr.com/photos/rjjphotography
    My Equipment:
    Canon EOS 30D || Canon EOS 50D || EF 16-35mm f2.8 L II || EF 24-70mm f2.8 L | EF 50mm f1.4 || EF 70-200mm f2.8 IS L || EF 100-400mm f4.5-5.6 IS L || Speedlite 580EXII
    Wist list
    Canon EOS 5D MII and the Pelican hard case 1614 series.
  2. # ADS
  3. #2
    Join Date
    Aug 2008
    Posts
    10
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Everytime you turn the camera off the white balance will reset.
    I have this 3 pack of cheat cards, ones a grey card, ones a black (handy for black point) and ones for white balance, everytime I go to shoot I take a image of the white one, then set the camera to that white balance in the custom settings. that way if the conditions change in the few short minutes I can change it later.
  4. #3
    Join Date
    Mar 2008
    Anchorage, Alaska
    Posts
    967
    My Gallery
    (0)
    Liked
    1 times
    Quote Originally Posted by sdowden View Post
    Thanks I appreciate it..... I have lot too learn.....
    My Equipment:
    Wist list
  5. #4
    It's all about - Light Site Moderator
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,093
    My Gallery
    (1)
    Liked
    1750 times
    Interesting. I have one card that does all of that. You get it from www.rawworkflow.com .
    Setting a custom white balance is a good idea whenever the light changes. White balance is easiest set from a card that is 18% grey. The key is knowing exactly the color and reflectance of whatever you use.
    There is white and there is white, and then there is the other white.
    Our eyes aren't reliable for distinguishing white because our brains continually make adjustments for us. Incandescent lighting is really a light shade of orange and flourescent light it actually a shade of light green, but our brain tends to make us humans think it's all white light.
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    "Even the easy things are tough, if you do them half-heartedly"
    FOR SALE : Stay Tuned!
  6. #5
    Join Date
    Mar 2008
    Anchorage, Alaska
    Posts
    967
    My Gallery
    (0)
    Liked
    1 times
    Quote Originally Posted by KmH View Post
    Thanx I am trying too shoot with alot of snow here in Alaska n all my pictures all comes out grey. So I tried different techniques and still having a few problems.....I try and try them out again.....
    My Equipment:
    Wist list
  7. #6
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,554
    My Gallery
    (0)
    Liked
    29 times
    Interesting. What camera do you use?
    I set it once and done with it. Then again, I'm using flash 99.9% of the time to main light source is my flash. On occasion outdoors, I'll preset it again (takes seconds).
    What cheats do you have?
    If your light source in flash or sunny day, set it on "sunny/daylight" or flash (a bit warmer then previous one) and have a blast
  8. #7
    Join Date
    Dec 2008
    Salisbury MD
    Posts
    36
    My Gallery
    (2)
    Liked
    0 times
    Are you sure this is a white balance problem. First Nikon recommends a grey card not a white card, however, white will work.
    But, the snow problem. Your cameras light meter will assume that any photo is normal. A photo with a large amount of snow in it is not normal, it's way too white so your cameras computer says "Wow its too bright I need to make it darker." and guess what? Your snow is grey. If you have a +/- control set your camera to over expose by one or two stops set it to +1 or +2 and see what happens.
  9. #8
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,554
    My Gallery
    (0)
    Liked
    29 times
    for exposure, I believe its called shooting lights to Over and darks to under (don't remember the saying ) but point is that camera will attempt underexpose lights and overexpose darks thus you have to compensate for that
  10. #9
    Keeper of the Padlocks Site Moderator
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    15,103
    My Gallery
    (0)
    Liked
    899 times
    I belive this article might give some advince on setting white balance as well as the topic in general:
    White Balance
    Jim gives a good measure for working in snow - but I will also add that you should use your histogram - take a shot and review it with the histgram in the camera and then adjust your exposure based onthat - it should give you a better idea of roughly how much you can get away with overexposing the shot before you start to get blown highlights.
    more info:
    Histograms - Part I
    Histograms - Part II
    Finally another very good measure is to also shoot in RAW because RAW will let you adjust the white balance in the shot in editing. This is a very big advantage because it means that even if auto or manual white balance fail, you can still correct the error later. Note that whilst you can correct some white balance problems with a JPEG image it takes a lot longer and is a lot harder to perform and have the effect looking correct (and without having the image suffer from pixelation and banding).
    more info:
    Why Raw -- Part I
    How to get critique and feedback on your photography!
    Photo of the month April Voting now open
    The Mentor Scheme mentoring on TPF all are welcome to read and apply
    Best photos on the net!
    well at least I like to think so - sometimes
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Custom Motorcycles C&C
    By Randy55 in forum General Gallery
    Last Post: 01-22-2010, 03:51 PM
  2. Custom Brackets...
    By natc143 in forum Photography Equipment & Products
    Last Post: 02-01-2009, 05:07 PM
  3. DIY Custom camera bag?
    By mimstrel in forum Photography Equipment & Products
    Last Post: 08-04-2008, 07:11 PM
  4. Custom Computer?
    By AprilRamone in forum General Shop Talk
    Last Post: 01-05-2008, 04:04 PM
  5. Custom PCs in the UK?
    By Don Simon in forum Off Topic Chat
    Last Post: 08-28-2007, 09:51 AM
+how to adjust the histgram on the canon 50d
custom wb
reset custom wb 5d mark2
