+ Reply to Thread
Results 1 to 8 of 8
  1. #1
    Join Date
    Jun 2009
    Oxford, UK
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Question Flash Shutter speed and syncing speed.
    Hi,
    my name is andy and i'm new to this forum and also relatively new to photography.
    I'm hoping to get a bit of guidance from here.
    I'm having a few issues with my nikon D300 and nikon SB900. Why is it that when using the flash on top of my camera it doesn't use a higher shutter speed than 1/60th?
    I've set the flash sync speed to 1/320th FP but when i go into the flash shutter speed, it only goes upto 1/60th?
    I have my camera on aperture priority and the flash gun on Aperture also.
    Can anybody tell me where im going wrong?
    Thanks.
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,242
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    108 times
    Only goes up to? 1/60th is the lowest setting and also the setting the camera will select when it is low on light. So when in aperture priority or any of the automatic modes, the camera will pick 1/60th if the light is 1/60th or below, then pick a range between 1/60th and 1/250th if that is what the correct normal (non flash) exposure calls for, and in even brighter conditions will either over expose or set the flash higher still using FP sync.
    Put the camera into either shutter priority, or more usefully into full manual when doing high speed sync. Remember there are a lot of variables in photography already and now you're adding a flash too; locking some settings using manual can help a lot.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  4. #3
    Join Date
    Jun 2009
    Oxford, UK
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Aha!!
    Thanks alot for that. It was really confusing me as i only ever shot in Aperture priority and in low light, hence why it was only go as fast as 1/60th.
    Thinking about what you said and having tried it, manual with a flashgun is easier than i'd expected.
    Thanks again!!
    This is a great forum.
  5. #4
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,242
    My Gallery
    (0)
    Liked
    108 times
    You're welcome. By the way in future these questions belong in the Beyond the Basics subforum, you'd get many more views there.
  6. #5
    TPF Junkie!
    Join Date
    May 2008
    Eastern Montana
    Posts
    1,533
    My Gallery
    (0)
    Liked
    0 times
    Does Nikon have a setting that you can set you shutter to a certain default speed in aperture priority with flash? My new 5D mkII has this feature. It will not drop below 1/60, or you can set it for 1/200 all the time in Ap. This is all via camera menus.
  7. #6
    TPF Junkie!
    Join Date
    Oct 2007
    Montreal, QC, Canada
    Posts
    6,082
    My Gallery
    (0)
    Liked
    3 times
    Quote Originally Posted by Montana View Post
    Most all dSLR cameras can... it is called manual mode... lol
    Kidding aside, you can set minimum shutter speed with flash in the menus and then control it via the different modes identically like your Canon.
  8. #7
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,242
    My Gallery
    (0)
    Liked
    108 times
    The maximum speed is selectable in menu too, including disabling FP sync.
  9. #8
    Join Date
    Jun 2009
    Oxford, UK
    Posts
    9
    My Gallery
    (0)
    Liked
    0 times
    Thanks again guy's!
    the advice has been really helpful!!
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Wind Speed, Shutter Speed, And Foliage
    By decado in forum Photography Beginners' Forum
    Last Post: 10-18-2009, 04:53 PM
  2. Question about max flash shutter speed.
    By TheUndisputed in forum Photography Beginners' Forum
    Last Post: 01-27-2009, 07:32 AM
  3. Flash and shutter speed
    By plastii in forum Beyond the Basics
    Last Post: 11-27-2007, 09:17 AM
  4. Shutter Speed vs. Flash
    By woodsac in forum Beyond the Basics
    Last Post: 04-15-2006, 06:19 AM
  5. Replies: 4
    Last Post: 12-04-2003, 06:34 AM
sb900 flash shutter speed
