Help: Radio Control flash triggers
This is a discussion on Help: Radio Control flash triggers within the Photography Beginners' Forum & Photo Gallery forums, part of the Foundations of Photography category; Im trying to do some more complicated flash photography. So I did buy the (Chinese) RC flash triggers. There are no instructions. I tried testing ...
Go Back   The Photo Forum - Photography Discussion Forum > Foundations of Photography > Photography Beginners' Forum & Photo Gallery
Photography Beginners' Forum & Photo Gallery Brand new to photography, or brushing up on some of the basics? Don’t be shy! Talk to other beginners and ask all your basic photographic questions here. Show us some of the photos you have taken so far and get some review - so you can learn where there is room for improvement!
Reply
LinkBack Thread Tools Display Modes
Old 07-03-2009, 09:24 AM   #1
illstudio's Avatar
My Photos Are NOT OK to Edit
My Gallery: (3)
I tried testing the setup and the flashes wont trigger. I guess Im at a loss how to use them..
Phoshot 4 Channel Flash Trigger + 3 Receiver PT-04 V2s - eBay (item 140303850143 end time Jul-24-09 19:14:17 PDT)
Any ideas? The seller is no help.
I have an Olympus E-Volt 520 DSLR, a Nikon SB-24 flash and an Olympus FL-39 flash. The triggers say they work with both flashes.
What settings do I put on the flashes and the camera?
illstudio is offline   Reply With Quote
Sponsored Links
ThePhotoForum.com is the premier Photography Forum & Digital Camera Resource! Registered Users do not see the above ads. Please Register - It's Free!
Old 07-03-2009, 09:31 AM   #2
My Gallery: (0)
Are your receivers set to the same channel as your transmitter/trigger? Just starting with the obvious, please do not think I am trying to insult your intelligence.
paulk_68 is offline   Reply With Quote
Old 07-03-2009, 09:33 AM   #3
I am Big, I am Mike
Site Moderator
Big Mike's Avatar
TPF Supporter
My Gallery: (94)
First thing, check to see if the batteries have a plastic cover (that one got me). I'd also suggest getting new/fresh batteries as well. You never know how old these batteries are, they are often close to dead by the time you get them.
Once the batteries are in order, make sure the transmitter and the receiver are on the same channel (little switches in the same positions). Then you should be able to test fire the flash with a button on the sending unit. Once that works, you can put the transmitter on the camera and start using it.
When using this type of off-camera flash, the camera and the flash should be in Manual mode. The shutter speed should be below the max sync speed of your camera. I'd suggest trying 1/125 or 1/60 to be safe. Then you can adjust your aperture and/or the flash's power setting until you get the exposure you want.
__________________
"The most important thing I have learned over the years is the difference between taking one's work seriously and taking one's self seriously. The first is imperative, and the second disastrous"
Edmonton Wedding Photographer ==>Blog
Big Mike is online now   Reply With Quote
Old 07-03-2009, 10:06 AM   #4
illstudio's Avatar
My Gallery: (3)
Yes they are.
Old 07-03-2009, 10:12 AM   #5
illstudio's Avatar
My Gallery: (3)
The transmitter appears sealed. The receiver(s) takes 2 AAA bats. The channels are the same. Pressing the test button gets no response from the flashes, HOWEVER I do see a small light flash/blink on the receivers when I do press the test button on the transmitter. So it must be getting the transmit signal???. Thats why Im stumped. Flashes are powered up fine. I tried other channels too.
Other ideas?
Old 07-03-2009, 10:33 AM   #6
TPF Junkie!
Samanax's Avatar
My Photos Are OK to Edit
My Gallery: (0)
Yes, the receivers are getting the fire flash signal.
Other ideas?
How do you have the flash connected to the receivers? Is the flash mounted to the hot shoe on the top of the receiver or are you using that short sync cord?
__________________
Gear List / My Flickr
Samanax is offline   Reply With Quote
Old 07-03-2009, 10:34 AM   #7
DeadEye's Avatar
TPF Supporter
My Gallery: (6)
Well if you press the test button on the transmitter and a little led blinks on the receiver then the fire signal is good. You can rule out transmitter and channel as problem. Take a close took at the pin contacts between the receiver ans flash.
In a similar case I had same problem with Pocket Wizards. Press test on transmitter and get blinky on receiver but no flash on old vivitar flash. Worked well with newer flash though. Turned out to be contact delay time to short. In other words you have to short the center pin to ground for like more than 5 milliseconds in order to fire the flash. Modern units only need a few milliseconds and that is all you get from the receiver. On the pocket wizard multi max unit you can program the contact delay to what ever you want but it is a very expensive transceiver.
__________________
DeadEye is offline   Reply With Quote
The Following User Says Thank You to DeadEye For This Useful Post: illstudio (07-03-2009)
Old 07-03-2009, 11:15 AM   #8
Don Kondra's Avatar
My Gallery: (22)
Can't help with the flashes themselves, I use strobes, but...
On the camera, turn on the menu and go down to the fourth submenu. There you will find the setting for camera sync speed. This is totally different than pressing the top button and setting the cameras flash settings. As a matter of fact, you can set the on board flash to off. That setting has nothing to do with sending a signal to the receivers.
HTH,
Cheers, Don
__________________
Don Kondra - Furniture Designer/Maker
Olympus E-510 ~ E-3 ~ E-30
ZD 50 ~ 7-14 ~ 14-54 ~ 12-60 ~ 50-200 ~ EC 20
Velbon tripod/ ball head
Slik tripod/Jobu Jr 2 Gimbal
Don Kondra is offline   Reply With Quote
Old 07-03-2009, 02:06 PM   #9
illstudio's Avatar
My Gallery: (3)
HTH,
Cheers, Don
Thanks. There is an "RC" screen on the camera. I enabled it. I'm a step further, thanks! LOL
Ok, now, how do I set the camera for proper exposure? What do I set the mode dial at for?
If I have a subject at, say, 12 feet away from the remote flash. How would I set the camera and flash (O FP-39)?
Old 07-03-2009, 02:07 PM   #10
illstudio's Avatar
My Gallery: (3)
Other ideas?
The transmitter is on the cameras Hot shoe. No cords.
Old 07-03-2009, 02:18 PM   #11
I am Big, I am Mike
Site Moderator
Big Mike's Avatar
TPF Supporter
My Gallery: (94)
Camera will have to be in Manual mode. The shutter speed will have to be below the max sync speed of your camera. You can then use the aperture and the flash power setting to control the exposure from the flash.
But how is the flash connected to the receiver? It it's just sitting in the hot shoe of the receiver, make sure it's well seated as that could easily be your problem.
__________________
Old 07-03-2009, 02:26 PM   #12
Don Kondra's Avatar
My Gallery: (22)
It's a matter of balancing what f number you want to use against the power/distance to subject of the flash.
Oh, in manual mode.... start with say f 8 and work from there. The sync speed is 1/180 all the time
In very simple terms, if the image is overexposed, up the f number or turn down the flash power.
Play with it and post examples.
Cheers, Don
__________________
Old 07-03-2009, 02:27 PM   #13
illstudio's Avatar
My Gallery: (3)
Cheers, Don
Will do.
Old 07-03-2009, 02:50 PM   #14
TPF Junkie!
Samanax's Avatar
My Gallery: (0)
Read my question again. I didn't ask about the transmitter, I asked about the flash and the receiver.
__________________
Old 07-03-2009, 04:54 PM   #15
illstudio's Avatar
My Gallery: (3)
Well, yeah the flash is on the receiver...
Im not using the sync cords.
Reply
Lower Navigation
Tags
flash, radio control, rc flash triggers, strobe
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
Celebrity Gossip - United States Message Board - Parrot Forum - Honda Motorcycle - iPhone News - iPhone 4 Forum - Motorola Droid Forum - Nintendo Wii Forum - Apple iPad Forum
