Results 1 to 5 of 5
06-16-2008, 11:46 AM #1Been spending a lot of time on here!
- Join Date
- Jun 2008
- Posts
- 109
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 0 times
Macro lens or tele lens + closeup lens?
For macro shots, I can either buy this:
http://www.amazon.com/Canon-100mm-Ma.../dp/B00004XOM3
Or buy these:
http://www.amazon.com/Canon-70-300mm.../dp/B0007Y794O
http://www.amazon.com/Canon-250D-Clo.../dp/B000050M6M
I'm buying the 70-300mm regardless, as I need a good telephoto lens. So, any suggestions as far as the close-up lens vs. the 100mm macro lens?
Thanks in advance..
06-16-2008 11:46 AM # ADS
06-16-2008, 11:50 AM #2Just Corinna in real life Site Moderator
- Join Date
- Feb 2004
- Location
- Lower Saxony, Germany
- Posts
- 34,625
- My Gallery
- (1)
- My Photos Are NOT OK to Edit
- Liked
- 489 times
From what I can tell about my own telephoto lens with macro settings as opposed to, for example, our member doenoe's dedicated macro lens, his takes MUCH better photos than mine does in its macro settings. The telephoto lens in macro settings offers you only 1:2 (so doenoe explained to me on here only a short while ago), while a dedicated macro lens offers you a 1:1 ratio, which is what you want when you REALLY want to go into macro photography.
But let the real and true macro photographers such as doenoe or TCimages reply. They know what they have and can better recommend things. All I know is that a telephoto lens with macro settings only gets you halfway into macro photography. It is a pleasant toy, but if you mean to become more serious about it, you'll soon wish you had something better. (I'm at this point just now).
06-16-2008, 11:56 AM #3Been spending a lot of time on here!
- Join Date
- Jun 2008
- Posts
- 109
- My Gallery
- (0)
- Liked
- 0 times
Pardon my dumb question here, but I've seen people talk about 1:2, 1:1 ratio when talking about lenses.. what does the ratio refer to exactly?
06-16-2008, 11:58 AM #4Herding cats since 1988...
- Join Date
- Mar 2007
- Location
- The Magic Kingdom
- Posts
- 7,823
- My Gallery
- (315)
- Liked
- 9 times
1:1 is where the image on the film/sensor is the same as the object being photographed - 1:2 is half size, 1:4 is quarter etc.
flickr now showing...
obligatory blog - izdihar.com
"Photography is 1% inspiration, and 99% moving furniture..." - .lisakimberly.
06-16-2008, 12:41 PM #5I spend too much of my life on TPF!
- Join Date
- Jun 2008
- Location
- Whitstable
- Posts
- 573
- My Gallery
- (0)
- Liked
- 0 times
The macro lens will undoubtably give you far better results that adding a close up lens.
There are three reasons for this:
1) The macro lens is a prime lens and all else being equal they always have the edge over a zoom.
2) The macro lens is designed from the ground up for macro work so wherever compromises need to be made they are made to favour the macro side of things.
3) Adding extra curved glass to the light path (i.e. glass other than a filter) is always going to spoil the quality of the main lens even with an extremely expensive close up lens such as the one you are suggesting.
The main lens is designed as a complete unit with all the elements interacting in a defined and optimised way. You cannot then add some further element and expect the quality to be unimpaired.
Similar Threads
62mm 0.45x Wide Angle Lens + Macro Conversion Lens Adapter
By Link Delight Online Shop in forum Linkdelight Photography AccessoriesReplies: 0Last Post: 10-21-2010, 07:49 PM -
Will a Sigma 70mm f2.8 EX DG Macro Lens work with a Sigma 1.4 Tele Converter?
By N E Williams in forum Photography Beginners' ForumReplies: 8Last Post: 09-19-2010, 01:04 AM -
Tamron AF LD Tele-Macro 70-300mm Camera Lens for Pentax
By CrazyDriver in forum Buy and SellReplies: 1Last Post: 03-13-2009, 07:21 AM -
Need advice on choosing a wide lens, normal lens or macro lens.
By bla in forum Photography Equipment & ProductsReplies: 7Last Post: 06-13-2007, 08:20 PM -
? Nikon Lens to buy - Macro & Tele
By ermetekos in forum Digital Discussion & Q&AReplies: 9Last Post: 06-12-2007, 03:34 AM
close up lens on tele lens
,close up tele photography
,contact lens ppt
,macro versus tele
,macro vs tele lens
,macro x tele
,tele close up macro photo
,tele macro close up
,tele macro close-up
,tele macro vs macro
,tele wide or normal macro lens
,telelens --filetype:ps -filetype:dwf -filetype:kml -filetype:kmz -filetype:xls -filetype:ppt -filetype:doc -filetype:rtf
,telephoto lens with close up lens vs. macro lens
,why is a macro 70-300 mm lens better?
,why is a macro lens better for close-up than telephoto
LinkBack URL
About LinkBacks
