Results 1 to 9 of 9
Thread: Raw vs. JPEG
  1. #1
    Join Date
    Jan 2007
    Las Vegas, NV.
    Posts
    118
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Question Raw vs. JPEG
    Hi everybody,
    For the first time since I have had my digital cam, I downloaded the raw versions of my pics and I noticed that they are dramatically better than the JPEGs I had previously downloaded (shooting with RAW+JPEG). So, my question is: if I edit the RAW pics and then save them as JPEGs, will they still look better than the original JPEGs or will the compression make them essentially the same?
    As stated this is my first digital cam and therefore my first experience with RAW pics, so any info/advice would be much appreciated.
  2. #2
    Join Date
    Apr 2008
    Springfield, Missouri
    Posts
    780
    My Gallery
    (0)
    Liked
    2 times
    They will look better because you are starting with more "information". RAW files (photos) capture all the detail of the actual scene you are photographing, therefore more detail is available for rendering. JPG files only capture a certain amount of information (or the photo subject) and then fills in the rest based on the information around it. Therefore you are not getting a true depiction of what you are shooting.
    Canon 1Ds mk III/Canon 5D mk II/Canon 50D, Canon EF 400mm f/2.8L IS USM, 70-200 f/2.8L USM, Canon EF 100-400mm f/4.5-5.6L IS USM, 23-185 f/3.5-5.6 IS USM, 50mm f/1.8 II, 70-300 f/4-5.6, UVs and Polarizers for all, 580EX II, BG-E2N x 2
  3. #3
    Join Date
    Jun 2006
    Posts
    77
    My Gallery
    (0)
    Liked
    0 times
    Did you say that when you were using the .jpgs that weren't as good, you were getting them from shooting RAW + .jpg? Some cameras record a lower quality .jpg when shooting in RAW + .jpg, presumably to safe processing time when recording the large RAW file. Or did you mean that you were shooting solely in .jpg before, and then switched to RAW + .jpg to get the RAW files? If so, that shouldn't make any difference.
    But yes. The images should still look better starting from a RAW file.
  4. #4
    Iron Flatline
    Guest
    RAW for the win. Welcome the club.
  5. #5
    Join Date
    Feb 2009
    Houghton, MI
    Posts
    480
    My Gallery
    (0)
    Liked
    0 times
    If you're using a lower-end Nikon, your RAW+JPEG choice is actually a raw file and a basic (i.e. low) quality jpeg -- that could account for dramatic differences that you're seeing.
    While raw vs. jpeg is a bit of a holy war, the real answer is: learn about them both, and make the best choice for your situation. For example, I shoot jpegs mostly, but I occasionally go to raw when I know that I need a bit more dynamic range, or when I'm not sure that my camera will really be able to handle an unusual lighting situation. Don't let anyone tell you that there is a single correct answer, because (as with most things in life), there is no absolute here.
    In the end, it's your composition, colors, lines, stories, etc. that matter. Raw files can help you get a bit more quality out of your images, and jpegs can help you get images from camera to computer faster, but if they aren't GOOD images, it doesn't matter one bit.
    David Clark Photography, photo blog, flickr.
    It is OK to edit and repost my photos on TPF only.
  6. #6
    Join Date
    Jan 2007
    Las Vegas, NV.
    Posts
    118
    My Gallery
    (0)
    Liked
    0 times
    Thanks a lot for the responses. To clarify, I've been shooting RAW+JPEG from the time I got the camera, but I never got around to installing the RAW converter until last week. So, up until then, I was processing the JPEGS via photoshop and leaving the RAW version on the memory card. The memory card finally got to the point where the Raw's were filling up the card, so I installed the Raw converter and noticed the difference between the previous JPEGs and the newly downloaded RAWs.
    So, as a result, I was wondering if I edited them and copied the result to a JPEG, if they would retain the appearance of the RAWs or if it was the compression of the JPEG that was causing the lesser image.
    Again, thanks for the helpful comments.
    Last edited by EYEAM4ANARCHY; 04-14-2009 at 03:48 AM. Reason: I think faster than I type.
  7. #7
    Join Date
    Dec 2008
    San Francisco Bay, CA
    Posts
    477
    My Gallery
    (0)
    Liked
    2 times
    just use photoshop to convert the raws. u dont need a separate program, unless ur using an old version of PS. and yes, always shoot with raw+jpeg. i use the jpegs to preview the composition and delete if i dont like the pics, then the keepers get saved over from the raw.
  8. #8
    Join Date
    Jan 2007
    Las Vegas, NV.
    Posts
    118
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by CraniumDesigns View Post
    just use photoshop to convert the raws. u dont need a separate program...
    I could never get the RAWs to load onto PS. The JPEGs load automatically, but it doesn't seem to even recognize the RAWs.
  9. #9
    TPF Junkie!
    Join Date
    Jan 2009
    Kaneohe, Oahu
    Posts
    2,562
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by EYEAM4ANARCHY View Post
    You need to update the ACR (Adobe Camera RAW) that your version of PS uses.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. "Image Quality": JPEG normal vs. JPEG fine
    By a1157814a in forum Photography Beginners' Forum
    Last Post: 01-29-2012, 01:03 PM
  2. Raw, Jpeg, or Raw+Jpeg
    By RockstarPhotography in forum Photography Beginners' Forum
    Last Post: 02-04-2011, 04:21 PM
  3. RAW vs. JPEG...??
    By MGriff240 in forum Photography Beginners' Forum
    Last Post: 03-01-2010, 11:20 AM
  4. DPI for jpeg
    By indigenous in forum Digital Discussion & Q&A
    Last Post: 11-19-2006, 01:21 AM
  5. TIF or JPEG?
    By neeleymartin in forum Photography Beginners' Forum
    Last Post: 08-07-2006, 10:39 AM
raw vs jpeg canon
Tags for this Thread
