Results 1 to 10 of 10
06-06-2009, 04:09 AM #1TPF Noob!
- Join Date
- Mar 2009
- Location
- Maine
- Posts
- 12
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 0 times
How To Mount A Hoya Infrared Filter To A Canon A650?
I purchased a Hoya IR filter (R72, 58mm, pitch 0.75) that is supposed to fit on a Canon A650 -- so said all the literature I read.
I'm a beginner and figured that it would click/snap/screw on, but it does not fit at all. It seems too big for the stock lens that I have.
I have no idea where to go from here so I need help.
Any ideas?
Thanks in advance.Today they call you crazy. Tomorrow they call you "ahead of your time".
Amazing Photos - Chemtrails - Animal Gallery
06-06-2009 04:09 AM # ADS
06-06-2009, 08:33 AM #2
You may need something like this
Amazon.com: Canon LA-DC58J Conversion Lens for A650IS Digital Cameras: Camera & Photo
06-06-2009, 08:40 AM #3TPF Junkie!
- Join Date
- May 2009
- Location
- Glasgow
- Posts
- 1,717
- My Gallery
- (0)
- Liked
- 2 times
what is your stock lens?
im guessing the 18-55mm? in which case it SHOULD screw in (read the rim of the lens it should say a size other than the size of the focal, that is what size of filter will fit it i.e. my 50mm is a 52mm mount where as my 75-300mm is a 58mm mount
just looked at what the Canon A650 is...
you will never get a 58mm filter onto that, filters are desicled for SLR cameras not compacts
the above link is about the only thing you can do
06-06-2009, 01:29 PM #4TPF Noob!
- Join Date
- Mar 2009
- Location
- Maine
- Posts
- 12
- My Gallery
- (0)
- Liked
- 0 times
More Research Needed
OK, thanks for the info.
I will research this tonight and see what has to be done.
Thanks.Today they call you crazy. Tomorrow they call you "ahead of your time".
06-08-2009, 10:53 PM #5TPF Noob!
- Join Date
- Mar 2009
- Location
- Maine
- Posts
- 12
- My Gallery
- (0)
- Liked
- 0 times
We'll Soon See
I called the company at Amazon that offers that adapter linked to earlier in this thread and they said it would allow me to mount my Hoya 58mm IR filter to a Canon A650IS.
I went ahead and ordered it and will report back about how it works.
Thanks again for the suggestions.Today they call you crazy. Tomorrow they call you "ahead of your time".
06-08-2009, 11:10 PM #6
The company that sells the adapter in Amazon is Adorama. If they say it will work, most likely it will work for you.
Once you get the adapter, be sure show us the result with the filter!
06-09-2009, 07:56 AM #7
06-09-2009, 08:11 AM #8
I do not know since I do not own the camera.
A plastic lens hood that made by Canon will cost that much (or more). So a plastic adapter like that made by Canon, I will not be surprised if it cost over $20.
06-09-2009, 03:53 PM #9TPF Noob!
- Join Date
- Mar 2009
- Location
- Maine
- Posts
- 12
- My Gallery
- (0)
- Liked
- 0 times
Yea, the adapter was $21... Reasonable.
I'm getting it to adapt a 58mm Hoya IR filter to my A650IS to do IR timelapse.
I've already done some non-IR timelapse using two methods:
1. CHDK (Canon A650IS)
2. GBTimelapse (Canon A520)
06-18-2009, 03:01 PM #10TPF Noob!
- Join Date
- Mar 2009
- Location
- Maine
- Posts
- 12
- My Gallery
- (0)
- Liked
- 0 times
Just an update to let you know that the Canon adapter DOES allow the mounting of the 58mm Hoya IR filter to the A650IS. Just pop off the plastic chrome-colored cosmetic ring around the lens, and twist on the adapter (remembering to push the release button both times).
It works wonderfully.
I've tried doing some IR timelapse but am a little disappointed with the results. It works, but does not capture heat profiles as I was hoping.
I think I'm going to have to look for something specifically made for doing IR photography as the sensor in a consumer camera is just not sensitive enough for picking up heat signatures with a filter.
You can see the light emitted when you press a remote control button though. Still, not enough sensitivity, I think.
If anyone has ideas about equipment for doing real IR photography, I'd love to know about it.
Thanks.
Here is another timelapse I took with the Canon A650IS using CHDK:
Similar Threads
Sigma 18-250mm f/3.5-6.3 with Hoya multi coated UV filter (Nikon mount) $415
By iAstonish in forum Buy and SellReplies: 2Last Post: 08-10-2010, 11:16 AM -
which Hoya filter line is the appropriate quality filter for a simple kit lens?
By jc1234 in forum Photography Equipment & ProductsReplies: 11Last Post: 07-19-2010, 11:08 AM -
FS: Canon EF-S 18-200mm f/3.5-5.6 IS + Hoya 72mm UV Filter + EW-78D Hood
By canonikon in forum Buy and SellReplies: 0Last Post: 07-14-2009, 10:12 AM -
infrared hoya 35mm
By toxic_stars in forum Beyond the BasicsReplies: 5Last Post: 01-17-2005, 11:02 AM -
Infrared with the Digital Rebel and the Hoya R72
By Digital Matt in forum General GalleryReplies: 14Last Post: 08-23-2004, 10:50 AM
58mm hoya filter does not screw on
,a650 infrared
,a650,ir
,a650is infrared
,all you need is a hoya infrared filter here is the site http://www.hoyafilter.com/
,canon a520 infrared
,canon a650 filter
,canon a650 filters
,canon a650 infrared conversion
,filter converter hoya
,how to mount a filter
,how to mount uv 72 filter canon hoya
,hoya filter 55mm pitch:0.75 infrared (r72)
,ir filter canon mount
,ir filter in canon a650
LinkBack URL
About LinkBacks
