Results 1 to 12 of 12
  1. #1
    Join Date
    Jul 2009
    Utah
    Posts
    8
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    "Closest Focusing Distance"
    Okay.
    As I'm looking around at lenses, particularly macro ones, I notice that it says "Closest focusing distance" or "Minimum focus distance" and its usually around a foot to a foot and a half.
    Even on macro lenses?!
    Am I missing something?
    (Sorry. I'm such a n00b.)
    How can this lens have a focusing distance of 1 foot and 2.4 inches and be able to take images like this and this?
    Sorry. But I just don't understand.
    Can someone explain?
    Like. Is it the 100mm making it be like THAT close or are they fibbing on focus distance. Or are they cropping in after the picture??
    Hahaaa. Thanks for any help, I'm just so used to being able to put my camera in macro "mode" and touching the object with the lens!
    [Click it. ]
  2. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,206
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1571 times
    The minimum focus distance for many lenses is several feet. So if you can focus at 14" with a 100mm lens, that is pretty close.
  3. #3
    Join Date
    Jul 2009
    Lancaster, PA
    Posts
    203
    My Gallery
    (0)
    Liked
    0 times
    With macro lenses the first thing to look at is maximum magnification. Assuming you know what that means, the next thing to look at is working distance. Longer focal lengths allow you to be farther away from your subject and still obtain whatever magnification they claim to have. This is especially useful for skittish subjects like bugs. For studio work you probably wouldn't care as much. Longer focal lengths usually cost more too.
  4. #4
    Join Date
    Jul 2009
    Akron Ohio
    Posts
    46
    My Gallery
    (7)
    Liked
    0 times
    I've been reading up on macro lenses recently to as I'm in the market for one. I'm still new to it but think I have a good understanding. Here are a few examples of how I see it working.
    A 50mm macro lens might have a minimum focusing distance of 7.4" at 1:1 magnification which means it'll be life size and can focus when it's 7.5" away from the lens.
    A 105mm macro lens might have a minimum focusing distance of 12.3" at 1:1 magnification which means it'll be life size and can focus when it's 12.3" away from the lens.
    A 180mm macro lens might have a minimum focusing distance of 18.1" at 1:1 magnification which means it'll be life size and can focus when it's 18.1" away from the lens.
    What this all means is that each lens will achieve the 1:1 magnification but longer focal length while remaining at 1:1 magnification will allow the camera to be further from the subject which makes it nice for different flash options and to help keep from scaring off the subject (if an insect) not to mention the use of extension tubes and teleconverters.
    EDIT: which is basically exactly what Stosh said
  5. #5
    Join Date
    Dec 2011
    Seattle, WA
    Posts
    My Gallery
    (0)
    Liked
    0 times
    Re:
    Slight Adjustment... When you say 12.3, or 18.1 inches away, the distance is from the film plane, not the lens. i.e. a 180mm Macro lens with an 18" Min focus distance may only be 9 inches from the subject at the FRONT of the lens.
  6. #6
    Join Date
    Oct 2007
    Posts
    740
    My Gallery
    (0)
    Liked
    46 times
    And bear in mind that it's the distance from the sensor in your camera, not the front of the lens.
  7. #7
    TPF Junkie!
    Join Date
    Jun 2010
    minnesota
    Posts
    3,459
    My Gallery
    (0)
    Liked
    643 times
    Yup distance from subject to sensor, so depending on the size of you lens + hood your subject is going to be alot closer than you think.
    Also, at 1:1, your seeing your subject at life size. So a ladybug will fill the frame more than a small fly and you may only fill the frame with the head/eyes of a large dragonfly at 1:1.
    Our human eyes see allbugs as relatively small, at 1:1 your seeing the difference in 10mm much more clearly.
    Shot at min focusing distance of .30m on my tokina 100mm f2.8 macro, I can't recall if this was cropped(most likely)
  8. #8
    TPF Junkie!
    Join Date
    Sep 2010
    Bowling Green, KY
    Posts
    2,014
    My Gallery
    (0)
    Liked
    418 times
    ^ Nice shot Jake! Any additional lighting used?
    Nikon D7000, Nikon MB-D11, Nikkor 28mm f/3.5, Nikkor 55 f/2.8 Micro, Tokina 11-16 f/2.8, Tokina 16-50 f/2.8, Tokina 50-135 f/2.8,
    Slik
    580DX, Domke F-2 & F-5XB,(3) Nikon SB-28 & SB-600, Yongnuo RF-602, Hoya 77mm CPOL
  9. #9
    TPF Junkie!
    Join Date
    Jun 2010
    minnesota
    Posts
    3,459
    My Gallery
    (0)
    Liked
    643 times
    Quote Originally Posted by mjhoward View Post
    If anyone wants to make one:
    Heres how my first one turned out.
    DIY diffuser holder, diffuser from cheap pop-up flash diffuser and sb600 on camera.
  10. #10
    TPF Junkie!
    TPF Supporter
    Join Date
    Aug 2011
    Posts
    17,146
    My Gallery
    (0)
    Liked
    4382 times
    Keep in mind that while the more expensive, longer focal length macros all have longer "closest focusing distances".. the lenses are longer also... so the distance from the front of the lens to the subject is still minimal. The longer ones do have more distance though... proportionately. Subtract the length of the lens and another inch or so.. to get a more accurate idea of actual lens to subject distance. I have found that anything under 85mm usually requires you to get so close that you spook most subjects (if you are shooting insects)... and this also gets in the way of using flash (unless OC) since you are so close.
    I highly recommend 100mm and up... although something in the 85 range can do nicely. most 50mm\60mm's.. you just have to get TOO CLOSE! Of course if you shoot Canon... the MPE65 is the ultimate macro lens (DROOL)! I wish that Nikon made a similar lens!
  11. #11
    has a hat around here somewhere Site Moderator
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    19,789
    My Gallery
    (0)
    Liked
    2496 times
    psst guys check the first post date - its 2 years old
  12. #12
    TPF Junkie!
    TPF Supporter
    Join Date
    Aug 2011
    Posts
    17,146
    My Gallery
    (0)
    Liked
    4382 times
    Quote Originally Posted by Overread View Post
    hahahah.. busted! I just read the couple of posts above me.... and ran with it! Cracks me up when noobs open up old posts... and usually I catch it! Thanks!
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. "1st colors of spring", "Reaching out", "Dirty View"
    By MM Turner in forum General Gallery
    Last Post: 04-15-2008, 02:51 PM
  2. Replies: 11
    Last Post: 01-18-2007, 11:43 AM
  3. Replies: 26
    Last Post: 06-04-2006, 02:15 PM
close focus distance
close focusing distance
closest focus distance
closest focusing distance macro
diy flash diffuser
what does closest focusing distance mean
what is closest focusing distance
what is the closest focusing distance on most cameras
what is the minamun focus distanse of the i phone
