Results 1 to 9 of 9
  1. #1
    Join Date
    Jul 2009
    Tijuana Mexico , El Cajon CA
    Posts
    55
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Aspect Ratio ?? 3:2 or 16:9 ??
    Whaasup you guys . . .
    Ok so I got another question for you guys , how come my pictures are a lot different than the ones taken with my point and shoot Canon SD630 ??
    I mean on my Sony's A200 pics it looks like they are a widescreen tv , and with my Canon's pics they look like regular TV , do I make any sense ??
    Which format do you guys use and why ??
    How come when I try to resize (in order to cut down the size) I can not get 800x600 , I get 800x536 ?? when I take a pic with my Canon I can get 1024x768 , 800x600 , 640x480 but with my A200 I get a whole different set of sizes ??
    Any input will be highly appreciated , and if you can explain it in simple non-photography expert english will be even better
  2. #2
    TPF Junkie!
    Join Date
    Oct 2006
    South Carolina USA
    Posts
    1,347
    My Gallery
    (0)
    Liked
    0 times
    The size and shape of your sensor. If you were to look at the Sony's sensor (what captures the image) it looks wider than it is long...more like a rectangle and a widescreen TV.
    The Canon one (along with most point and shoots) are more square in size. That's why when you print DSLR pictures, the image is not cropped becuase it's already formatted to the 4x6 or proportional size print whereas the Canon point and shoot is more square and some gets chopped off
    ~Michael~
    ~Michael~
    Michael
    D3 D300
    l 24-70 2.8 l 70-200 2.8 VR I l Sigma 150 2.8 Bugma l 50 1.8 l 28 2.8 l SB-800 l Manfrotto 055XBPro and Ball Head
    Some people see things
    and say
    WHY?
    I look at things
    and Say
    Why NOT?
  3. #3
    TPF Junkie!
    Join Date
    Oct 2007
    Cedar Hill, Texas
    Posts
    14,528
    My Gallery
    (4)
    My Photos Are NOT OK to Edit
    Liked
    1209 times
    Your title answers all of your questions.
    They are different aspect ratios.
    My camera doesn't have the option to shoot in different aspect ratios (it's 2:3).
  4. #4
    Join Date
    Jul 2009
    Posts
    55
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by iflynething View Post
    ~Michael~
    ~Michael~
    Thank you . . .
    Quote Originally Posted by O|||||||O View Post
    Dude . . . If I knew what I was talking about , I wouldn't ask don't really know what kind of camera you have , all I know is that mine does have those aspect ratios , and I have no idea what to do with either one . . .
    Can anybody else give me some detail on this ??
  5. #5
    TPF Junkie!
    Join Date
    Oct 2006
    South Carolina USA
    Posts
    1,347
    My Gallery
    (0)
    Liked
    0 times
    I personally have have not need to change the aspect ratios. your 3:2 would print with no cropping as a 4x6 or proportionally larger.
    As far as I know, the A200 will not have the option to shoot in different aspect ratios (if you didn't know that already) but you can just change the file size and quality but the aspect ratio will stay the same no matter what.
    A quick Wikipedia search revealed more results http://en.wikipedia.org/wiki/Aspect_ratio_(image)Aspect ratio (image) - Wikipedia, the free encyclopediaAspect ratio (image) - Wikipedia, the free encyclopedia
    If you look at the 16:9 for instance, that would be good for a panoramic shot. The 4:3 would be good for 8x10....well it's the same format size as an 8x10. If you set your camera to the 4:3 then you could take a picture, and without cropping at all, print an 8x10.
    Is there something else in particular you're looking for an answer?
    ~Michael~
    Michael
    D3 D300
    and say
    WHY?
    I look at things
    and Say
    Why NOT?
  6. #6
    TPF Junkie!
    Join Date
    Oct 2007
    Cedar Hill, Texas
    Posts
    14,528
    My Gallery
    (4)
    Liked
    1209 times
    Quote Originally Posted by LokoTripper View Post
    2:3 most likely uses more of the sensor than 16:9.
    Other than that, one isn't necessarily "better" than the other...
    Though, if you plan on printing 4x6's, 2:3 will probably be the better choice since it won't require cropping.
    It's just a ratio to tell you the shape of the picture.
    2:3= 4x6, 6x9, 8x12, 10x15, 12x18, etc... (Are you seeing the pattern?)
    If the short side was 25 inches, the long side would be 37.5 inches.
    (25 is 12.5x2, 37.5 is 12.5x3)
    With 16:9 you could get non-cropped sizes like 8x4.5, 12x6.75, or the obvious - 16x9.
    It's just a ratio...a comparison of one side to the other.
  7. #7
    Join Date
    Jul 2009
    Posts
    55
    My Gallery
    (0)
    Liked
    0 times
    ~Michael~
    Thanks dude . . . that was exactly what I was looking for
    Thanks . . . I plan on printing 8x12 or 6x9 , so I guess they will work , thank you dude !!
  8. #8
    TPF Junkie!
    Join Date
    Oct 2006
    South Carolina USA
    Posts
    1,347
    My Gallery
    (0)
    Liked
    0 times
    Glad we could help
    ~Michael~
    Michael
    D3 D300
    and say
    WHY?
    I look at things
    and Say
    Why NOT?
  9. #9
    TPF Junkie!
    Join Date
    Jul 2009
    United States of America
    Posts
    1,058
    My Gallery
    (0)
    Liked
    1 times
    ~Michael~
    ~Michael~
    Thank you . . .
    The simplest example is a 1:1 ratio, which is a square image. If you print that image on 4X6 paper, the image will be 4X4 and you will need to cut off the white space. Alternately, you could enlarge the image to 6X6 but then you couldn't print the entire image.
    The 2:3 ratio means that the physical size of the image is two units by three units. Pick any unit that you want to enlarge or shrink the photo. For example, if I pick one unit = 2 inches, then this ratio will print perfectly on borderless 4X6 paper. However, if you print it on borderless 5X7, you would either have white bars on the sides or, if you enlarge, you will have to cut off a half inch from the height (that ratio would need 5X7.5 paper).
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. How to decide the aspect ratio of a photo?
    By thesandeep in forum Photography Beginners' Forum
    Last Post: 01-26-2011, 07:18 PM
  2. Aspect Ratio
    By ShutterSpeed in forum Photography Beginners' Forum
    Last Post: 12-10-2008, 01:34 PM
  3. Aspect ratio of 35mm film
    By Hair Bear in forum Film Discussion and Q & A
    Last Post: 10-16-2006, 03:42 PM
  4. Ideal aspect Ratio
    By halwyman in forum Photographic Discussions
    Last Post: 03-08-2006, 04:20 PM
  5. Explaining aspect ratio...
    By Artemis in forum Beyond the Basics
    Last Post: 12-21-2005, 02:39 PM
16:9 vs 3:2
3:2 or 16:9
3:2 vs 16:9
aspect ratio 3 2 or 16 9
aspect ratio 3.2 or 16.9
aspect ratio 3.2 vs 16.9
aspect ratio 3:2 or 16:9
is 4 3 or 16 9 tips taking better photos
