Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2008
    Is this heaven?
    Posts
    62
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Using Gels to Light Background
    I am needing advice on using gels to create different backgrounds. I understand that black or dark grey works the best. Is it best to use seamless paper? Would it work on the muslin backdrops? I envision that it might look cool with the crinkle looking muslin backdrop (I'm okay with that kind of wrinkle). Any opinions?
    Also, I am using strobe lights. I can find all kinds of info on using gels with flashes, but not much on strobes. Any advice there?
    I will be using this in my new studio. However, the first use will be at a preschool shooting "school" pics. Is there a way to set up the strobe so that I can change the gels quickly?
    PS. Anyone thinking of shooting preschool pics should think twice on how sane they are!
  2. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,419
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1655 times
    You can use gels to light anything. Sometimes you use them to add color, sometimes you use them to balance your lights with an existing light.
    (by strobe, do you mean studio lights?)
    Pretty much the same. You put the gel in front of the light...although, you will need a much larger sheet to cover a studio light than a hot-shoe flash unit. Also, you have to be careful about heat. You don't want to melt you gels.
    There are many ways to attach the gel to the light. If you have a typical reflector dish, you can just clip the sheet to the edge of it. Also, many light companies have accessories that allow you to slide the sheet right in. Or, if you have gels that are mounted, they can go right into the proper holder.
  3. #3
    Mr. Rain Cloud
    Join Date
    Jul 2009
    USA
    Posts
    27,563
    My Gallery
    (0)
    Liked
    9183 times
    One bit of advice is that dark, charcoal gray eamless paper or muslin works quite well with a gelled backlight. Black paper also works well, and tends to create a darker, more-saturated looking background color at the same,exact watt-second output.
    One danger is having excessive bounce-back of gelled lighting hitting the neck and hair areas of the subject,which is worse on paper than it is on muslin or canvas backgrounds; paper tends to reflect the light a bit more than fabric. Shooting a gel onto a light gray background can cause a pretty fair amount of blowback lighting or "wrap" on your subject. To minimize the chance of that,try using a reasonably low power output on the background light,especially if using light-colored gels in the pink or yellow families--those blow back very easily!
    Black seamless paper works very well with darker hued gels like purple, blue,and red. Interestingly, I have some purple-looking gels that, on digital, produce a very deep BLUE color in the final result, but looking at the gel in regular light, it looks purple to my eyes.
    You can try angling the backlight upward at 30-40 degrees, which will produce a graduated color backdrop,lighter in the middle, darker at the top and top corners of the frame. A pink gel fired onto a brown Old Masters canvas can look nice too.
  4. #4
    Join Date
    Oct 2008
    Is this heaven?
    Posts
    62
    My Gallery
    (0)
    Liked
    0 times
    Yep. Sorry, I do mean studio lights.
    Have you ever used gels on the wrinkle kind of muslin?
    Derrel, I think I read a post where you indicated that you've done school type pics? If so, how important is it that I offer a variety of background choices? I was thinking of getting a background with blues & browns, but if I could get something like black that I might actually use more -- then I'm all for that. I just don't want to use black as the background for preschoolers.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Background light
    By plastii in forum Beyond the Basics
    Last Post: 04-01-2010, 07:59 AM
  2. Heron late light with dark background
    By randallone in forum Nature & Wildlife
    Last Post: 12-17-2009, 03:07 PM
  3. Using Gels to Create Background Colors
    By chrisburke in forum Photography Beginners' Forum
    Last Post: 01-19-2009, 08:37 AM
  4. Photographing dark objects in a light background
    By keller in forum Beyond the Basics
    Last Post: 12-11-2005, 04:43 AM
  5. Color Gels, Background Colors
    By LAB in forum Beyond the Basics
    Last Post: 09-05-2005, 07:00 PM
attaching gels to lights
creating cool backgrounds with strobes in photographs
how to attach gels to lights
lighting up the background with gels for a picture
putting gel on studio strobes
shooting with gels
what background color to use with a strobe light
what color blue gel do i use when i want to change the backround color
