Results 1 to 6 of 6
  1. #1
    Join Date
    Aug 2009
    New Website Is Up!
    Posts
    210
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Cheap One Light Set-Up Review (Mainly for Outdoor Fill)
    I'm looking to piece together a cheap, simple set-up for (primarily) outdoor portrait shoots. Basically, the main concern is being able to fill in some shadows when I am shooting. It'd also be nice to be able to shoot some basic night/dusk stuff, but it's not essential.
    I'm looking to spend as little as possible at the moment. I'm thinking the following set-up could work for around $200. Please let me know your thoughts. I shoot a 50D, FWIW.
    Vivitar 285HV (Possibly with home-brew battery pack down the line.) - $90
    Cactus V4 Triggers - $40
    Westcott 7' Stand - $30
    60" Umbrella - $40
    Flash/Umbrella Bracket - $15
    That puts me at <$250 shipped. Worth going for? Some shots from my recent shoot seriously needed some fill light, so it's time to make a move. A 70-200/2.8 is most important on my agenda, so spending serious money on a little lighting rig isn't possible right now.
    Insight appreciated.
    Check out my work @ Tampa Family Photography!
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    TPF Junkie!
    Join Date
    Mar 2008
    Posts
    6,878
    My Gallery
    (0)
    Liked
    328 times
    It'll work nicely for a fill, just keep in mind if you're outside that you're going to have to get the flash close.
    My name is Will. You may call me Will.
    -Will
    Slough Roast Blog
    Capitol Sound Blog
  4. #3
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    Liked
    1202 times
    Technically, fill light doesn't need to be off-camera. It's purpose is to give a base amount of light to the scene/subject and it can do that from the same angle as the camera.
    Your main/key light should be off-camera, because that is the light that casts shadows and gives your subject some depth.
    Of course, when you have an off-camera light you can use it as a main light as well, using the ambient light for fill.
    Also, one of the best things for outdoor fill light is a reflector. With a reflector you don't have to worry about figuring the flash power and you don't have to limit your shutter speed to the max sync speed.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  5. #4
    Join Date
    Jul 2009
    NYC
    Posts
    687
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    1 times
    you should check the strobist kits at mpex... prob everything you need in one little discounted package..
    Strobist Starving Student SC1 Lighting Kit
  6. #5
    Join Date
    Dec 2008
    Waunakee, WI
    Posts
    684
    My Gallery
    (0)
    Liked
    0 times
    You are trying to attract customers and you want to skimp on lighting equipment?
    I can appreciate your enthusiasm but, don't agree with this line of thinking for building a business.
    What if you're doing your "free portrait sessions" and one of these items becomes unreliable or breaks on you? People will be cranky, and it's a free session. Imagine what they'd think if they were paying you.
    Skimping on lighting because you need the $ for a good lens means that you're rushing into this venture not fully prepared.
    Bill
    Nikon D300 / 18-55 VR / 70-300 VR / 50mm 1.4G / 35mm 1.8G / SB-900 / CYBERSYNCS
    D300s>D700
  7. #6
    TPF Junkie!
    Join Date
    Jul 2009
    USA
    Posts
    19,184
    My Gallery
    (0)
    Liked
    4732 times
    My main concern is the light-duty light stand you are considering--it's simply too lightweight,and designed for indoor use. You need to have a light stand that can handle uneven ground, so a C-style light stand with a sliding leg like this one is close to the absolute ideal basic stand for location work
    Avenger | A2033L Century C Stand with Sliding Leg - | A2033L
    This type of C-style stand (also sometimes referred to as a turtle base stand) is also a lot heavier than an inexpensive aluminum studio stand,and will need MUCH less sandbag weight (if any) to keep it stable in the breeze. Outdoors, studio-oriented stands with lightweight aluminum bases and lightweight aluminum columns simply blow over in the breeze because they are too narrow in footprint,and simply are too light. I would encourage you to look at C-style stands from Matthews or Avenger because besides being good outdoors, they ALSO can support a 36x48 inch softbox and studio flash head in areas where there is not room,or time, to set up a boom stand with counterweight. The heavy STEEL lower bases and columns make these stands very bottom-heavy,and very safe,very stable, and long-lasting.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. First try outdoor portraits with fill flash
    By YoMoe in forum People Photography
    Last Post: 04-19-2010, 05:16 PM
  2. Outdoor Portrait-1st attempt with fill flash
    By PixiePix in forum People Photography
    Last Post: 07-21-2009, 06:37 PM
  3. Outdoor lighting and fill flash?
    By rockangelphotography in forum Photography Beginners' Forum
    Last Post: 01-17-2009, 12:25 PM
  4. Fill Light
    By mandabec in forum Photography Beginners' Forum
    Last Post: 03-19-2008, 02:07 PM
  5. Butterfly w/ fill light
    By TCimages in forum Nature & Wildlife
    Last Post: 03-17-2008, 02:26 AM
basic outdoor photography setup
cheap lighting for outdoor photography
fill light cheaply outside
how to set up for an outdoor photography shoot
how to shoot outdoor fill light photography
inexpensive fill light equipment for photography
lights setup in outdoor photography
one light outdoor photography
one light set up, outside, photography
one light setup outdoor
outdoor 1 light setup
outdoor fill light flash
setting up an outdoor photo studio
setting up lights outside for photo shoot
two light photography setup outdoor
