Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
  1. #1
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    3,004
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    155 times
    Lightbulb Topic #3, Layers & Post Processing
    Alright so I thought I would do something focused on post processing. Now, there are quite a few different ways to do what I'm about to demonstrate, I just happen to prefer this method and find it goes pretty quickly.
    The software I will be using for this is:
    Topaz ReMask - Masking Made Easy
    Topaz Adjust - Redefining Creative Exposure
    Topaz Detail - Halo-free Detail Enhancement, Sharpening, and Toning
    *Free 30day trial of the bundle is highly recommended
    PS Elements 6
    Adobe Photoshop Elements - PC - CD-ROM ( mini-box ) - Universal English
    So lets get started, here is the original photo I will be tweaking (random choice):
    This was a RAW file, just to be clear.
    So with this photo, you'll notice the sky is blown, most likely a result of trying to properly expose the foreground, or brickwork that had it's back to the setting sun.
    The bricks/foundation are dull and the green middle ground is also lifeless and boring, so we'll try and break it all up and add some life back to it.
    First thing we do is open the original in PSE. It will open in Camera raw 4.6, once open you will be able to adjust the photo like you normally would, but we're going to do something different this time.
    -Go ahead and select Camera Neutral under the Camera profile tab.
    -Go back to basic and adjust your settings to enhance the sky. I was something like -1.45 exposure, +38 brightness, +56 contrast, +100 clarity, +49 Vibrance, +44 saturation.. Basically just adjust it until the sky looks good to you.
    --Once that is done you are going to Save Image (bottom left) as a .dng file onto your desktop. This will save your sky that you can open later.
    Sky image:
    -Next you will reset what you did by hitting "default".
    -After that you will adjust the photo for the brick and mountains, disregarding the sky. Don't go to crazy here, just get it decent looking.
    -Now open the the image into PSE editor.
    -Once you have the the image opened into PSE, hit CTRL+J twice to create two copies (make sure your layers tab is open on the right).
    -With the top copy selected, open REmask 2.
    -Now use the Remask tool to separate the sky from the mountains. You'll simply trace the mountain line and chimney with the BLUE pen and then use the red paint can on the sky side and hit process. If you get stuck, just ask about it later and I'll go in greater depth.
    -Now you'll end up with this in your layers
    Blank background:
    -Now you'll have one layer with no sky and two full photo layers. Take the other layer and do the same thing except outline the bricks and then open it.
    -Next you'll need to bring back that sky we created earlier, so just hit "create new layer" and a blank layer will pop up.
    -Now select your layer, then go to file "place", and place your sky file onto that layer.
    -At this point your Layers should look like this:
    (You'll want the sky on the bottom)
    -Now is when I will go in and adjust each layer individually using Adjust 3. I will also adjust the levels (Ctrl+L) and Saturation of individual colors; green most notably in this one (Ctrl+U).
    -I used the "clone" tool to get rid of that random branch in the sky. I use a fairly small brush when doing it, and zoom in pretty far to get a good idea of what texture I am adding. You'll have to play/blend it a bit depending on your photo.
    -Then I used Topaz Detail on the sky, and the stone layers to give them some pop.
    -Then I used Denoise on the sky and the mountain layer.
    -After all the layers looked acceptable to me, and I had done all the editing, I simply flattened the image resulting in this:
    vs Original
    --This can be done with almost anything. You'll find some photos are more labor intensive when it comes to masking them (tree's that show sky through them are notorious for being difficult). But in the end it just takes a tad bit more time, but it all can be done.
    -You can use this technique for "Selective coloring" as well.
    Hope this helps, makes sense, and adds some new techniques to someones skill box. Let me know if you have any questions or get stuck...
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Feb 2010
    Posts
    33
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Omg do you need a roommate or something?? awesome tutorial !! Thanks!!
  4. #3
    Join Date
    Nov 2009
    Tacoma, WA
    Posts
    448
    My Gallery
    (0)
    Liked
    4 times
    Quote Originally Posted by kangta13 View Post
    You can't figure out layers either huh?
    Thanks for this post. So much has been done on the actual camera work but little has been posted about the PP. This makes it easier to understand rather than just watching Youtube videos.
  5. #4
    Join Date
    Feb 2010
    Posts
    33
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by indeedies View Post
    i understood layers having used cs3/photoshop a while back when making logos.. never knew the extent in photography with saturating/exposure separation.. it really is sweet what can be done.. almost like you don't need to take a good picture anymore HOW SAD.. ..
  6. #5
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    3,004
    My Gallery
    (0)
    Liked
    155 times
    No problem.... Give it a try sometime and let me know if you have any issues, I might be able to address.
    This setup I am using is probably less then $60 out the door (if you're ont he free trial of Topaz). So it isn't very expensive to PP.
  7. #6
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,649
    My Gallery
    (0)
    Liked
    43 times
    dude, i was away for two hours and you put this up... AWESOME,
    KEEP IT UP
  8. #7
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    3,004
    My Gallery
    (0)
    Liked
    155 times
    Had to do something while watching TV
  9. #8
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    3,004
    My Gallery
    (0)
    Liked
    155 times
    I would also like to put it out there that if someone wants help with a photo and shot it in raw, they can upload it and link it here and I'll try and break it up in layers and give it back. NOW don't go putting up a forest shot and expect the professional touch, just sayin (that s#it is labor intensive).
  10. #9
    Join Date
    Aug 2009
    Columbus, OH
    Posts
    370
    My Gallery
    (0)
    Liked
    4 times
    wow, very informative! thank you very much Dominantly. I'm going to have to try this soon
  11. #10
    Join Date
    Feb 2010
    Posts
    33
    My Gallery
    (0)
    Liked
    0 times
    :D
    Quote Originally Posted by Dominantly View Post
    btw nice photo blog dominant, very interesting captures.. haha do you have an editing service?? omg you would make my life so much easier..!
  12. #11
    TPF Junkie!
    Join Date
    Jul 2009
    NYC
    Posts
    2,649
    My Gallery
    (0)
    Liked
    43 times
    dont offer if ya'll can't hack it LOL
  13. #12
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    3,004
    My Gallery
    (0)
    Liked
    155 times
    Thanks I appreciate it! It's a PIA in progress
    Nope no editing service here, I've done something similar though.
  14. #13
    TPF Junkie!
    Join Date
    Jul 2009
    San Diego, CA (RB)
    Posts
    3,004
    My Gallery
    (0)
    Liked
    155 times
    Quote Originally Posted by IgsEMT View Post
    I thought I would put it out there just in case....
  15. #14
    TPF Junkie!
    Join Date
    Jun 2009
    British Columbia
    Posts
    2,635
    My Gallery
    (0)
    Liked
    221 times
    Thanks for that, really useful. Couple of queestions:
    - When you said " simply flattened the image resulting in this" can you explain what you meant by flattening?
    -What exactly is a .dng and why do you need to save it as that type rather than a .jpg? Can you not place a .jpg into a layer? (I would just try this but I'm at work at the moment so I can't).
    Cheers!
  16. #15
    Join Date
    Aug 2009
    Columbus, OH
    Posts
    370
    My Gallery
    (0)
    Liked
    4 times
    Quote Originally Posted by fokker View Post
    I believe that is referring to combining the layers into one; it is an option in Photoshop (Layers -> Flatten Image).
    .dng stands for Digital Negative; Adobe's answer to Canon's RAW.
    I'll let Dominantly field that one, though I imagine for the same reason RAW is preferred over JPEG in other situations?
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Tried something new with my post-processing.
    By ghache in forum Photography Beginners' Forum
    Last Post: 11-23-2010, 04:26 PM
  2. Post Processing
    By dbird in forum Photography Beginners' Forum
    Last Post: 10-28-2009, 08:44 AM
  3. How much post processing is too much? (long post disclaimer)
    By BuZzZeRkEr in forum Photographic Discussions
    Last Post: 09-20-2009, 04:54 PM
  4. How much Post-Processing?
    By gabrielh in forum Digital Discussion & Q&A
    Last Post: 12-27-2008, 08:46 AM
.dng images
how to use layers for post processing
layers and post processing
layers and post-processing
layers in post-processing ?software
layers the photo forum
photo processing layers
post processing layers
post processing layers in elements
topaz help for beginners, place on another layer
