Results 1 to 15 of 42
Thread: What MODE are you shooting?
10-25-2010, 12:05 PM #1TPF Junkie!
- Join Date
- Nov 2008
- Location
- In between her...
- Posts
- 2,583
- My Gallery
- (0)
- My Photos Are NOT OK to Edit
- Liked
- 11 times
I have always shot in M since day one but what's everyone's fav mode?
The reason I like M mode is just because I have control over it all and I also like the fact I like looking at the light meter in the bottom of the screen to show exposure.
I know a lot of people just swear by AV and P mode. What's your thoughts?Canon 1D mk IV | 5D mk II | T1i (500D) | 35 1.4L | 16-35 2.8L | 24-105 4L | 70-200 2.8L II | Siggy 85mm 1.4 | Couple Canon 580EX | Other random ****s that help me with my mediocre photography.
"Avedon sucked, Karsh sucked, Adam sucked, Mary Ellen sucked, Cowart sucked, Jarvis sucked. Every photographer in all of history was a horrible photographer for some period of time. They learned, they grew, they had dark days, they persevered. - Zack Arias
10-25-2010 12:05 PM # ADS
10-25-2010, 12:13 PM #2TPF Junkie!
- Join Date
- Mar 2010
- Location
- Southern Alberta
- Posts
- 2,656
- My Gallery
- (0)
- My Photos Are OK to Edit
- Liked
- 179 times
I bounce back between A and M. Or S & M.
If I don't like the look I get I switch to M and adjust to get the tone/feel I want.
Dee
Nikon D700 & D90 w/lenses and various other crap.
My Photography Blog
updated every now & then.
myflickr
10-25-2010, 12:14 PM #3TPF Junkie!
- Join Date
- Oct 2010
- Location
- The Goondocks
- Posts
- 1,683
- My Gallery
- (0)
- Liked
- 203 times
This subject is getting old. It doesnt matter. Each setting has its pros and cons, one just needs to know when its beneficial to use them. In most cases the only time manual is needed is when using flash, or going for artistic flair like blurred motion. In most any other case you are just wasting your time as well as possibly your clients.
We get it, you have a 5D and shoot manual, let it go already.
relax, I'm just kidding with you.
10-25-2010, 12:15 PM #4
Aperture priority most of the time and manual if needed. For example, flash(es) shots and consistency.
10-25-2010, 12:17 PM #5TPF Junkie!
- Join Date
- Oct 2010
- Location
- The Goondocks
- Posts
- 1,683
- My Gallery
- (0)
- Liked
- 203 times
Also, dont forget that in Av and Tv modes you have exposure comp which can in most cases, make a switch manual mode all the more pointless.
10-25-2010, 12:17 PM #6TPF Junkie!
- Join Date
- Nov 2008
- Location
- In between her...
- Posts
- 2,583
- My Gallery
- (0)
- Liked
- 11 times
Nothing to do w/ my camera. I am speaking in general. I wanted to know if I should shoot in a different mode for weddings or just stick to what I've been doing so I don't ahve to learn new things? With M mode, I can set the apature to a certain spot and the ISO but it gives me the control to change shutter speed and my exposure changes which shows in the bottom of my screen allowing me to know what to shoot to get it to perfect 0 exposure
10-25-2010, 12:18 PM #7TPF Junkie!
- Join Date
- Feb 2010
- Location
- New Orleans, LA
- Posts
- 2,151
- My Gallery
- (0)
- Liked
- 262 times
Aperture Mode 90% of time. Manual for the times I want to overexpose/underexpose a certain image to get the shot I want.
10-25-2010, 12:19 PM #8I spend too much of my life on TPF!
- Join Date
- Mar 2010
- Location
- New Jersey
- Posts
- 667
- My Gallery
- (0)
- Liked
- 1 times
I shoot mostly aperture priority then manual next.
Buying a Nikon doesn't make you a photographer. It makes you a Nikon owner. ~Author Unknown
10-25-2010, 12:24 PM #9TPF Junkie!
- Join Date
- Feb 2010
- Location
- Ohio
- Posts
- 2,410
- My Gallery
- (0)
- Liked
- 64 times
Tv when panning, Av when lazy, M when using off-camera flash (since my flashes don't TTL)
But there are exceptions.
I'd use Av for weddings.. maybe change the exposure compensation depending on your result. This way you can focus on 'getting the shot' rather than getting the settings right. Your camera handles high ISO well (you've bragged about and demonstrated that to us enough) so you could leave it up around 800, that way you'll have a nice quick shutter speed when using Av with a telephoto lens.-Paul
Sigma 1.4x Teleconverter for sale!
"rebal" T2i
my amateurish flickr
my mm retouch port/gallery
10-25-2010, 12:25 PM #10
10-25-2010, 12:35 PM #11TPF Junkie!
- Join Date
- Oct 2010
- Location
- The Goondocks
- Posts
- 1,683
- My Gallery
- (0)
- Liked
- 203 times
I was just kidding with you. Everything you just said can be done in Av mode. If you want to control DOF use Av, if shooting action use Tv to control the amount of stopaction or blur you want. The camera sets the other parameter which saves you time. If you cant go fast enough, bump up the ISO. If you need 1/250 of a second for sports, your aperture for proper exposure is what it is, whether you set it or your camera sets it, unless you want a jacked exposure.
10-25-2010, 12:39 PM #12TPF Junkie!
- Join Date
- Nov 2008
- Location
- In between her...
- Posts
- 2,583
- My Gallery
- (0)
- Liked
- 11 times
Yeah that makes sense. I guess I could put center weight and shoot that way and if I use flash, it won't matter much anyway since AV will mostly focus on background
10-25-2010, 12:45 PM #13TPF Junkie!
- Join Date
- Jul 2010
- Location
- Japan
- Posts
- 1,128
- My Gallery
- (5)
- Liked
- 18 times
Manual is mostly good for shots where you have plenty of setup time, like landscapes or studio portraits. To try and use it for changing lighting conditions in sports for example is far from ideal.
That being said, if your camera has auto-Iso Manual is given additional flexibility and can be used effectively for almost all types of shooting.
Recently I have found that using Manual and setting a shutter of 1/200th or 1/250th along with the desired aperture (for a given lens) works well for keeping up with my 2yr old son.
I can set f/2.8 + 1/250th for example and then let auto Iso take over from there to ensure the proper exposure. This ensures that I am not getting changing shutter speeds that might result in subject blur.
For this to work though the shots have to be on the side of underexposure, because the Iso can only go up and not down from 100. One way to quickly fix this while staying in manual though is to increase shutter speed as needed.
So this is my preferred method for low light, and its not that ideal for outside bright daylight...
For bright daylight I would normally use Ap and set for the desired aperture for the attached lens (2.8, 1.8, etc.) and set manual Iso-100.
This way the shutter speed can scale to what is needed for the proper exposure, while ensuring that I get the DOF and subject isolation that I desire.
Av mode has its uses as well no doubt; I just don’t use it that often.
Basically its best to use the ideal mode for a given situation, they are all good in their own ways and have their specific uses.
- NeilEOS 7D / EOS 1v / 70-200mm 2.8L IS II / 85mm 1.2L II / 35mm 1.4L / 17-55mm 2.8 / 10-22mm 3.5-4.5 / 580EX / CS5 + LR3
10-25-2010, 12:48 PM #14I spend too much of my life on TPF!
- Join Date
- Aug 2010
- Location
- Olive Hill, Ky
- Posts
- 560
- My Gallery
- (0)
- Liked
- 2 times
I use AP most of the time. Like most others, I only use manual when I need something specific. For weddings I would for sure use Av or Tv if I were you. There's no point in missing moments and shots while you're fiddling with the your setting to get the exposure right when there is a mode that will do it for you with no problems in those conditions.
10-25-2010, 12:53 PM #15TPF Junkie!
- Join Date
- Feb 2010
- Location
- Tempe, Arizona
- Posts
- 2,408
- My Gallery
- (0)
- Liked
- 19 times
Aperture Priority most of the time, then Manual .
Learn as if you were going to live forever; Live as if you were going to die tomorrow.
|My WEBSITE |Twitter | Blog| FACEBOOK|
Similar Threads
How do you calculate shooting in bulb mode?!
By sam_justice in forum Photography Beginners' ForumReplies: 21Last Post: 10-04-2010, 12:56 PM -
So I started shooting in AV mode... (+1 for C&C)
By Raizels in forum Photography Beginners' ForumReplies: 24Last Post: 09-20-2010, 03:26 PM -
What Shooting Mode Do You Use ?
By tkaat in forum Photography Beginners' ForumReplies: 108Last Post: 07-14-2008, 07:07 AM -
Shooting mode; RAW vs. jpeg
By NM Rich in forum Photography Beginners' ForumReplies: 19Last Post: 03-05-2008, 02:22 PM -
Camera won't stay on in shooting mode
By cindyg2024 in forum Photography Equipment & ProductsReplies: 3Last Post: 10-31-2007, 07:42 PM
av mode for shooting wedding?
,shooting in av mode
LinkBack URL
About LinkBacks
