Results 1 to 9 of 9
  1. #1
    Join Date
    Nov 2010
    Spain
    Posts
    44
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Question Help: How to avoid too much light on these photos?
    Hi. I took these two photos in the morning. The sun was already shining hard and I had to take the photos at an angle of 15-20 degrees from the sun (I mean, the sun was almost in front of me). One of the problems I have in my outdoor photos is excess of light; I've been reading for a while about exposure and such so I think I know how to correct the problem, but every time I try I end up with a dark photo
    I used my Canon T2i and the 18-55 lens kit for these and in both of them I corrected color levels using the "auto" button. Originally they looked even worse
    Well; this is image #1. Here are the camera settings:
    WB: Auto
    Aperture: F7.1
    Shutter speed: 1/15
    ISO: 100
    Program: M
    Focal length: 28mm
    And this is #2. The settings are:
    WB: Auto
    Aperture: F7.1
    Shutter speed: 1/8
    ISO: 100
    Program: M
    Focal length: 41mm
    I realize that, apart from other mistakes, I should have chosen a higher aperture number so that everything in the background would be on focus (especially the houses on the right).
    So the question is: how would you have avoided the "sun" problem here?
    Thanks.
  2. #2
    Join Date
    Nov 2009
    Valley Forge, PA
    Posts
    773
    My Gallery
    (0)
    Liked
    3 times
    An ND filter would help with that but its still not a very good time of day to shoot.
    Gear:
    Nikon D40|18-55mm AF-S|55-200mm AF-S VR|35mm AF-S f/1.8
    Pro
    My Flickr
  3. #3
    Join Date
    Aug 2009
    Kitchener ON
    Posts
    449
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    5 times
    try a polarized filter. Will cut out a lot of the stray light
    [Canon EOS 5D MKII ] [Canon EOS 3000N (film)]
    [Sigma 24-70 2.8]
    [Canon 430EX II]
    [Promaster flash triggers] [Canon shutter trigger]
    [Pelican 1500] [LowePro SlingShot 200 AW]
    photosandfrustrations (unlinked)
    Flickr (unlinked)
    Edit with: GIMP, Photoshop CS5, Lightroom 3.4.1
  4. #4
    KmH
    KmH is offline
    Helping photographers learn to fish
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    33,535
    My Gallery
    (1)
    Liked
    3909 times
    Your camera has 4 light metering modes to choose from: Spot, Center-weighted, Partial and Evaluative.
    Which of them did you use to snap each of the images you posted?
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    Effort equals results - Roger Penske
  5. #5
    Join Date
    Nov 2010
    Spain
    Posts
    44
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by KmH View Post
    Spot metering for all of them.
    Thanks
  6. #6
    Join Date
    Aug 2010
    Saint Louis MO
    Posts
    767
    My Gallery
    (0)
    Liked
    87 times
    Quote Originally Posted by aaneiros View Post
    Thanks.
    Both of the photos you've shown are basically backlit. The sun has crossed over a 180 degree line perpendicular to your lens. Backlighting raises the overall tone range of the scene (increases contrast). Backlighting can and often does raise the contrast too much.
    The highlights in your photos are already overexposed so more exposure isn't going to improve things.
    Less exposure will make the shadows in your photos much darker and they are already dark enough so less exposure isn't going to help.
    The exposure you've already made is unsatisfactory and if more exposure would be bad and less exposure would be bad that leaves you with just one answer to your question. Avoid the problem by not taking the photo. I'm not trying to sound flippant here. The answer is that there are frequent lighting conditions that just aren't going to work. Learn to see them and avoid them and use your time more profitably on what will work.
    P.S. There are some extreme technical methods that can be brought to bear on lighting conditions like this -- they require skill and time and equipment and software. HDR would be one. The photo has to be worth the trouble.
    Joe
  7. #7
    TPF Junkie!
    Join Date
    Jan 2010
    Cincinnati, Ohio
    Posts
    1,853
    My Gallery
    (0)
    Liked
    206 times
    Quote Originally Posted by clanthar View Post
    Joe
    Meter the sky, note your settings. Meter the foreground, note your settings. Compose the shot using a tripod. Set for a proper sky exposure, take it. Set for a proper foreground exposure, take it.
    Move the files onto your computer and a simple stitch of the two will yield a nice photograph.
    You have sort of complicated it by adding reflective water into the frame, but it still can be done with minimal PP skills.
    Dominatly wrote up a how to on this very action a while back- maybe he will repost it for you, it goes much more in depth than my directions.
    p!nK
    I look at every photograph I take with this quote in mind.....
    Don't despair, your mother still loves you.
    Don't be too proud, she has to.
    I'm FX'y and I know it.....
  8. #8
    TPF Junkie!
    Join Date
    Mar 2010
    Posts
    1,131
    My Gallery
    (0)
    Liked
    7 times
    Shoot in Av instead of M and keep your shutter above your focal length; i.e., 50mm, use 1/60.
    *poof* these issues go away.
    Your camera settings lead me to believe these photos were overexposed.
    destroyer | Canon 1 megadickle FF-S BLAHBLAHBLAH 85-2000000 mm LoL | plastic is fantastic
    < I shoot in Awesome Mode only >
    Is my bokeh okay?
  9. #9
    Join Date
    Aug 2010
    Saint Louis MO
    Posts
    767
    My Gallery
    (0)
    Liked
    87 times
    Quote Originally Posted by white View Post
    Here's the histogram for the OP's first photo:
    As you can see the highlights are already completely blown. However with 90% of the tonal information below the midpoint this photo is clearly underexposed. The shadows are OK now, but they've started to block and so any reduction in exposure would quickly begin to cause trouble.
    This photo really needs a big reduction in exposure to correct the blown highlights while at the same time keeping the shadow exposure where it is and/or even increasing exposure a little for the midtones.
    I didn't know AV mode could both decrease and increase exposure simultaneously -- how's that work?
    Joe
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. how to use a photo light to avoid shadows
    By edadmartin in forum Photography Beginners' Forum
    Last Post: 02-09-2011, 10:33 AM
  2. What is this? How to avoid it?
    By bluetibby1 in forum Photography Beginners' Forum
    Last Post: 01-03-2011, 04:49 PM
  3. How to avoid the fog..
    By albo in forum Beyond the Basics
    Last Post: 01-13-2006, 11:06 AM
  4. How to avoid the fog..
    By albo in forum Photographic Discussions
  5. To avoid confusion!
    By Chase in forum Off Topic Chat
    Last Post: 11-20-2003, 12:28 AM
my pictures have too much light
photographic histogram
too much brightness in camera photo
too much light in photo
too much light in pictures
too much sunlight photo
too much sunlight photography
why are my photos too light
