Results 1 to 5 of 5
  1. #1
    TPF Junkie!
    Join Date
    Oct 2009
    Riverview, New Brunswick, Canada.
    Posts
    2,345
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    82 times
    Radio Trigger question...
    I have a buyer for my Washburn bass, which means I will soon have some disposeable income.
    My plan WAS to buy a Pocket Wizard for my 50D in an effort to bypass the sync cord.
    ie. Pocket Wizard transceiver on the camera would trigger my Bowens Gemini monolights via the built in photocell/slave cell on my lights.
    But, I was informed that I would need to buy 2... Because the Bowens Gemini monolights won't fire without a sync cord... or a connection between 2 Pocket Wizards.
    So I would need a Pocket Wizard on my camera and one connected to one of the monolights??? Even though they have built in slave cells???
    I need to know whether or not I will have to buy 2...
    BuS_RiDeR aka Mark
    Canon EOS 50D
    Canon EF 50mm f/1.8 II
    Canon EF-S 17-85mm f/4.0-5.6 USM IS
    Canon EF 75-300mm f/4.0-5.6 III
    PP courtesy of the Gimp!
    My photography Blog
  2. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,490
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1679 times
    I don't know about your specific lights. But with most (probably all) studio lights...when they say that have a built-in slave cell...it means that the light will trigger when it senses another flash/strobe fire.
    In other words, it's not a receiver for your Pocket Wizard...it's a receiver for any flash. So if you do want to use a radio trigger like the PW, you will indeed need two units...one on the camera and one on the light. You only need to have a receiver on one light, because the others will be triggered via their built-in slave cell.
    So yes...you could just use a flash on the camera, to trigger the lights. You would have to make sure that the flash doesn't use a pre-flash (E-TTL uses a pre-flash). And of course, using a flash to trigger your lights, will affect the light in your scene...which is one reason why most photographers don't use an on-camera flash to trigger their lights.
    If you don't need the reliability of the PW units. You could buy a $40 wireless flash trigger. Or if you don't need the range of the PW (1600 feet), you could get something like the Cyber Sync from Alien Bee (that's what I use).
  3. #3
    TPF Junkie!
    Join Date
    Oct 2009
    Posts
    2,345
    My Gallery
    (0)
    Liked
    82 times
    Quote Originally Posted by Big Mike View Post
    Thank you for the response. This does make sense. Although I was hoping that the built in cell would be able to "see" the signal from the PW. Wishful thinking on my part I guess.
    The OCF option is not really something I want... So I guess I'll have to wait until I can afford two PWs...
    On a similar note... Is anyone familiar with the Cactus radio triggers? My local camera shop stocks them, but I don't know how good/bad they are.
    BuS_RiDeR aka Mark
    Canon EOS 50D
    My photography Blog
  4. #4
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    33,490
    My Gallery
    (111)
    Liked
    1679 times
    Those are the $40 flash triggers I was referring to.
    Gadget Infinity :: Digital Camera :: Flash Trigger :: Wireless Trigger :: Cactus Wireless Flash Trigger Set V4
    They are essentially the exact same thing as the PW Plus II units. They send a radio signal from one unit to another, which tells the flash/strobe to fire. You could use either the PW or the Cactus for OCF for studio work.
    The practical difference is that the PW is a high quality unit that is made to be reliable and has a very high range. Also, the PW Plus II is a 'transceiver'...so the unit can send or receive...meaning that you don't have to pick the right on to put on the camera or on the strobe. With the cheaper ones...there is a specific sending unit and a specific receiving unit...but this in itself, is not worth the huge price difference.
    I have some of the older, cheaper Cactus units. like THIS and they do work...but they were not consistent enough for professional work. That's why I went with the Cyber Syncs instead. I use them both for triggering my studio lights and for triggering off-camera-flashes.
  5. #5
    TPF Junkie!
    Join Date
    Oct 2008
    Chesterfield UK
    Posts
    13,106
    My Gallery
    (0)
    Liked
    2047 times
    The built in trigger start in the classic monolight the series above the ones you have so you will need 2 or you could get the Pulsar trigger by Bowens, i use these Twin-Link Remote Flash Triggers
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. What radio trigger should i buy?
    By Misfitlimp in forum Photography Beginners' Forum
    Last Post: 07-15-2009, 06:07 PM
  2. Radio trigger/D50 problem!
    By rabhobbes in forum Beyond the Basics
    Last Post: 05-25-2009, 04:30 PM
  3. Ebay radio trigger problems
    By joey-cakes in forum Photography Equipment & Products
    Last Post: 05-10-2008, 12:36 PM
  4. Ebay Radio Trigger/Recievers Question
    By Deadeye008 in forum Photography Equipment & Products
    Last Post: 10-28-2007, 07:02 PM
  5. Wireless Flash Radio Trigger?
    By guitarmy in forum Photography Equipment & Products
    Last Post: 01-05-2007, 11:27 PM
bowens gemini pocket wizard
bowens lighting one won't trigger
bowens monolight work with 2 receivers
bowens pocket wizard radio
triggering monolights from bowen pulsar
using wireless trigger, will it send a preflash radio signal
what is a built in slave cell
why wont both my bowens strobes flash
