Results 1 to 3 of 3
  1. #1
    Join Date
    Jan 2007
    Posts
    95
    My Gallery
    (0)
    Liked
    0 times
    resolution/printing question...
    a friend shot a photo and the specs are as follows:
    width 3504 pixels
    height 2336 pixels
    48.667 inches
    32.444 inches
    72 pixels/inch
    how do i crop/convert this landscape photo to a portrait 8x10? normally what i would do is create an 8x10 canvas in photoshop with the same resolution, shrink down original and then cut and paste into. but my resolutions are typically 180 or 300 pixels/inch. how do i make sure i get a "high res" 8x10 from the original?
    thanks!
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1202 times
    You could do it the same way that you are used to. Create a new canvas that is 8x10 with a resolution of 300 PPI. Then just cut/paste or drag/drop your image onto the new canvas. You may need to resize it, then move it around to get your composition.
    Another option, in Photoshop, is to use the crop tool. Select the crop tool and then set the variables (usually in the top bar) to 8, 10 and 300. Then when you crop, it will become the right size and resolution for an 8x10 print.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  4. #3
    TPF Junkie!
    Join Date
    Feb 2007
    Posts
    1,698
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Those numbers are all related. Do this sum
    48.667" x 72ppi and 32.444 x 72ppi
    What do you get? 3504 x 2336 (the image size of a 20D or 30D camera
    To work out the size you need, you want to print an 8 x 10 @ 300ppi so that is 10 x 300 = 3000pixels by 8x300 = 2400pixels.
    Resize the image to this pixel dimension. Set the ppi to 300ppi (with resampling switched off) and the image size will automatically be 10x8.
    The crop tool as Mike says is also very useful.
    What software are you using?
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Resolution Question
    By RÅW in forum Photography Beginners' Forum
    Last Post: 02-07-2011, 08:48 PM
  2. A question about printing size and maximum resolution....
    By wishbone_17 in forum Digital Discussion & Q&A
    Last Post: 05-09-2009, 11:52 PM
  3. Resolution Question
    By memento in forum Photography Beginners' Forum
    Last Post: 07-19-2007, 09:11 AM
  4. Printer resolution question
    By madhatter in forum Beyond the Basics
    Last Post: 05-26-2006, 04:52 PM
  5. resolution question
    By Corry in forum Beyond the Basics
    Last Post: 02-16-2005, 02:38 PM
