+ Reply to Thread
Results 1 to 12 of 12
  1. #1
    Join Date
    May 2008
    Posts
    55
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Was planning on D80, but oh no! slow sync speed!
    I have been planning on buying a D80 in the next couple months, but just realized that it has the rather slow flash sync speed of 1/200 of a second. Will this be a problem when shooting skateboarding and snowboarding?
    I was looking at the Nikon d70s because that has a sync speed of 1/500 of a second. Any major issues with that or things where it is not as good as the D80? How big could one print from the 6.1 megapixels of the d70s?
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Jul 2007
    State of Confusion
    Posts
    11,569
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    831 times
    Good question. I don't know, but 1/200s is still pretty damn fast. Pair either one up with a SB-600 or 800 flash and you're on your way. The D80 is newer technology and a bit more robust (I think). I don't shoot boarding, but I've not had an issue with synch speed on the D80. You can probably find the D70 cheaper as well. Either one will give you great images or the opposite. If memory serves me correctly (and don't count on that), 6MPX should yield 8x10s really good, provided the source material is there to support.
    The Liver is Evil and Must Be Punished.
    Shooter of FX, DX and MFT
    I could be wrong, but I doubt it.
    Two wrongs don't make a right, but three rights make a left.
  4. #3
    TPF Junkie!
    Join Date
    Jun 2006
    Durham, UK
    Posts
    1,918
    My Gallery
    (0)
    Liked
    1 times
    For about the tenth time on this fora, your sync speed is irrelevant to stopping motion, flash/light travels at 186,000 mpsecond, it is this light that captures your exposure. Sync speed is only there to allow the shutter to fully clear the frame/sensor, use of a higher speed will produce a black band on your picture, meaning the shutter has closed during exposure, the D80/D90/D200/D300 etc will all work fine to "freeze" the action of your skate shots. In days of old flash sync was normally 1/60th sec, I even have an old bronica that synced at 1/40th and never had a blurred shot when using flash. H
  5. #4
    Join Date
    Jan 2008
    Lethbridge, Alberta, Canada
    Posts
    909
    My Gallery
    (0)
    Liked
    4 times
    Won't a slow sync speed still blur anything not lit by the strobe? You know what I mean, like dragging a shutter using rear-sync flash (Not my photo).
    Now, this isn't a bad thing and in fact it looks pretty neat, because you subject will still be frozen perfectly. But I think it should be noted.
    Browse my photos on Flickr, if you like.
    Currently a Pentaxian. Favourite lens: 100mm f2.8 Macro. I now have all the lenses I need. On to lusting over lenses I want.
  6. #5
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,308
    My Gallery
    (111)
    Liked
    802 times
    It can, yes...but 1/200 is probably fast enough to avoid that when you need to.
    The camera makes everyone a tourist in other people's reality, and eventually in one's own. - Susan Sontag
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  7. #6
    TPF Junkie!
    Join Date
    Jun 2006
    Durham, UK
    Posts
    1,918
    My Gallery
    (0)
    Liked
    1 times
    But we aren't talking about dragging the shutter, hi speed photography, bursting balloons, bullets etc does not rely on shutter speed to freeze motion, it relies on the flash which is usually triggered by sound/motion or other method, I personally did a self portrait with the shutter on bulb with the flash triggered by the object passing through a laser to capture the shot with no blur on either myself or the object, (an egg) The only time I see sync speed affecting the shot is if shooting at wide apertures which will allow more ambient light to expose the subjects that aren't lit by the flash, at 1/200 sec this sync will freeze motion of any human in the frame unless he's a terrorist who actually detonates himself as your shutter is open. H
  8. #7
    Join Date
    Jan 2008
    Posts
    909
    My Gallery
    (0)
    Liked
    4 times
    Quote Originally Posted by Flash Harry View Post
    That's exactly what I said.
  9. #8
    Join Date
    May 2008
    Middelburg, The Netherlands
    Posts
    106
    My Gallery
    (0)
    Liked
    0 times
    hate to interrupt but if the shutter speed does not stop motion but the flash does then what is the point in having a really high flash sync speed?
  10. #9
    TPF Junkie!
    Join Date
    Jun 2006
    Durham, UK
    Posts
    1,918
    My Gallery
    (0)
    Liked
    1 times
    so you can use higher iso's, wider apertures and fill flash in bright conditions over extended distances, balancing flash with ambient light without overexposing your subject, in this type of scenario the higher shutter will freeze motion as the purpose of the flash is to eliminate the shadows, (racoon eyes etc) H
  11. #10
    TPF Junkie!
    Join Date
    Jun 2006
    Durham, UK
    Posts
    1,918
    My Gallery
    (0)
    Liked
    1 times
    Oh, also, the d80 custom menu will allow FP shoot mode with certain flash guns which basically allows high speed sync up to 1/4000th sec, to answer the OP's querie regards this camera. H
  12. #11
    Join Date
    Apr 2008
    Mississauga, ON
    Posts
    881
    My Gallery
    (0)
    Liked
    0 times
    Most flashes have a highspeed sync mode that allows you to shoot up to your cameras fastest shutter speed. i believe the way it works is that it fires off multiple flashes while the shutter is open instead of just one. THINK
    40D
    EF 24-105 F/4L
    EF 50mm F/1.8
    EF 100 mm F/2.8 Macro
    Speedlite 430EX
    Stand in the thrall of My Tidal Wall
  13. #12
    TPF Junkie!
    Join Date
    Feb 2008
    Western NJ
    Posts
    1,240
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by dmatsui View Post
    You sorta/kinda answered your own question. If you've ever took a flash shot of a moving subject with a sync speed of 1/60 th of a sec, you'd get blur or ghosting. The higher the sync speed, the more ambient light is blocked out.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. sync speed question
    By goodoneian in forum Beyond the Basics
    Last Post: 03-24-2009, 05:58 AM
  2. Max sync speed
    By Jus7 A Phas3 in forum Photography Beginners' Forum
    Last Post: 02-26-2008, 03:46 PM
  3. What is 'Slow Sync', 'Rear Sync', and 'Flash Compensation'?
    By ted_smith in forum Beyond the Basics
    Last Post: 12-07-2006, 09:00 PM
  4. Slow Sync's
    By maxbennett in forum General Gallery
    Last Post: 01-09-2005, 07:09 PM
  5. Slow Sync
    By ksmattfish in forum Graphics Programs and Photo Gallery
    Last Post: 01-14-2004, 07:14 AM
d80 flash sync speed
d80 slow sync
d80 sync speed
d80 sync speed 1/60
flash sync d80
flash sync to stop motion
nikon d80 slow sync mode
slow sync d80
slow synch mode d80
slow synch on the d80
sync speed d80
Tags for this Thread
