+ Reply to Thread
Results 1 to 14 of 14
  1. #1
    Join Date
    Aug 2006
    Posts
    60
    My Gallery
    (0)
    Liked
    0 times
    SB-600 Diffusers
    Looking into getting a diffuser for my flash since the SB-600 doesn't come with one.. I have noticed there are alot of them out there and have no idea which ones I should be looking at. Can you guys and gals point me in the right direction?
  2. # ADS
  3. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,308
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    802 times
    What situations do you need a diffuser for?
    I've written plenty of posts about my thoughts on these flash accessories. Some of them are good for some situations and useless for others. Many of them are meant to be used while bouncing the light and many of these could be replaced with a simple bounce card.
    Better than any flash accessory is a good knowledge of light and how your flash works and how to bounce it effectively.
    I would suggest practicing with your flash, as is. Then if and when you find that you need something for your specific needs, then you can better choose what will be best for you.
    The camera makes everyone a tourist in other people's reality, and eventually in one's own. - Susan Sontag
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  4. #3
    Banned
    Join Date
    Oct 2008
    Massachusetts
    Posts
    1,860
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    I absolutely love my Light Sphere. It does a superb job of, not only diffusing the light, but sending it around the entire room to eliminate almost all shadows and hot spots. Instead of just diffusing the light in the direction of your subject, it sends light up and all around at the same time with a convex dome in the top of it that is translucent. I don't know what the pros think of it, because I'm about the only person on here I've seen mention it. Maybe it's too pricey, but I really like the results. Just my $0.02
    www.garyfong.com
    As mike said above, it's good to understand light, and almost everyone raves about www.strobist.com. Gary Fong offers some online tutorials here: http://flashdiffuser.com/
  5. #4
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    30,308
    My Gallery
    (111)
    Liked
    802 times
    Many people like the LightSphere, and it works great in small rooms. The problem, however, is when people use it in large rooms or outdoors etc. Because it spreads light all around, it wastes a lot of light/power.
    The only way to soften light is to either make the source bigger or move it closer. Like many of these accessories, the L.S. is bigger than the flash head...but not by a whole lot. When used directly (not counting the bounce) it will give you softer light when close up...but as you get farther away from your subject, it really doesn't improve the light over a bare flash.
    So the key is knowing when to use it and when not to use it.
  6. #5
    Banned
    Join Date
    Oct 2008
    Massachusetts
    Posts
    1,860
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by Big Mike View Post
    Right, and you really need a low ceiling for it to be effective.
  7. #6
    TPF Junkie!
    Join Date
    Jan 2007
    The Upper West Side of Mississippi (you have no idea just how funny that is)
    Posts
    4,236
    My Gallery
    (0)
    Liked
    57 times
    Go here and work your way down to DIY Diffuser. It'll be worth your while I think.
    Luck favors the prepared.
    To be in the right place at the right time you have to first be in the right place.
  8. #7
    TPF Junkie!
    Join Date
    Dec 2007
    Flagstaff/Az
    Posts
    2,242
    My Gallery
    (0)
    Liked
    1 times
    I use the omni bounce which works well for me or, the built in diffuser on mine.
    I shoot therefore Iam.
    Nikon D300
  9. #8
    Join Date
    Jan 2007
    Kansas City MO
    Posts
    201
    My Gallery
    (2)
    Liked
    0 times
    Quote Originally Posted by Mike_E View Post
    no link
  10. #9
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,242
    My Gallery
    (0)
    Liked
    108 times
    The ghetto DIY photography stuff thread.
    Second from the top. Take a look at the example photograph. And take note of how cheap this wonderful light is achieved.
    /EDIT: Proofread first post later. Sorry that's not a diffuser, but the principle can be just as easily applied. Build a box out of tracing paper. The effect is just as good as buying an omni bounce.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  11. #10
    Banned
    Join Date
    Oct 2008
    Massachusetts
    Posts
    1,860
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by Garbz View Post
    That stuff's all well and good if you're just sitting at home, but it's definitely a moped.
  12. #11
    Join Date
    Aug 2006
    Posts
    60
    My Gallery
    (0)
    Liked
    0 times
    I know I need to learn to use my flash better.. That I will admit... I try to bounce my flash whenever possible.. But I'd like a diffuser to soften shadows when I have no choice but to use direct flash.. Maybe I can achieve that without a diffuser is what I'm hearing on here?? Anyone have any book recommendations that might add to my knowledge?
  13. #12
    TPF Junkie!
    Join Date
    Oct 2007
    Montreal, QC, Canada
    Posts
    6,082
    My Gallery
    (0)
    Liked
    3 times
    www.abetterboucecard.com You can make one for about 15 cents and it works better than a diffuser. However, if you need a diffuser, just pick one up for under $10, they are all over the net in many places (google is your friend).
    Gary Fong stuff is *incredibly* overpriced for what it does.
  14. #13
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,242
    My Gallery
    (0)
    Liked
    108 times
    Quote Originally Posted by stsinner View Post
    Yeah it gets some looks but I did shoot a wedding with that huge bounce card, and got the idea from a wedding photographer. Guess it depends on if you care about how you look vs how much money you spend. The example photos speak for themselves. But I did get some questions why I had a large sheet of paper stuck to my camera
  15. #14
    TPF Junkie!
    Join Date
    Jan 2007
    Posts
    4,236
    My Gallery
    (0)
    Liked
    57 times
    Sorry, I was evidently in too big a rush.
    Here you are...
    http://super.nova.org/DPR/#TOC
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Flash diffusers - which?
    By enzodm in forum Photography Beginners' Forum
    Last Post: 12-21-2010, 12:33 AM
  2. Flash Diffusers
    By mcopan in forum Photography Equipment & Products
    Last Post: 06-02-2010, 02:34 PM
  3. Diffusers
    By iBats in forum Photographic Discussions
    Last Post: 12-08-2009, 07:35 PM
  4. diffusers
    By Rhys in forum Beyond the Basics
    Last Post: 04-14-2008, 05:30 AM
  5. Diffusers
    By Blackswann in forum Beyond the Basics
    Last Post: 02-01-2005, 10:15 AM
diffuser for sb-600
diffuser for sb600
diffuser for the sb-600
diffuser sb-600
diffuser sb600
diy diffuser for sb600
diy sb600 bounce
how to use sb 600 diffuser
sb 600 diffuser
sb 600 flash diffuser
sb-600 diffuser
sb-600 diffusor
sb600 diffuser
sb600 diffusers
sb600 diy diffuser
