+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2009
    Posts
    282
    My Gallery
    (7)
    My Photos Are OK to Edit
    Liked
    0 times
    Cool Len's Filter/Polarizer, 70-200 f/2.8, HELP.
    So I have the new nikon 70-200 pre ordered, i need to get a filter for it, I don't want to go cheap on it so for those of you who have some experience in this matter, I need some advice, Should I go with just a UV protection filter or a circular polarizer. and any good suggestions as far as brand (Hoya, Tiffen, BW) my budget is around $150ish. Thank you in advance
    Nikon D300s + MB-D10 Grip
    Nikkor 70-200mm f/2.8 VR II
    Nikkor 50mm f/1.4
    Nikkor 18-105 f/3.5-5.6 VR
    Nikon SB-900
    Nikon 1.7x Teleconverter
    Sigma 70-300mm f/4-5.6 DG APO Macro
    Manfrotto 190XPROB & Manfrotto 322RC2 Head
    Kata Sensitivity V Bag
    Wish List: AF-S VR Zoom-Nikkor 200-400mm f/4G IF-ED, AF-S NIKKOR 600mm f/4G ED VR
  2. # ADS
  3. #2
    TPF Junkie!
    Join Date
    Jul 2009
    USA
    Posts
    13,254
    My Gallery
    (7)
    Liked
    1935 times
    So, you want to buy a $2,500 70-200 zoom lens that is designed to be the best lens possible to make in the category for $2,500,and you are preparing to spend up to $150 to subtly degrade the optics of this new super lens. Okay. You can do that here for $112.50.
    The best filter will be the B+W 010 with the multi resistant coating
    B+W | 77mm UV Haze 010 (MRC) Multi-Resistant Coating | 66026942
    Keep in mind however, that you are buying a lens with the new Nano-crystal multicoating,which is a true, not an advertising or Bu(($hi+ type of advance in lens coating technology. Using a UV filter,even a good one, will significantly increase your chance for some nice lens flares when shooting right toward bright light sources (or even candles at a birthday party in a darkened room).
  4. #3
    Join Date
    Oct 2009
    Posts
    282
    My Gallery
    (7)
    Liked
    0 times
    very true, so in that case you would recommend not using a filter on it, how about top of the line polarizer, would that still not be a good idea?
    Nikkor 50mm f/1.4
    Nikon SB-900
  5. #4
    TPF Junkie!
    Join Date
    May 2006
    Eddington, ME
    Posts
    2,093
    My Gallery
    (0)
    Liked
    15 times
    For filter brands stick with either Hoya or B+W, but make sure they are the multi-coated versions! Hoya also carries a lower line so avoid those.
    As for filters, I do not use a protection filter. I use a hood or nothing at all. Why add glass in front of very good glass if you dont need too?
    As for a circular polarizer, again stick with Hoya's or B+W's multicoated variety. There is a difference in the good ones and cheap no-name ones.
    Hoya has several levels of CPOL's. Their Pro 1D which is supposed to be designed for digital sensor, and 2 regular ones with different coatings (standard and super coatings). I would go with the Super coated version or the Pro 1D.
    B+W has what they call a MRC CPOL which is their term for multi resistant coating (multi coatings). They also have a Käsemann-type which is the best of the best. It's about $175 and would be my choice if I were to get a new one today.
    I have a MRC B+W that I bought about 10 years ago. Very good filter and will last at least another 10-20 years if not more.
    There are also some CPOL's that have additional effects like a warming effect (slight color filtering effects). These are for specific uses and are probably not a good choice for a first filter unless you are doing only what they would be good for.
    Do not buy a linear filter. I have not tried it but it is said they dont work well with digital cameras???
    Also a CPOL blocks some light. So they are not a keep on the lens all the time type filter. Unless your in good light all the time when shooting. I don't know if the new 70-200 comes with a hood. If it doesnt pick one up and keep it on, and use it as a lens protector from bumps and thumps. They also help take higher quality shots by redusing flare and ghosting from strong light.
    If you want to know my equipment, your gonna have to specify which bag of equipment you want to know. Choices are bag #1 thru #6
  6. #5
    TPF Junkie!
    Join Date
    Jul 2009
    USA
    Posts
    13,254
    My Gallery
    (7)
    Liked
    1935 times
    ^^ + 1
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. polarizer filter?
    By photosoto in forum Photography Beginners' Forum
    Last Post: 10-30-2009, 02:46 AM
  2. Which ND filter to buy? Also Polarizer
    By sinjans in forum Photography Equipment & Products
    Last Post: 07-02-2009, 07:29 AM
  3. Polarizer filter
    By mooimeisie in forum Photography Equipment & Products
    Last Post: 04-14-2009, 09:35 PM
  4. Got me a Polarizer filter!
    By CAG76 in forum Photography Beginners' Forum
    Last Post: 01-11-2009, 11:26 PM
  5. Polarizer Filter
    By loves_guitar in forum Photography Beginners' Forum
    Last Post: 10-13-2006, 07:33 PM
70-200 nikon filter
70-200 polarising filter
best filter for nikon 70-200
best filter for nikon 70-200 vr ii
best hoya filter for nikon 70-200mm vrii
best polorizor for nikon 70-200
filter size to fit 70-200mm lens
nikon 70 200 filter
nikon 70-200 filter
nikon 70-200 filter size
polarizer filter 70-200 nikon
polarizing filter sigma 70-200 lens
what size filter fits the 70-200 nikon lens
which camera filter goes with nikon 70-200
Tags for this Thread
