+ Reply to Thread
Results 1 to 11 of 11
  1. #1
    Join Date
    Aug 2010
    Posts
    4
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Framework issue with the Sony Alpha 300
    (not sure if this is the correct subforum for this post, but there are so many and yet none seemed to fit, move this thread if need be)
    My Sony Alpha 300 has an issue. I'm quite sure it is hardware related, since I set back all my settings to the factory default.
    whenever I look trough my objective I see the frame of my picture. When I've shot this frame and I look at the actual photograph I took it differs from the frame I saw through my objective, before and while taking the photograph.
    It differs because the bottom is 'sliced' off a little bit and is added at the top. Of course not literally, it didn't move the pixels that are supposed to be on the bottom to the top, but the frame has been moved 'upwards' as if I was aiming xx cm/m higher then I had displayed trough my objective.
    My Sony Alpha 300 makes a 'rattling' sound whenever I turn it on. This has occurred during my last holiday. Might this be the problem causing the frame issue?
    I reckon I'll bring my body and objective to a photoshop retailer tomorrow.
  2. # ADS
  3. #2
    Join Date
    Aug 2010
    Edmonton
    Posts
    155
    My Gallery
    (0)
    Liked
    0 times
    Hmm, are you sure its taking it from the bottom and adding at the top?
    Most DSLRs have this thing where the viewfinder only sees about 95% of the actual image. The picture is a bit bigger then what you can see through the viewfinder.
    If you're missing a bit from the bottom and there's more at the top though, there might be a problem with your camera.
    Pike Games Free online games
  4. #3
    Join Date
    Aug 2010
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by AdrianC View Post
    Yes, I am sure.
    The sides are affected as well, as you mentioned happens with most DSLRs.
    The cut off from the bottom and the adding to the top still occurs, yes.
    I figured as much.
  5. #4
    It's all about - Light Site Moderator
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,102
    My Gallery
    (1)
    Liked
    1750 times
    Your camera is malfunctioning and requires repair.
    We are assuming when you say 'objective' you really mean 'viewfinder'.
    The viewfinder is blocked by the mirror during an exposure, which is why the viewfinder goes black.
    The rattleing sound is likely the in-the-body optical stabilization system, which I suspect is malfunctioning.
    . . . . . . Keith . . . . . . .How Do I Use My Digital SLR?...
    "Even the easy things are tough, if you do them half-heartedly"
    FOR SALE : Stay Tuned!
  6. #5
    Join Date
    Aug 2010
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by KmH View Post
    I do. Excuse me for this misunderstanding. My knowledge of the photographical terminology is non existant, if limited at most.
    This is normal though, is it not?
    I see. I'll mention this at the photography retailer. Thank you for your reply and seemingly fine information in it. It is appreciated.
    /edit 27/11/2010
    Brought back to retailer. All problems seem solved.
  7. #6
    Join Date
    Jan 2011
    France
    Posts
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Quote Originally Posted by Omitson View Post
    Hi
    I have the same problem in my Sony300.
    Is it a serious problem or just the dislocation of the CCD.
    What was the repair charge.
    Thanks in advance
  8. #7
    TPF Junkie!
    Join Date
    Jun 2009
    An American in Europe
    Posts
    5,307
    My Gallery
    (0)
    Liked
    374 times
    Translation service here:
    Objective = Lens
    "Every child is an artist. The problem is how to remain an artist once you grow up."
    Pablo Picasso
  9. #8
    TPF Junkie!
    Join Date
    Jun 2009
    Posts
    5,307
    My Gallery
    (0)
    Liked
    374 times
    The only thing I can think of is that the mirror is not quite where it should be?????????
    Pablo Picasso
  10. #9
    Join Date
    Aug 2010
    Posts
    4
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by videobusters View Post
    Hi
    Thanks in advance
    I don't know exactly what the issue was, other then how I described it above.
    I know they fixed it and I didn't have to pay anything because it was still within the one or two year warranty I had.
  11. #10
    Join Date
    Mar 2011
    Posts
    My Gallery
    (0)
    Liked
    0 times
    Did you ever find the solution to your problem? My Sony Alpha 300 is doing the exact same thing. It makes a rattling noise when I turn it on, and all of the pictures are off. I took it into a camera store nearby and they had no idea how to fix it. Sending it in to be repaired (even though they couldn't yet tell me the problem) would cost around $300. Anything you've found out about this problem would be greatly appreciated!!!
  12. #11
    TPF Supporter
    Join Date
    Apr 2009
    Iowa
    Posts
    22,102
    My Gallery
    (1)
    Liked
    1750 times
    there is little doubt your camera is malfunctioning and needs to be repaired. It's to bad your Sony is apparently no longer in warranty.
    It sounds like Sony has a design problem.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Replies: 0
    Last Post: 05-10-2010, 04:39 PM
  2. Sony Users! Battery Grip for Sony Alpha Series Digital SLR Camera
    By Link Delight Online Shop in forum Linkdelight Photography Accessories
    Last Post: 01-05-2010, 01:34 AM
  3. Sony's New Alpha 350
    By skieur in forum Photography Equipment & Products
    Last Post: 02-02-2008, 08:35 PM
  4. The sony alpha, and ISO
    By shorty6049 in forum Photography Beginners' Forum
    Last Post: 04-13-2007, 04:36 AM
  5. sony alpha?
    By mkalcevic in forum Photography Equipment & Products
    Last Post: 08-13-2006, 10:15 AM
cranking noise when u turn on the sony a 300 camera
default sony alpha 300
framework problem with sony alpha 300
sony a300 frame problem
sony a300 viewfinder problem
sony alpha 300 disassembly
sony alpha 300 problems
sony alpha 300 shift
sony alpha 300 viewfinder blurry
sony alpha 300 viewfinder issues
sony alpha a100 rattling
sony alpha framework issue
sony alpha noise while on
take apart sony alpha 300
where can i take my sony alpha for repair
Tags for this Thread
