Results 1 to 6 of 6
  1. #1
    Join Date
    Oct 2010
    Posts
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Question Questions about buying first dslr
    This is my first post on The Photo Forum, so I hope I don't mess anything up... I love photography and am looking to get my first DSLR. I want to get the Canon Rebel T2i kit (which has an 18-55mm) along with a 50mm lens. Would this be a good first two lenses? Also, I live in on the Mid-Atlantic coast of the U.S. and humidity can get pretty bad in the summer. What precautions should I take in these conditions. Also, are there any accessories that I should get? I'm sorry if this is posted in the wrong section, but I was having trouble finding another place to ask these questions...
    Thanks a ton
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1202 times
    Welcome to the forum.
    The T2i would make a great first DSLR camera, and those two lenses would make a good starting point...unless, of course, you can afford better lenses. A good quality lens may last a lifetime and while these cheap ones might last, if you take care of them, it's likely that you will want to upgrade them before long (especially if you hang around on photography forums )
    If that's something you want to consider, then what is your budget for better lenses? If not, then don't worry about it for now, those two will do fine.
    As for the humidity, you will want to avoid condensation. When you have a cold object and take it into a humid environment, it will collect condensation...so for example, if you are in an air conditioned space and you go out into the hot humid air, water will form on (and in) your gear.
    To avoid that, let your gear warm up before you expose it to the air. You could use zip-lock bags, but usually a camera bag is good enough, but they can act like a cooler, keeping the gear cool for a long time.
    I'd also suggest getting some silica gel packs for inside your bag, to absorb moisture.
    As for accessories; a good camera bag, extra memory and batteries, a tripod etc.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  4. #3
    Join Date
    Oct 2010
    Posts
    My Gallery
    (0)
    Liked
    0 times
    Thanks so much. My budget really isn't very big. Are there any relatively inexpensive tripods that you would care to recommend? I was thinking about a Crumpler Six Million Dollar Home bag for my camera... should that house the body, two lenses and some accessories, or is it to small to use as my main bag?
  5. #4
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    Liked
    1202 times
    You might be able to get by with a cheap tripod for a while. I used a cheap Velbon tripod for a few years before I got some good ones. Your gear isn't heavy, so that shouldn't be an issue. Although, if you buy a good tripod, it should last you for decades. I like Manfrotto brand.
    Judging the size of a camera bag, is best done in person. I'd suggest going to a well stocked camera store and trying out several bags.
    Hugh Macleod
  6. #5
    emh
    emh is offline
    Join Date
    Apr 2010
    CA
    Posts
    181
    My Gallery
    (0)
    Liked
    3 times
    The T2i is a decent first DSLR. However, if your budget is not super-tight, I would encourage considering a Nikon D90 (which you could get for perhaps $150 more then the T2i with similar lenses, and is much, much better for still photography although not as good as the T2i for video) or a Canon 60D (pricier than the D90, but does good video too). Personally, I find the limited controls on the Rebels a bit of a hindrance if you want to experiment and play around more with the settings and features of a DSLR as you learn.
    As for lenses, the 50mm is always a good place to start. The kit lens will get you started but will likely need upgrading at some point Still, it's a good start until you figure out what you'd want in the long run.
    Agree with Big Mike on tripods. A decent Velbon or something similar will work for most of these lighter DSLR to get you started. The adjustments can sometimes be a bit cumbersome on these, but they should be stable enough.
    As for bags, I'd encourage you to go to a store and try them out. If you don't plan to carry the camera in the bag much, a messenger-style bag (like the Crumpler you mentioned) may be fine. However, if you plan to carry the camera for a long time -- say several-hour hikes, or a day touring a city on foot -- that can get a bit tiring. They also have very little space for anything other than the camera. A backpack-style bag is generally less tiring and more versatile. Sling-style bags that go over one shoulder are another option. In the end, you may find you need more than one bag based on what you plan to do on a given day
  7. #6
    TPF Junkie!
    Join Date
    Apr 2008
    California, USA
    Posts
    1,661
    My Gallery
    (0)
    Liked
    22 times
    Edit: one sec :P
    Canon EOS 7D
    Canon EF 70-200mm F/2.8L USM
    Canon EF 50mm F/1.4 USM
    Canon Speedlite 480EX II
    Manfrotto 293 Tripod w/ QR ballhead *NEW*
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Buying First DSLR
    By nicko in forum Photography Equipment & Products
    Last Post: 07-28-2009, 09:57 PM
  2. Buying my First DSLR
    By egor.evseev in forum Photography Beginners' Forum
    Last Post: 05-12-2009, 11:21 PM
  3. buying first dSLR
    By colette in forum Photography Beginners' Forum
    Last Post: 01-14-2009, 10:56 AM
  4. Buying my first DSLR
    By ChrisF79 in forum Photography Beginners' Forum
    Last Post: 02-09-2008, 11:05 PM
  5. Buying a dSLR??
    By jeremyboycool in forum Photography Beginners' Forum
    Last Post: 06-27-2007, 03:37 PM
how much silica gel to use for dslr
how to use sillica gel with dslr
precaution before dslr buy
precautions before buying slr camera
questions ask buying dslr
questions to ask a store when buying a d-slr camera
questions to ask before buying a dslr
questions to be asked while buying a dslr
silica gel with dslr
things to check buying a dslr
what precaution before buying dsl camera
what question to ask a before buying a dslr camera
what question to ask before buying dslr camera forum
what should i ask when buying a dslr
what to ask before buying a dslr
