+ Reply to Thread
Results 1 to 10 of 10
  1. #1
    Join Date
    Aug 2011
    kolkata, india
    Posts
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Whether to buy an entry level DSLR or Compact
    Hi,
    I am new in this forum and I am posting this thread to get your advices on my specific needs. I was thinking about buying a compact camera within the price range of $300-400 with manual control. My preference was Nikon P100. But, I learnt that the model is now discontinued by Nikon. Subsequently, I learnt about FujiFilm HS10, but got different feedbacks. Some are saying it's a good camera while others are telling me not to look for anything beyond Nikon or Canon (as they don't produce good pictures). Now, the choice that is left is Nikon P500 which is marginally less affordable than D3000. So, now, I am confused as to which camera to buy. Should I trust Fuji or should I buy P500? Will it be a good choice to buy D3000.
    I don't have a lot of experience in photography; but I am really passionate about it. I am reading a lot of articles to learn about the different aspects. The DSLRs will not be too complicated to me. At least, I will enjoy playing with it. However, I am a bit worried about the baggage. Also, I can't invest on a good lens; at least not now.
    My interest are in general travel photography, occasional night shots/ low light photography, wildlife, sports, etc.
    Please help me!
  2. # ADS
  3. #2
    Ant
    Ant is offline
    Join Date
    Jun 2004
    Luton. UK.
    Posts
    438
    My Gallery
    (0)
    Liked
    1 times
    I'd always go for a DSLR over a prosumer/compact if you're really serious about photography. They're far more flexible in terms of lens options and they usually perform better in low light and fast action situations, although, some of the higher end prosumer fixed lens cameras are getting pretty good.
    If you're on a really tight budget you may look at the used market. You can get some really decent DSLRs quite cheap because they're a few years old. Just try to find out how many actuations they've had and what kind of condition they're in. Of the cameras you're mentioned, however, I'd go for the D3000. I don't know anything about Canon cameras but there's no reason you shouldn't look at their entry level range cameras either. Don't worry about not being able to afford a lens. It'll come with a fairly decent kit lens and then you can gradually save for another one. In a few years time when you decide to buy another newer DSLR then you'll still have your existing lenses to use, and might only need to buy a body, which will save you money and is one of the biggest advantages with DSLRs
  4. #3
    Join Date
    Jan 2011
    Newark, De
    Posts
    50
    My Gallery
    (0)
    Liked
    0 times
    I would have to say to go with the DSLR If you are truly passionate about photography this is going to benefit you some much more than a point and shoot. Like ANT said check out the used market and try to pick up a used D3000 with a kit lens. Start with that and see how you like shooting with a DSLR. The only other advise i would give is that when you go to get new lens in the future don't waste money on cheap lenses, save your money and buy the better faster lenses. It will pay off with better results in your photos. Good luck
    Nikon D3s
    Nikon D300s w/MB-D10
    Nikon 14-24 2.8
    Nikon 24-70 2.8
    Nikon 70-200 VR II 2.8
    Nikon 300 2.8
    Nikon 105 2.8 Macro
    Nikon 85 1.4G
    2 Nikon SB-900
    2 Nikon SB-700
    PocketWizards Flex & Mini
  5. #4
    TPF Junkie!
    Join Date
    Jun 2010
    minnesota
    Posts
    1,994
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    267 times
    It going to be upto you but I would lean towards used body and lens. You could come out with two lens and a body depending on if you want AF and metering.
    Just an example:
    Nikon Digital D 40 6.1 MEGAPIXEL BLACK WITH BATTERY & CHARGER (SD CARD ) DIGITAL SLR INTERCHANGEABLE LENS CAMERA - KEH.com
    Nikon Autofocus 50 F1.8 (52) WITH CAPS 35MM SLR AUTO FOCUS STANDARD ANGLE LENS - KEH.com
    About $275 plus shipping
  6. #5
    Join Date
    May 2011
    Canada
    Posts
    527
    My Gallery
    (0)
    Liked
    8 times
    dslr, it leaves room for upgrades and it will take you further in photography than a compact would.
    http://www.flickr.com/photos/60751091@N06/
    Nikon D90
    Nikon AF-S 24-70mm f2.8G ED N
    Nikon AF-S 18-105mm f3.5-5.6G ED VR
    Nikon SB-600
  7. #6
    Join Date
    Oct 2010
    Slovakia
    Posts
    536
    My Gallery
    (0)
    Liked
    34 times
    Quote Originally Posted by joyphoto View Post
    That's really an easy answer then If you're really passionate about it, don't waste your time and money on a compact camera, get a DSLR. Getting at least some decent low-light photos with a compact is really a pain.
  8. #7
    Join Date
    Aug 2011
    kolkata, india
    Posts
    My Gallery
    (0)
    Liked
    0 times
    Thank you all for your advices. You guys really made it easy for me. Just two more things - how would I know that a used dslr is in good condition? and if I buy a new DSLR (probably D3000) is it a good camera in itself? I heard some people saying that a low level dslr makes a lot of compromise and you won't be able to use it after a year or so. Looking for your inputs. Thanks again for your support.
  9. #8
    Join Date
    Oct 2010
    Slovakia
    Posts
    536
    My Gallery
    (0)
    Liked
    34 times
    Well, that isn't easy to explain on the forum. There are quite a few things to look for, so I guess your best best would be to check the camera with some of your friends, who is more experienced and who can recognize whether it's ok or not.
    It all depends on what you really want. Is there a chance you'll turn into semipro/pro after a year? Do you plan to shoot everyday or just occasionally? What are you hoping to achieve in photography? I believe, that for a beginner it's best to buy a cheaper body and get better lenses over time when you can afford them. Bodies come and go, but your lenses stay and if you bought them wisely, you can use them with whatever camera you'll buy in the future. I believe it's always better to have a cheap body and quality lenses than vice versa.
  10. #9
    Join Date
    Jan 2011
    Newark, De
    Posts
    50
    My Gallery
    (0)
    Liked
    0 times
    Tom is right on, it all depends on what you to do with the camera. Since this is going to be your first dslr the d3000 is a really good starting point, its cheap enough that if you happen to loose interest your not throwing a bunch of money away.
    When buying a used camera you just need to be selective with who you buy from. I have bought camera bodies off ebay without any problems. You want to look for one with a fairly low number of shutter clicks (pictures taken) and just make sure it is in good physical condition. If it is in good physical condition there is a good chance it was well cared for. When I buy camera gear from ebay I look for sellers that have %100 feedback and been selling for awhile. If you find something your interested in and want an opinion send me a link and ill look at it for you. Good luck
    Nikon D3s
    Nikon 14-24 2.8
    Nikon 24-70 2.8
    Nikon 300 2.8
    Nikon 105 2.8 Macro
    Nikon 85 1.4G
    2 Nikon SB-900
    2 Nikon SB-700
  11. #10
    TPF Junkie!
    Join Date
    Jun 2010
    minnesota
    Posts
    1,994
    My Gallery
    (0)
    Liked
    267 times
    Do you plan on getting into any Off Camera Flash portrait work? One advantage of the D40 is its 1/500 flash sync speed.
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. User Entry Level DSLR on for $200-$300?
    By ILikePictures in forum Photography Beginners' Forum
    Last Post: 02-26-2011, 09:45 AM
  2. entry level dslr
    By furion23 in forum Photography Equipment & Products
    Last Post: 10-01-2010, 11:24 PM
  3. Looking for Entry Level DSLR
    By SAPierce2006 in forum Photography Equipment & Products
    Last Post: 06-24-2009, 02:02 PM
  4. Entry level DSLR
    By zbo2408 in forum Photography Equipment & Products
    Last Post: 11-07-2008, 06:26 PM
  5. entry level dslr?
    By niko in forum Digital Discussion & Q&A
    Last Post: 02-22-2008, 03:32 AM
best 300$ compact camera
better to buy used dslr or entry
compact entry level dslr
compact entry-level dslr
dslr vs compact
dslr, whether to buy
entry dslr vs compacts
entry level dslr for product photography
entry level dslr forum
entry level dslr or compact
entry level dslr vs compact
entry level dslr vs compact dslr
nikon p500 vs entry level dslr
prosumer compact fixed lens
should i buy used dslr or compact
Tags for this Thread
