+ Reply to Thread
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Derrel
Thread: I know what I want my first real camera system to do.... suggestions please
  1. #1
    Join Date
    Jan 2012
    Posts
    7
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    Currently I own what I would call a Bridge camera.. Im learning how to take proper photos and im enjoying it. I have a Fujifilm Finepix S3300. I am an avid outdoors-man, birder and hunter. When I make the jump to my first DSLR system I know what I want it to do. I want to be able to take pictures of wildlife at distance. Particularly ducks and other birds sitting still and flying. With my current equipment I find my self in the woods or a marsh under gunned and unable to take the photos im could be.
    So when I buy my first DSRL I will be also buying a long range telephoto lens. I am interested in suggestions in the most economical way to put this camera together. The camera itself does not have to be any fancier than it has to be. In Other words what Camera brand or model lends itself to the least expensive long range telephoto lens set up.. Im not worried about weight or using third party equipment. Im also not going pro any time soon.
    Thanks in advance for your suggestions.
  2. # ADS
  3. #2
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    777
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    123 times
    Long range is relative and depends on subject size. Even with a relatively long lens on a crop-sensor camera you are going to have to get pretty close to ducks to get good shots.
    This Coot was shot with a 500mm lens at 33', and is relatively uncropped.
    AS to what gear you choose, most newer bodies by Nikon or Canon would be a good choice.
    Scott Craig - Nashville, TN - Photography Pages on My Web Site and My Under Construction Site
  4. #3
    TPF Junkie!
    Join Date
    May 2008
    Seattle, WA
    Posts
    2,373
    My Gallery
    (15)
    Liked
    63 times
    Suggestions:
    Crop sensor over full-frame = You'll get 30% more range from a crop sensor using the same lens
    Good high-iso performance = If you're shooting birds in flight you'll need a fast shutter speed, telephoto lenses are typically not very fast (unless you spend a small fortune). Good high-iso performance will allow you to make up for the slower telephoto lens.
    High FPS = at least 5fps, preferably faster
    I'd suggest the nikon D7000, it has all the above. The D5100 would be a cheaper option, but it's sort of slow (4fps).
    Whatever you get the lens I'd suggest is the Sigma 50-500mm DG OS HSM. Not as good as the ideal birding lens: the 600mm f4 AF-S VR, but that lens cost $10,000
  5. #4
    TPF Supporter
    Join Date
    Nov 2011
    Nashville, TN
    Posts
    777
    My Gallery
    (0)
    Liked
    123 times
    Quote Originally Posted by djacobox372 View Post
    ... Whatever you get the lens I'd suggest is the Sigma 50-500mm DG OS HSM. Not as good as the ideal birding lens: the 600mm f4 AF-S VR, but that lens cost $10,000
    The Coot in my post was shot with the Sigma 150-500 at 500mm (not the 50-500). I only wanted the long end and the 150-500 is about $1,000 (MSRP) less than the 50-500.
  6. #5
    TPF Junkie!
    Join Date
    Jan 2007
    Chicago burbs
    Posts
    1,168
    My Gallery
    (0)
    Liked
    30 times
    Well, your current camera has a 24-620 mm lens.
    To have an improvement on that is mostly going to be a issue of speed, not length.
    You'll get partly there simply by going to an SLR. The larger sensor gives better images when the sensitivity is cranked up, because the image doesn't have to be enlarged as much.
    If you can afford an SLR with a full frame sensor, that is the way to go. If not, get one with an APS-C sensor and then get the Sigma 100-500 (?) lens.
    Another option that is often forgotten is the mirror lens. I had one for my old Pentax K1000, and I LOVED it. It was a fixed f/8, so I alway shot it with fast film.
    If you had that on a digital SLR body with the APS-C sensor and sensitivity set to about 800, I think you could do quite well on a budget. It would come out to about 750 mm. With digital, you have the option to change the ISO on the fly, so these are even more attractive than before.
    A tripod should be considered required.
    "Well begun is half done."
    -Aristotle
  7. #6
    KmH
    KmH is offline
    TPF Junkie!
    Join Date
    Apr 2009
    Iowa
    Posts
    20,345
    My Gallery
    (1)
    Liked
    1482 times
    Serious bird photographers use a very sturdy and stable tripod, usually with a gimbaled head, and 600 mm f/4 prime lenses.
    You'll want to keep your eyes peeled for used 600 mm f/4 lenses. New ones go for just over $10,000 - Nikon 600mm f/4.0G ED VR II AF-S SWM Super Telephoto Lens for Nikon FX and DX Format Digital SLR
    A good gimbal tripod head - Black Widow Gimbal Pro Tripod Head BWG-Pro ProB Jobu Design
    End Internet Piracy, Not Internet Liberty
    . .Keith. . . .How Do I Use My Digital SLR?...
    FOR SALE : Stay Tuned!
  8. #7
    TPF Junkie!
    Join Date
    Jul 2009
    USA
    Posts
    12,113
    My Gallery
    (7)
    Liked
    1472 times
    I'd say, buy a Canon APS-C body, and look for good, used glass to put on it, via adapters. Canon will accept like seven different lens system lenses. Older, manual focus Nikkors will work well on a Canon 40D or 50D body. You will want a LONG lens, like a 500mm f/4 Nikkor-P, or Sigma 500mm f/4.5, or maybe an older Canon EF 500mm f/4.5-L. All of those lenses tend to be in the $2k range or so,depending. "Wildlife at a distance" is sort of like "Crystal champagne", or "Rolex watches"...it doesn't come cheaply...and what I am suggesting is the "budget" route.
    bazooka likes this.
    "It's about time people started taking photography seriously, and treating it as a hobby." Elliott Erwitt
  9. #8
    Dao
    Dao is online now
    TPF Junkie!
    Join Date
    Mar 2008
    St. Louis
    Posts
    4,452
    My Gallery
    (0)
    Liked
    140 times
    From the links below, the photographer took those bird photos with camera like Canon 20D or 350D (aka Digital Rebal XT). But the lens he used were expensive.
    Juza Nature Photography - Birds: Ducks, Geese and Grebes
  10. #9
    Keeper of the Padlocks Site Moderator
    TPF Supporter
    Join Date
    May 2008
    UK - England
    Posts
    14,146
    My Gallery
    (0)
    Liked
    731 times
    Canon has the added advantage of their £1K line of longer lenses - a 300mm f4 IS (bit short but works well with a 1.4TC for a 420mm) - a 400mm f5.6 L (sharpest of this set) and 100-400mm. Something where Nikon (in new) has only their 300mm f4 as an option.
    If you opt for Sigma 3rd party options you can go Canon or Nikon equally (since Sigma make options for both).
    Derrel has also listed out options for going into older glass which might yet be cheaper still, though will often have you working only with manual focusing.
    How to get critique and feedback on your photography!
    The Mentor Scheme mentoring on TPF all are welcome to read and apply
    Best photos on the net!
    well at least I like to think so - sometimes
  11. #10
    TPF Junkie!
    Join Date
    Sep 2010
    Bowling Green, KY
    Posts
    1,117
    My Gallery
    (0)
    Liked
    186 times
    Really? And all this time I thought the crop factor was 1.6x, unless of course you're referring to the Canon APS-H format.
    Nikon D7000, Nikon MB-D11, Tokina 11-16 f/2.8, Tokina 16-50 f/2.8, Tokina 50-135 f/2.8, Tokina 100 f/2.8 Macro, Hoya 77mm CPOL
    Slik 580DX Tripod, Domke F-2, Domke F-5XB, Nikon SB-600, (2) Nikon SB-28, Nikon SB-28DX, Yongnuo RF-602 Triggers
  12. #11
    Join Date
    Jul 2011
    WV
    Posts
    280
    My Gallery
    (0)
    Liked
    25 times
    You've gotten a lot of suggestions here but you really need to put up a budget if you want more concise suggestions. From what I've read you've gotten set-ups ranging from around $1500 to closer to $15000 suggested so far. I can tell you that I like to shoot wildlife and I wanted to stick with Nikon lenses at first so I have a 300mm f/4 with a 1.4X teleconverter. Essentially that gives me a 420mm f/5.6 lens on a crop body so equivalent to 630mm full frame and I still wish I had more reach. Once you learn how to use the 300mm f/4, it's a good "budget" option for what you're looking at though I've heard a lot of good things about the Sigmas as well and almost went that route myself.
    Nikon D7000 : 18-105mm f/3.5-5.6 VR DX : 50mm f/1.8D : 300mm f/4 AF-S w/Kenko 1.4 Teleplus Pro 300 DGX : Tamron 90mm f/2.8 macro : Meike battery grip (to be replaced with Nikon) w/ second EN-EL15
    Nikon D50 backup body : 28-80mm kit lens
  13. #12
    TPF Junkie!
    Join Date
    Dec 2009
    Houston
    Posts
    2,130
    My Gallery
    (0)
    Liked
    238 times
    40D $500 used
    Canon 400mm 5.6 $1k used
    Tripod and ball head $250
  14. #13
    Join Date
    Jul 2010
    Atlanta, GA
    Posts
    359
    My Gallery
    (0)
    Liked
    26 times
    I suggest the 7D. It has the best AF system that you will find on a non-1D line camera. Plus, it's a crop body so you get that extra reach from your teles.
    Sent from my Galaxy Nexus using Tapatalk
    Canon EOS 7D | Canon BG-E7 Grip | EF 24-105mm f/4L IS USM | Sigma AF 8-16mm f/4.5-5.6 DC HSM | EF 85mm f/1.8 USM | EF 50mm f/1.8 II
    Manfrotto 055XPROB | Manfrotto 808RC4
    | Speedlite 580EX II | Canon PowerShot S100
    flickr
  15. #14
    Join Date
    Jan 2012
    Posts
    7
    My Gallery
    (0)
    Liked
    0 times
    Thanks for all the good information. I have started looking into all of the suggestions. The Budget well will be low 1000 to 1500 for the body and lenses. Im into used or other options. I realise that's incredibly low but I need to start the learning proses before i spend the rest of a fortune on the new hobby. thanks
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. FS: Tamrac System 3 Camera Bag, Black, Like New
    By jdag in forum Buy and Sell
    Last Post: 06-29-2011, 09:43 AM
  2. Camera System for Photography Class - Opinions please
    By supercomp in forum Photography Beginners' Forum
    Last Post: 04-22-2011, 11:33 AM
  3. Need help on understanding dslr camera and lenses system
    By saabuldin in forum Photography Equipment & Products
    Last Post: 12-13-2010, 09:24 AM
  4. Picking a Camera System.
    By ZWolfe21 in forum Photography Equipment & Products
    Last Post: 03-15-2010, 03:21 AM
  5. Help me pick a camera system
    By supra89t in forum Photography Equipment & Products
    Last Post: 10-09-2007, 09:12 PM
gimbal ball head 400mm 5.6
my first dslr system
