Originally Posted by
Mach0
IIRC, you need to have receipts for your gear.... Otherwise, you'd be limited to the amount you will get back if something happens and need to file a claim.
I did not have to turn in receipts for my gear as I added it. Only serial numbers.
I've had one claim on mine and I got current market value for a used replacement until I submitted the receipt for the new piece, at which point they cut me a check for the rest. HOWEVER you must make sure that your gear policy is for FULL REPLACEMENT COST. Not current market value.
Personally I feel that a shooter in your position would benefit more from a membership to PPA-which comes with $15k in gear coverage and you can add the indemnity trust as well. MANY benefits for a PPA member in discounts, learning, their resources... You'll spend about the same in a year that you would to insure your commercial (any gear you use to make $ with) gear.
Canon FanGirl Extraordinaire
02-21-2012 06:00 PM
# ADS
