Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
  1. #1
    TPF Junkie!
    Join Date
    Jul 2008
    Baltimore
    Posts
    4,001
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    191 times
    Question Cokin Z or P for 17-35?
    Hey everyone! I'm finding more and more times when I need a CPOL and ND/GND filter as my work progresses. I've always been interested in the Cokin series as I won't have to be holding any filters in my hands to cause unevenness or blur. So, my question to you is:
    Will the Cokin Z-series adapter vignette at 17mm on an FX camera? Do you think that's a viable option for my needs? I don't know how I'd attach a CPOL to the mix, should I use this system, though. Perhaps attach the whole system to the front of a CPOL? This would really concrete my need for the Z-series over the P.
    So, what do you think?
    Mark
    NIKON: D800 || D3200IR || 50mm F/1.8G || 80-200mm F/2.8D || 300mm F/4.0 AF-s
    SIGMA: 85mm F/1.4 || 180mm F/3.5 Macro
    TOKINA: 16-28mm F/2.8
    **Photography Facebook Page**
    The Journey of One Lens Across the USA - Round 2
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    TPF Junkie!
    Join Date
    Dec 2006
    Southern Maryland
    Posts
    1,907
    My Gallery
    (11)
    Liked
    318 times
    I have a couple of the Cokin "P" filters, although I don't use them much. I haven't noticed any vignetting using a 24mm on a Nikon N90S. I have seen an article where you can cut off the leading edges of the filter holder (it will still hold two filters) to reduce/eliminate vignetting on wider lenses.
    The Cokin CPL is round and fits into the slot nearest the lens, allowing it to rotate. I do not have that particular filter.
  4. #3
    TPF Junkie!
    TPF Supporter
    Join Date
    Jan 2012
    God's Country
    Posts
    1,271
    My Gallery
    (0)
    Liked
    214 times
    Z Pro, for sure. You can purchase 4X4 polarizers for the Z. You then rotate the holder.
    “ I always thought good photos were like good jokes. If you have to explain it, it just isn’t that good. "–
    Anonymous
    "The more you practice the more likely you are to get lucky." - Unknown
  5. #4
    TPF Junkie!
    Join Date
    Jul 2008
    Baltimore
    Posts
    4,001
    My Gallery
    (0)
    Liked
    191 times
    Landscape Photography
    Well, it shouldn't vignette.
    Mark
  6. #5
    TPF Junkie!
    TPF Supporter
    Join Date
    Jan 2012
    God's Country
    Posts
    1,271
    My Gallery
    (0)
    Liked
    214 times
    I have both the P and Z and I can assure you, anything wider than about 20 and the holder WILL be in view, even with the P low profile holder.
    Anonymous
  7. #6
    TPF Junkie!
    Join Date
    Sep 2006
    Wichita, Kansas, USA
    Posts
    4,598
    My Gallery
    (0)
    Liked
    371 times
    I am not terribly fond of the Cokin filters, I perfer Sing-ray and Lee but be that as it may, unless you never plan on using anything other than the 17-35 than you are not buying a system for that lens. You need to buy for your whole system.
    With that said. Lee advises that in general anything wider than 20mm has a possibility of vignetting. The basic Lee holder, while more expensive, can be built to hold from one to four filters. Lee also has a series of wide angle step up rings that are thinner than the standard rings. You might want to contact Lee support directly and see if they can advise you on your particular concern. They even make a dedicated setup for the Nikon 14-24mm. The LEE Camera Filters System - Includes Filter Holders, Adaptor Rings and Lens Hoods If you go with Cokin, go with the Z holder.
    Amateurs worry about equipment, professionals worry about time, masters worry about light.
    I can honestly say that there are two most remarkable men in the world today.
    Michio Kaku is one, and I am the other. Between us we cover all knowledge.
    Kaku knows all that can be known....And I know the rest.
    "Yesterday is history, tomorrow is a mystery. Today?
    Today is a gift. That is why we call it the present."
    Master Wugui from Kung Fu Panda
  8. #7
    TPF Junkie!
    Join Date
    Jul 2008
    Baltimore
    Posts
    4,001
    My Gallery
    (0)
    Liked
    191 times
    Wider than 20mm with the Z-pro filter holder as well?
    Mark
  9. #8
    TPF Junkie!
    Join Date
    Sep 2006
    Posts
    4,598
    My Gallery
    (0)
    Liked
    371 times
    The holder keeps that filter quite a ways from the front of the lens and is designed to hold more than one filter. With the Lee at least you could cut it down to a single filter holder. Not sure if that is possible with the Cokin.
  10. #9
    TPF Junkie!
    TPF Supporter
    Join Date
    Jan 2012
    God's Country
    Posts
    1,271
    My Gallery
    (0)
    Liked
    214 times
    Quote Originally Posted by gryphonslair99 View Post
    Yes, they make a low profile P holder that has a wide slot up tight against the lens for the CP that was mentioned earlier and then one slot in front of that for the filter. It still sticks out too far for a 20mm.
    Cokin P Wide Angle Holder PW700
    Anonymous
  11. #10
    TPF Junkie!
    Join Date
    Jul 2008
    Baltimore
    Posts
    4,001
    My Gallery
    (0)
    Liked
    191 times
    Will it vignette with the Z-PRO filter holder, though? I understand it will with the P filter holder.
    Mark
  12. #11
    TPF Junkie!
    Join Date
    Sep 2006
    Posts
    4,598
    My Gallery
    (0)
    Liked
    371 times
    The alternative that has not been mentioned. Do not go wider than 20mm and take a couple of steps back. The difference between 17mm and 20mm is very small.
  13. #12
    TPF Junkie!
    Join Date
    Sep 2006
    Posts
    4,598
    My Gallery
    (0)
    Liked
    371 times
    Quote Originally Posted by Markw View Post
    Mark
    There is a good likely hood that it will as the filter holder is three slots deep. Even in the closest slot you still have holder sticking out that may be in the FOV.
  14. #13
    TPF Junkie!
    TPF Supporter
    Join Date
    Jan 2012
    God's Country
    Posts
    1,271
    My Gallery
    (0)
    Liked
    214 times
    Mark
    You can reportedly go as wide as 10mm with the Z-Pro holder
    Anonymous
  15. #14
    TPF Junkie!
    Join Date
    Jul 2008
    Baltimore
    Posts
    4,001
    My Gallery
    (0)
    Liked
    191 times
    Quote Originally Posted by HughGuessWho View Post
    Mark
    Sweet. I only need it down to 17mm. That just doubled cost of the system, but opened up alot of options. Thanks.
    Mark
  16. #15
    TPF Junkie!
    Join Date
    Sep 2006
    Posts
    4,598
    My Gallery
    (0)
    Liked
    371 times
    Not so fast there Little Ranger. One thing that didn't get mentioned. No all filters work well with wide/ultrawides. CPOL for example. The FOV is wider than the effective coverage from the filter. Sort of like looking at a TN monitor screen from the side. You need to keep that in mind as well.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Cokin filters
    By andyg72 in forum Photography Equipment & Products
    Last Post: 09-08-2011, 02:05 PM
  2. Cokin system or...?
    By Mike K in forum Digital Discussion & Q&A
    Last Post: 05-19-2011, 03:19 PM
  3. Cokin kits
    By puyjapin in forum Photography Beginners' Forum
    Last Post: 11-28-2008, 07:02 PM
  4. Cokin reccommendations?
    By Markw in forum Photography Equipment & Products
    Last Post: 11-10-2008, 04:11 PM
  5. Cokin Filters
    By N2CSA in forum The Professional Gallery
    Last Post: 08-06-2005, 06:25 PM
76mm cokin cpl z series
cokin filter for nikon d800
cokin p filters on z pro series holder
cokin p vs z
cokin p vs z vs a holder
cokin z pro cpl
cokin z vs p
cokin z vs p filters
cokin z-pro vs lee
cpl for cokin z
d 800 cokin filters
d800 cokin
difference between cokin p and z
nikon d800 cokin
will i get vignetting using a cokin p filter holder system on the d800 28-300mm
