Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree2Likes
Thread: Reading multimeter to tell if my Vivitar 283 is of the high voltage variety.
  1. #1
    Join Date
    Jul 2012
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    I am really confused as my multimeter seems not to get consistent results from my Japanese Vivitar 283. I took pictures of my multimeter at 500 dcv 250 dcv 50 dcv and 10 dcv, in none of the modes the needles went beyond half way. My nikon d3000 which apparently max's out at 250. Can someone that can effectively read these give me some incite whether I have a high voltage or low voltage variety? IMG_0017.JPGIMG_0014.JPGIMG_0015.JPGIMG_0012.JPG Thankyou for any input.
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Posts
    Many
  3. #2
    Join Date
    Jul 2012
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    No responses yet...
  4. #3
    Chief Free Electron Relocator
    TPF Supporter
    Join Date
    Mar 2011
    Iowa
    Posts
    11,326
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    2704 times
    What exactly are you trying to measure? Trigger voltage?
    Go forth and actuate!
    Your help is requested in (charitably) tossing me off the 345-foot Financial Center.
  5. #4
    Dao
    Dao is online now
    TPF Junkie!
    Join Date
    Mar 2008
    St. Louis
    Posts
    5,399
    My Gallery
    (0)
    Liked
    265 times
    I think all Vivitar 283 has high trigger voltage.
  6. #5
    Join Date
    Jul 2012
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    Yes, trigger voltage. I am either getting inconsistent readings with my multmeter or I'm reading it wrong.
  7. #6
    Join Date
    Jul 2012
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    I looked up information and there are low voltage Vivitar 283's but some early ones are triggered by high voltage up to 450. Can you read the above multmeter at the different dcv ratings?
  8. #7
    TPF Supporter
    Join Date
    Mar 2011
    Iowa
    Posts
    11,326
    My Gallery
    (0)
    Liked
    2704 times
    My first guess is you've got a meter that no longer functions as designed.
  9. #8
    Join Date
    Jul 2012
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    Still no one that can read a mult meter? I think commenter might be right my mult meter might be shot but I tested it on a wall socket and got 120 acv... So, I'm not sure.
  10. #9
    Join Date
    Apr 2011
    Texas
    Posts
    179
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    9 times
    You should be ok if you are reading under 100 at 500dcv. I would still recommend you pick up a wein safe sync with any of those old Vivitars when using them on a dslr just to be safe. Then again some people dont and never have a problem. I wouldn't want to chance it. Also you might want to search YouTube for videos of Vivitar 283 voltage. That way you can make sure you are testing it properly.
    Edit...to answer your question it appears to be a low voltage model, but without actually seeing you perform the test or knowing if your meter is accurate I couldn't say either way without any accuracy.
  11. #10
    TPF Junkie!
    Join Date
    May 2011
    Montana
    Posts
    6,959
    My Gallery
    (0)
    Liked
    1465 times
    Quote Originally Posted by 480sparky View Post
    That's my bet. I am guessing it's reading everything at 500v max. What happens if you try to meter a 5v battery?
    75% of the internet is wrong. The rest is pornography.
  12. #11
    TPF Supporter
    Join Date
    Mar 2011
    Iowa
    Posts
    11,326
    My Gallery
    (0)
    Liked
    2704 times
    Quote Originally Posted by Anarchitekt View Post
    Well, it does look like it crossed the Atlantic on the Mayflower.
    unpopular and willis_927 like this.
  13. #12
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,643
    My Gallery
    (0)
    Liked
    191 times
    Your meter is not reading anything at all which makes sense. Where on the flash are you measuring? You should turn on the flash and measure between the centre pin (red) and the holding bracket (black), some flashes actually have a plastic holding bracket in which case the metal is recessed inside. Not sure if your flash looks like this but if so put your meter in like this:
    Set your meter to 500 DCV.
    You should read the second row from the bottom (0-50 scale). Understand that setting it to 500DCV means that scale is multiplied by a factor of 10. In this case the needle should be close to 0, if it goes anywhere above 10 start to think you have a high voltage trigger.
    To check set your meter to 250DCV your needle should double in scale. If you had 10 it should read 20 if you had 25 it should peg at 50. etc. If you're still near zero you're good.
    Finally set it to 50DCV. If the needle pegs at the right then your flash is a HV flash. It should be around 5-10 on the scale at this point.
    Honestly it looks like either your meter is toast, or you've hooked it up to measure the wrong thing. I wouldn't trust your meter if it doesn't show a linear relationship. I.e. going from 500DCV to 250DCV should cause the needle to double.
    "I am always satisfied with the best." -Oscar Wilde
    Larger versions always on flickr
    Best photos in my gallery
    Proud Supporter of The Pact
  14. #13
    Dao
    Dao is online now
    TPF Junkie!
    Join Date
    Mar 2008
    St. Louis
    Posts
    5,399
    My Gallery
    (0)
    Liked
    265 times
    I think OP was trying to measure the trigger voltage of the 283 flash.
  15. #14
    Join Date
    Jul 2012
    Posts
    12
    My Gallery
    (0)
    Liked
    0 times
    Thankyou all for your help, yes that was the method I used to check the voltage. I think I need to buy a new mult meter. Thankyou again, I appreciate your effort responding on what is a relatively boring topic.
  16. #15
    TPF Junkie!
    Join Date
    Oct 2003
    Brisbane, Australia
    Posts
    9,643
    My Gallery
    (0)
    Liked
    191 times
    Quote Originally Posted by Dao View Post
    ... and? Who were you replying to?
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. High Voltage
    By vipgraphx in forum HDR Discussions
    Last Post: 03-13-2012, 09:08 PM
  2. voltage for vivitar 550fd
    By naptime in forum Lighting and Hardware
    Last Post: 02-08-2012, 05:31 PM
  3. Replies: 3
    Last Post: 10-01-2009, 06:37 PM
  4. High Voltage
    By crawdaddio in forum General Gallery
    Last Post: 01-29-2006, 11:27 AM
  5. High Voltage Exposures
    By sepulker in forum General Gallery
    Last Post: 08-31-2005, 03:04 PM
how to modify vivitar 283 for lower charge voltage
how to read vivitar 283 meter
photography forum vivitar 283
vivitar 283 flash, voltage
vivitar 283 japan voltage
vivitar 283 low voltage
vivitar 283 low voltage model
vivitar 283 low voltage modify
vivitar 283 modification
vivitar 283 voltage
vivitar 550fd voltage
vivitar 550fd-n flash
vivitar modification low volt
www.jzxxxs 2
