+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 24
  1. #1
    Join Date
    Jun 2006
    San Francisco
    Posts
    110
    My Gallery
    (0)
    Liked
    0 times
    Looking for a fast, versatile lens for Nikon D50 (something like 18-100+mm)
    Hi All,
    I'm looking for a fast, versatile lens. I do mostly club/concert/low-light photography. I also do photography for artistic/creative purposes at times but the club stuff is where most people see my work.
    I just got a D50 a few months ago with the 18-55 kit lens and a 70-300 telephoto. I find the 18-55 doesn't always give the zoom range I need and switching back and forth is not practical in a club. I need a 'do it all lens'.
    Here's what I'm thinking:
    - 18-100+mm
    - Good in low light (i.e. fast lens even at the 55mm range)
    - Something that's not too big, i.e. easily transportable in a small camera bag.
    - Something that's noticably better than the kit lens.
    - The cheaper the better
    Thanks!
    --Illah
  2. # ADS
  3. #2
    Join Date
    Oct 2005
    Posts
    314
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    Fast and cheap are mutually exclusive. And that huge zoom range isn't going to help. Small is another issue. There is the 18-200mm, not real cheap, but not hugely expensive either. It isn't fast, but it does have VR which will buy you a couple of stops, more depending on technique. Just be aware that by getting such a big range you will give up image quality, there are compromises that have to be made to make an 11x zoom that is small and light.
    What's your budget, that may narrow down the choices. The 50mm f/1.8 is fast, small, cheap and sharp, but too short if the 18-55 doesn't cut it. There are 85mm and 105mm primes that are fast, more expensive, but no zoom.
    This was absolutley no help, was it....
  4. #3
    JIP
    JIP is offline
    TPF Junkie!
    Join Date
    Aug 2006
    Pittsburgh PA
    Posts
    3,019
    My Gallery
    (0)
    Liked
    1 times
    I'm curious, why exactly is switching lenses "not practical" in a club. I hear this so much how hard it is to switch lenses and I really want to know why it is so hard.
    "It is horrifying that we have to fight our own government to save the environment."
    Ansel Adams
    Nikon D700
    Nikon D-70s
    MB D-10 Grip
    14-24 2.8G ED
    18-70 kit lens
    85mm 1.8
    70-200 2.8 VR ED
    Nikon SB800 Speedlite
  5. #4
    TPF Junkie!
    Join Date
    Apr 2006
    Fairfax, VA
    Posts
    1,179
    My Gallery
    (0)
    Liked
    0 times
    Quote Originally Posted by JIP
    Well, i can tell you that i was scared to switch lenses while in the Grand Canyon for fear of silt, sand or dust in mass quantities...
    The 18-200 should serve your purposes. Fast, high zoom ratio, and cheap do not go together, though..
    -Danny
    SKAforLIFE
    Working with|Nikon D50|28-80 AF Nikkor|70-300 AF Nikkor|Tokina 10-17 AF DX Fisheye Zoom|Tokina 12-24
  6. #5
    JIP
    JIP is offline
    TPF Junkie!
    Join Date
    Aug 2006
    Pittsburgh PA
    Posts
    3,019
    My Gallery
    (0)
    Liked
    1 times
    Quote Originally Posted by midget patrol
    then why don't you keep your camera in a hermetically sealed box where you can jus look at it then you will never get dust in it. You know, there is a reason you can clean the lenses and sensor of your camera.
    Ansel Adams
    Nikon D700
    Nikon D-70s
    MB D-10 Grip
    14-24 2.8G ED
    18-70 kit lens
    85mm 1.8
    70-200 2.8 VR ED
  7. #6
    Join Date
    Dec 2005
    honolulu, hawaii
    Posts
    813
    My Gallery
    (0)
    Liked
    2 times
    anything with that much of a range is not going to give you the proformance you want. it wil have a sweet spot between 70 and 100, and the rest will be soft at best
    flickr
    gear:
    kodak funsaver disposable
    kodak funsaver disposable w/ flash
  8. #7
    Join Date
    Sep 2006
    currenty in Hyderabad, India
    Posts
    476
    My Gallery
    (0)
    Liked
    0 times
    I think 50mm f/1.8 is a good combination with D50. As it is cheap, fast and compact (to fit into small camera bag as you required). Once you go for a larger zoom range you have to sacrifice both compactness and your budget also.
  9. #8
    fmw
    fmw is offline
    TPF Junkie!
    Join Date
    Sep 2006
    Posts
    1,851
    My Gallery
    (0)
    Liked
    0 times
    Let me give you more to think about. The wider the zoom range on lens, the greater the compromises in the design. Lenses with wide zoom ranges have less contrast, more softness in the corners and smaller maximum apertures. One of the sharpest fast zooms I own is the 80-200 f2.8 ED. The range is only 2.5X. That's one reason that it performs so well.
    While the wide range zooms have a lot of appeal in terms of flexibility, the compromises in all other aspects of performance are on the negative side.
    A way to help the situation would be to use a lens designed for a 35mm camera. The smaller image size of the DSLR will use the central sweet spot of the lens and obviate these problems except for the smaller maximum aperture.
    I've gone to using three zooms with my Nikon DSLR. I use the 12-24 f4, the 17-55 f2.8 and the aforementioned 80-200 f2.8. These three lenses handle almost every photographic need for the camera and all perform quite well. They are all in the 2-3X zoom range area. It isn't a coincidence.
  10. #9
    JIP
    JIP is offline
    TPF Junkie!
    Join Date
    Aug 2006
    Pittsburgh PA
    Posts
    3,019
    My Gallery
    (0)
    Liked
    1 times
    Quote Originally Posted by fmw
    Thank you I think the 18-200 has been discussed about a hundred times already
    Ansel Adams
    Nikon D700
    Nikon D-70s
    MB D-10 Grip
    14-24 2.8G ED
    18-70 kit lens
    85mm 1.8
    70-200 2.8 VR ED
  11. #10
    JIP
    JIP is offline
    TPF Junkie!
    Join Date
    Aug 2006
    Pittsburgh PA
    Posts
    3,019
    My Gallery
    (0)
    Liked
    1 times
    Quote Originally Posted by Illah
    Hi All,
    I
    - 18-100+mm
    Thanks!
    --Illah
    keep dreaming!!!!
    Ansel Adams
    Nikon D700
    Nikon D-70s
    MB D-10 Grip
    14-24 2.8G ED
    18-70 kit lens
    85mm 1.8
    70-200 2.8 VR ED
  12. #11
    TPF Junkie!
    Join Date
    May 2006
    it varies.
    Posts
    2,109
    My Gallery
    (0)
    Liked
    1 times
    for real, if i were you i would suggest a WIDE FAST LENS, if the light is that low, then a short lens will also allow for more subject/camera movement without as much noticable motion in the image. (think about people on stage moving a bunch). i own an 85mm f/1.8 and love it. also, the 50mm is cheaper and just as fast.
    if you want to work in low light like this why don't you just buy a few speedlights? if you aren't up for dropping big bucks on fast glass. then buy lights.
    JIP IS CORRECT, KEEP DREAMING
  13. #12
    TPF Junkie!
    Join Date
    Apr 2006
    Fairfax, VA
    Posts
    1,179
    My Gallery
    (0)
    Liked
    0 times
    Because I was rafting the grand canyon for two weeks with a very limited amount of physical storage (i.e. drybag). You don't seem to understand how fine the silt is: it is still in my clothes and it's still on my camera, over six weeks later. Cleaning anything is hopeless while in the canyon. I stopped using a lens-cap because all it did was hold silt and sand between it and the lens.
    Not to mention the fact that we were on the Colorado River which was flowing at over 15,000 cubic feet per second.
    I'm also a high school student on a very limited budget and can't afford to wreck anything camera-wise.
    FMW didnt' say anything about the 18-200. In one post, he's been more helpful and less confrontational in this thread. The next time you spend two weeks in the Grand Canyon, come talk to me about sand and water management before you jump to conclusions, OK?
    -Danny
    SKAforLIFE
  14. #13
    JIP
    JIP is offline
    TPF Junkie!
    Join Date
    Aug 2006
    Pittsburgh PA
    Posts
    3,019
    My Gallery
    (0)
    Liked
    1 times
    I don't think he said anything about rafting the Colorado river either just that changing lenses at a concert is not practical.
    Ansel Adams
    Nikon D700
    Nikon D-70s
    MB D-10 Grip
    14-24 2.8G ED
    18-70 kit lens
    85mm 1.8
    70-200 2.8 VR ED
  15. #14
    fmw
    fmw is offline
    TPF Junkie!
    Join Date
    Sep 2006
    Posts
    1,851
    My Gallery
    (0)
    Liked
    0 times
    Not by me. I have never even seen one, let alone tested one. I was providing some generic information related to lens design that the OP should consider. It was not lens specific but was accurate. After you have completed about 1/2 century of photography, you may use any attitude you like with me. In the meantime comment on what I say, not on what you think I say. It reflects poorly on you, not on me.
  16. #15
    TPF Junkie!
    Join Date
    Apr 2006
    Fairfax, VA
    Posts
    1,179
    My Gallery
    (0)
    Liked
    0 times
    The grand canyon comments were in response to that.
    Regardless, fast, cheap and high zoom ratio will not come together, generally. Unless you're looking for professional results, the 18-200 and the 28-300 will yield good results.
    -Danny
    SKAforLIFE
Sponsors
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Need Recc of a Fast Low Light Lens- Nikon
    By myvinyl333 in forum Photography Beginners' Forum
    Last Post: 02-23-2010, 03:08 PM
  2. New Lens - versatile?
    By lamar328 in forum Photography Equipment & Products
    Last Post: 02-09-2010, 01:40 AM
  3. Looking to get a versatile lens for my d3000...help!
    By chris182 in forum Photography Beginners' Forum
    Last Post: 01-09-2010, 07:27 PM
  4. Versatile lens
    By Corey123 in forum Photography Equipment & Products
    Last Post: 01-03-2009, 05:31 AM
  5. Looking for advice on versatile zoom lens for Nikon
    By billybob in forum Photography Equipment & Products
    Last Post: 06-06-2008, 11:41 PM
fast 18-100 zoom
fast lenses for d50
good versatile d50 nikon lens
nikon 18-200 grand canyon
nikon d50 sweet spot
nikon d50 versatile setup
versatile lens nikon
