Results 1 to 12 of 12
  1. #1
    Join Date
    Nov 2006
    Turners Hill, West Sussex, UK.
    Posts
    463
    My Gallery
    (0)
    Liked
    1 times
    Off camera flash bracket.
    Hi Guys! Advice time again...
    I want a flash bracket to use with a Canon EOS and a 580 EX. The Canon bracket looks worse than useless (Although I may be wrong about that). I have seen a Manfrotto 233B and heard tell of a wimberly F1. Although I know little about it.
    Any suggestions?. Comments. or whatever.....?
    Don't let the memories fade.
    http://www.photodex.com/share/timholyoake
    F8, and be there.
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,059
    My Gallery
    (111)
    My Photos Are NOT OK to Edit
    Liked
    1206 times
    Yes, the Canon one is all but useless.
    The leader in this field is probably Stroboframe, they make many different models and all the parts and accessories that you could want.
    You should decide whether you want one that just holds the flash up and off the camera...or if you want one that keeps the flash above the camera when in both landscape and portrait orientation.
    If you want one that keeps the flash above the camera at all times, then there are two main types. There is the flip type, where the camera & bracket are rotated and then the arm with the flash flips over to be above the camera. The other type is camera-rotate. Just as it sounds, with this type, the flash stays still and the camera just rotates on a little lever.
    Remember that you will also need the Canon Off-Shoe Cord II, which will connect the camera to the flash. These cords are not cheap and are known to fail, so if it's an important shoot, you may want to have two or three.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  4. #3
    Join Date
    Nov 2006
    Posts
    463
    My Gallery
    (0)
    Liked
    1 times
    Thanks Mike. I already have the"Cord II" Although I didn't know that at THAT price they were prone to failiure. Will have a look at "Stroboframe" Thanks again...
    Tim.
    F8, and be there.
  5. #4
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,059
    My Gallery
    (111)
    Liked
    1206 times
    I'm not exactly sure, but I think it's the shoe or foot part that is structurally the weakest. I've heard that this little product can help...
    Bogen / Manfrotto 3298 Nikon Flash Adapter - SC-17 - Foot with 1/4" Screw
    This flash adapter converts a 1/4"-20 flash accessory into a shoe mount, and allows off-camera shoe cords like the Nikon SC-17, SC-28 & SC-29 to be mounted upon brackets that only feature a 1/4"-20 screw. It is also popular for use as a 'sacrificial' shoe mount to put under an off-camera cord which already has a shoe underneath, so that wear & tear occurs upon this piece as opposed to the more fragile and expensive cord itself.
    Hugh Macleod
  6. #5
    Join Date
    Nov 2006
    Posts
    463
    My Gallery
    (0)
    Liked
    1 times
    Thanks again Mike.
    F8, and be there.
  7. #6
    Join Date
    Nov 2006
    Posts
    463
    My Gallery
    (0)
    Liked
    1 times
    Hi Mike. The Stroboframe arrived this morning, It is Excellent. exactly what I wanted. Far better than the Canon and 1/4 the price...Many thanks for the advice.
    Tim
    F8, and be there.
  8. #7
    Join Date
    Dec 2006
    Toroto, ON
    Posts
    569
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    i'm also interested in getting a flash bracket for indoor parties shooting.....do you mind sharing the model you got?.....which type is better?
    Please be brutally honest with my pictures...so that i can learn and improve
    Learning to use my equipment
    Nikon D80
    Nikon SB600
    Nikkor 18-200mm f/3.5-5.6 VRII (still my favourite)
    Nikkor 50mm f/1.8D (coming from oversea)
    Tamron 17-50mm f2.8 (Latest Addition)
    Kingmax SD 4GB 150x (need another 4GB?)
  9. #8
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,059
    My Gallery
    (111)
    Liked
    1206 times
    It's not really a matter of which model is better....it's which will work the best for you. An Instructor of mine recommended the 'Press-T' or 'Pro-T' because the bracket is offset so that you can hold the camera just as you would if it didn't have a bracket.
    Hugh Macleod
  10. #9
    Join Date
    Nov 2006
    Posts
    463
    My Gallery
    (0)
    Liked
    1 times
    http://www.tiffen.com/Stroboframe_quickflip_page.htm
    The one I settled on is the Quickflip 350. Light , strong, Landscape and portrait format. Holds an EOS.. Works for me...
    F8, and be there.
  11. #10
    Now 100% DC - not as cool as I once was, but still a stud!
    Join Date
    Aug 2003
    Lawrence, KS
    Posts
    7,021
    My Gallery
    (0)
    Liked
    11 times
    I use a folding Newton DI100FRs bracket with my Canon DSLRs, and I love it. Small, adjustable, and folds up really small.
    Here's the Newton bracket website, although they can be purchased through B & H.
    http://www.newtoncamerabrackets.com/
    "There's no particular class of photograph that I think is any better than any other class. I'm always and forever looking for the image that has spirit! I don't give a damn how it got made." -Minor White
    http://www.henrypeach.com
    http://www.mattneedham.com
  12. #11
    Join Date
    Mar 2007
    Posts
    184
    My Gallery
    (0)
    Liked
    0 times
    I use a Quantum bracket...
    ...with my canon 550's, works great, sturdy, light weight, detachable easily. About $130 from B&H.
  13. #12
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,059
    My Gallery
    (111)
    Liked
    1206 times
    I ordered a Stroboframe Press T bracket, should be here soon, I'll let you know how it works.
    Hugh Macleod
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Need help with a flash shoe extender/ or flash bracket
    By Provo in forum Photography Equipment & Products
    Last Post: 11-27-2009, 08:00 PM
  2. flash & flash bracket questions
    By wet in forum Photography Beginners' Forum
    Last Post: 09-09-2009, 11:06 AM
  3. Which flash / bracket to buy for my D80?
    By Jon_Are in forum Photography Beginners' Forum
    Last Post: 11-13-2008, 11:47 AM
  4. Flash bracket?
    By DeepSpring in forum Photography Beginners' Forum
    Last Post: 12-09-2006, 01:35 PM
  5. Flash & Bracket
    By Lally0724 in forum The Professional Gallery
    Last Post: 10-24-2005, 02:48 PM
flash bracket useless
how can i mount a nikon sc-28 with manfrotto 233b?
off camera flash bracket
why nikon above camera flash bracket
