Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2007
    Ontario, Canada
    Posts
    351
    My Gallery
    (0)
    My Photos Are OK to Edit
    Liked
    0 times
    New Lens Purchase
    Evening all:
    I am considering buying the EF 17-40 F4L or the EF 70-200 F4L non IS. Does anyone out there own either of these lenses and can you tell me what the quality is like for both.
    I believe the 17-40L is weathersealed and the 70-200 is not.
    I plan on re-stalking my entire kit with new L glass and another body over the next few months and I am just wondering where to start as I am picking up my first new glass tomorrow. I know that Usually a decision on which lens to go with would be dependant on what the photographer prefers shooting however I enjoy shooting just about everthing equally.
    So basically if anyone can give me an opinion on the two above lenses and add any other favorites within the 1000 dollar range that would be great.
    "Things cannot disappear; they can only change" J.W. VON GOETHE
    "As Kingfishers catch fire, Dragonflies draw flame" GERARD MANLEY HOPKINS
    "Is all that we see or seem, but a dream within a dream" EDGAR ALLAN POE
    Canon EOS 40D / 350D+Grip / 70-200mm F4L / 17-40 F4L / 100-400 F4.5-5.6L
    http://www.haliburtonforest.com/index.html
  2. # ADS
    Ads
    Google Advertisement
    Join Date
    Always
    Advertising world
    Posts
    Many
  3. #2
    Join Date
    Sep 2007
    Dallas, Texas
    Posts
    199
    My Gallery
    (0)
    Liked
    0 times
    i would go for the wide angle. but thats only because i would use it more. it depends on what type of photography you like...
    CANON 20D
    CANON 50mm f/1.8
    CANON 100mm Macro f/2.8
    CANON 70-200 EF f/4
    TAMRON 28-300 f/3.5-5.6 Macro
  4. #3
    TPF Junkie!
    Join Date
    Nov 2003
    North New Jersey, United States of America
    Posts
    9,200
    My Gallery
    (0)
    Liked
    262 times
    well... it all depends...
    do you want telephoto? or wide angle?
    Both are good
    <exits stage left>
  5. #4
    Join Date
    Apr 2007
    Utah
    Posts
    532
    My Gallery
    (0)
    My Photos Are NOT OK to Edit
    Liked
    0 times
    I have the 70-200 4L and it is a great piece of glass. Very sharp even wide open and it is also very easy to pack around. The build is typical L quality and AF is quick and silent as expected. If I would have had the money I probably would have gotten the 2.8L version but it is double what the 4L cost me. If you will be shooting in low light then you will want the 2.8L version which you can pick up for about $1000. If you don't need the extra stop, get the 4L and save yourself the money.
  6. #5
    I am Big, I am Mike Site Moderator
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    Liked
    1202 times
    Those are two of the best lenses that Canon offer...nothing to worry about. However, if you shoot in low light (weddings) or sports etc, then I'd consider looking at F2.8 lenses rather than F4 lenses.
    There's no correlation between creativity and equipment ownership. None. Zilch. Nada. Actually, as the artist gets more into his thing, and as he gets more successful, his number of tools tends to go down. He knows what works for him. Expending mental energy on stuff wastes time.
    Hugh Macleod
    Edmonton Wedding Photographer ==>Blog
    Instructor at The Canadian Photography Learning Centre.
  7. #6
    Join Date
    Jul 2007
    Ontario, Canada
    Posts
    351
    My Gallery
    (0)
    Liked
    0 times
    Thank you
    Thank you for the info fellas. About 1 hr ago I just purchased a brand new
    EF 70-200 F4L with a Hoya S-HMC multi coated UV filter and a Hoya S-HMC multi coated Circular Polarizer both 67mm.
    Over the next couple of months I will be looking at some faster "L" glass as I do want to get into some wedding work so I will look at the 2.8 series, thanks for the advice Mike. A new body is also in the future to be my primary either the 40D or 5D although I am not sure of the advantages of having a full frame body.
    Thanks all.
    Paul.
  8. #7
    TPF Supporter
    Join Date
    Dec 2003
    Edmonton
    Posts
    32,045
    My Gallery
    (111)
    Liked
    1202 times
    The first advantage is low noise. The 5D produces almost no noise up to ISO 400 and barely any at ISO 800 (or so they say).
    Secondly, you don't need to use EF-S lenses to get a wide angle. 24mm on a full frame camera is pretty wide...but on a 40D, you would need 15mm to get the same wide FOV.
    There are advantages to using a 'crop factor' camera like the 40D...cost being a big one. Also, the narrower FOV makes lenses feel longer, which is good for telephoto. The 5D isn't necessarily very fast but the 20D & 30D are very fast...and the 40D is blazingly fast. (6.5 fps).
    Hugh Macleod
  9. #8
    Join Date
    Jul 2007
    Ontario, Canada
    Posts
    351
    My Gallery
    (0)
    Liked
    0 times
    Excellent info Mike, thanks a bunch:
    Sounds like the 40D then as I also like wildlife work so the 1.6X cropped body will give me more reach and I am likeing the 6.5 fps just in case I shoot some of my son playing soccer.
    Cheers.
Ads
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Similar Threads
  1. Next Lens Purchase?
    By dustin0479 in forum Photography Beginners' Forum
    Last Post: 10-22-2010, 02:01 AM
  2. Suggestions for Next Lens Purchase?
    By Bugs81 in forum Photography Beginners' Forum
    Last Post: 01-11-2010, 09:55 AM
  3. advice on which lens to purchase
    By nuno in forum Photography Equipment & Products
    Last Post: 07-12-2008, 10:39 PM
  4. First Lens purchase
    By JimmyO in forum Photography Beginners' Forum
    Last Post: 02-23-2008, 02:04 PM
  5. Purchase Questions....D40x +2 lens vs. D80 + 1 lens
    By Craddosk in forum Photography Beginners' Forum
    Last Post: 02-20-2008, 10:51 AM
