0.45X nikon lens
Discussion in 'Photography Beginners' Forum' started by JackGC, Mar 2, 2009.
  1. JackGC
    JackGC TPF Noob!
    Mar 1, 2009
    32
    Southend
    I would like to buy a 0.45X wide angle lens, just a filter because i have not got enough money for full on lens.
    i use a D60 with a 18 - 55mm lens, does this mean i should buy a 55mm 0.45X wide angle lens for it to fit?
  2. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    You need the 52mm filter size.
  3. JackGC
    JackGC TPF Noob!
    Mar 1, 2009
    32
    Southend
    oh thanks pal, may i ask why, just for future references :)
  4. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    You screw the filter onto the end of the lens (you can see the threads on the inside of lip at the open end of the lens). That opening is 52mm in diameter.
  5. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    55mm is the length of your lens... 52mm is width (filter size).
    The filter size and the focal length have nothing to do with each other.
    As for the wide angle adapter, they're basically worthless; if you think a .45x adapter will make your 55mm a 20mm... think again--they don't cacluate it like that; it will more likely turn it into a rather poor quality 40mm.
  6. JackGC
    JackGC TPF Noob!
    Mar 1, 2009
    32
    Southend
    ah - i see, thanks, ill look into something else.
  7. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    also your 18mm is pretty wide already. Your moving into fisheye territory at less than 18mm.
  8. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    18mm isn't wide enough for you?
  9. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    He/she would not to get quite a bit lower to get the effects of a fish-eye. Even a 12MM on a Nikon isn't there (nor is that lens designed to be, which is another consideration to take into effect).
  10. JackGC
    JackGC TPF Noob!
    Mar 1, 2009
    32
    Southend
    i just want to be able to make the curved effect on my photo's, can some one just please tell me a nicely priced adapter that can do that?
    i dont really want the black circle thing that a fish eye gives, or is that my last resort?
    PLEASE can some one just tell me what adapter i should look for :)
  11. puyjapin
    puyjapin TPF Noob!
    Nov 5, 2008
    759
    Warwickshire UK
    im no expert but u could probably do something in post processing. 18mm is ok on the nikon but id admit a decent wide angle would be good. Im surprised u have not noted the diameter of ur kit lens, dont you have a protective uv filter for it?
  12. ANDS!
    Nov 14, 2006
    2,178
    Downtown
    That black circle, is your camera lens. The field of view on a fish is so WIDE that it picks up even the corners of your lens. For some people its a cool effect - for others not so much. This adapter is not going to do wonders for you, but if you want to cheaply play with a wide angle, then sure - grab any of the cheapo adapters you can find on eBay.
