$1000 for a lighting kit, what would you choose?
Discussion in 'Photography Equipment & Products' started by gl600, Jan 31, 2010.
  1. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
    Middle East and Canada
    Hey,
    I'm looking to get a flash lighting kit to be used both for weddings and studio work.
    I currently own an SB-900, SB-600, and 2 Vivitar 285HV flashes. 3 Umbrella's (2 shoot through, 1 reflector) and a softbox. These are doing a great job for my general purpose lighting but they will not give me the recycle times nor the battery life (they also might lack the power) that I will require.
    The question is what kit would you buy with $1000.
    Your input is appreciated, thanks.
  2. Mike_E
    Jan 26, 2007
    5,327
    266
  3. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
    a little too expensive for what seems like not enough...
  4. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    If you want something for weddings and other uses...then I agree with Mike E. Stick with Nikon units (maybe SB-800s) so that you can easily use them on-camera as well as off-camera.
    They can be used in studio situations and should have enough power. If you want to improve battery life & recycle times, then Quantum Turbo that Mike mentioned, is a good option.
    Or are you looking for actual studio monolights?
    If so, I'd suggest looking at Alienbee, Elinchrom, Calumet etc.
  5. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
    After you put it that way I am wondering... what would be the benefit of getting monolights over nikon units?
  6. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    Well, if you are going to shoot in a studio type situation, monolights can be better to work with. They are typically more powerful (if you need it) they usually have modeling lights, they will likely recycle faster and they run directly off of AC power (no batteries to charge).
  7. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
  8. gl600
    gl600 TPF Noob!
    Sep 3, 2009
    156
    Thanks for the help :)
