danalec99
- Joined
- Mar 14, 2004
- Messages
- 8,345
- Reaction score
- 69
- Can others edit my Photos
- Photos NOT OK to edit
Wow. I hope you like it. I love mine.danalec99 said:And I've ordered the EF50 f1.4. Waiting for the online order to arrive.
I haven't used one, but I've heard mixed reports. It's a polycarb body, so a cheaper lens. I'm thinking of getting one myself, though. I don't need a telephoto often enough to justify the cost of a more expensive lens, but I would like to have one at times. I spent the money on the 50/1.4 (instead of the 50/1.8 ), since I knew I would be using that a lot.What do you think of EF 75-300mm?
Not traditional ones, where you see a wide vista. For that you would need a wide-angle lens. The Canon 22-55mm has the crop of a 35-88mm on the 10D. I picked one up a while ago when I wanted to experiment with really wide shots on my EOS5. It's perfect for the 10D, as 35mm tends to be a perfered focal length. It's also a cheap polycarb lens, but again, I don't do a lot of landscapes, so I didn't feel like spending the money on something of a higher quality.Could I do landscape with it or the 50/1.4?
danalec99 said:
How do you mean normal? It's not normal in the way the term is usually used. "Normal" means the camera sees the scene the way your eye would, with no distance compression (like a telephoto) or stretching (like a wide angle).danalec99 said:The reason why I asked re. ef75-300 is because I would like to have a 'normal' lens that would take normal pics. Is that a good call?
