120 film question
Discussion in 'Photography Beginners' Forum' started by ceemac, Jan 1, 2018.
  1. ceemac
    ceemac TPF Noob!
    Oct 8, 2017
    75
    35
    Cariboo, B.C.
    This may be a dumb question. What happens at the end of the roll. I`ve never shot 120. With 35mm, you just wind it back into the canister.
  2. Ysarex
    Ysarex Been spending a lot of time on here!
    Nov 27, 2011
    5,416
    2,396
    St. Louis
    120 film has a paper backing behind the entire length of the film. When you reach the end you just keep winding until all the paper is transferred to the take-up spool. A piece of tape will be waiting there for you already attached to the paper. Lick the exposed end of the tape and tape the paper down nice and tight to prevent light leaking and put the film in your camera bag.
    Joe
    • Informative Informative x 1
  3. john.margetts
    john.margetts No longer a newbie, moving up!
    Dec 3, 2015
    875
    193
    Lincoln
    Unless it is Fuji film in which case the paper tape is self-adhesive.
  4. ceemac
    ceemac TPF Noob!
    Oct 8, 2017
    75
    35
    Cariboo, B.C.
    Thanks, Joe, John. I was hoping it would be something like that. Guess I`ve lived a sheltered life.
  5. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    22,648
    8,117
    Iowa
    You also need to keep the spool from the roll you just shot as it will be the take-up spool for the next roll you load.
    • Like Like x 2
  6. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    16,221
    4,072
    Iowa
    The thing about paper is, you can write on it. Write down the date, the ISO (ASA?) the general subject matter, your name and contact information.
  7. Rick50
    Rick50 Been spending a lot of time on here!
    Jan 7, 2013
    3,135
    1,060
    San Diego, CA
    And when your done processing the film you can make an airplane out of the paper and impress the neighbor kids. Win-Win.
    • Funny Funny x 1
  8. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    14,061
    7,472
    Michigan
    You have to pay attention to the sticky tape to. I try to fix mine prior to pulling it out of the camera to keep it tight. If it unwinds or looses a little tension, it will expose and flare the edges. It seems to me that Fujifilm Acros is more prone to this. TriX, not so much. That has been my experience anyway.
  9. 480sparky
    Mar 8, 2011
    22,648
    8,117
    Iowa
    [​IMG]
    Problem solved.
  10. jcdeboever
    Sep 5, 2015
    14,061
    7,472
    Michigan
    Not really, I had a roll pop on me taking it out of camera, I knew it was going to be an issue. Sure enough, spent time cropping and cloning, lesson learned.
  11. 480sparky
    Mar 8, 2011
    22,648
    8,117
    Iowa
    Then you didn't have a chance to use the sticky paper either by that point. But don't condemn it just for that reason.
  12. jcdeboever
    Sep 5, 2015
    14,061
    7,472
    Michigan
    Yes sir, I'll never do that again.
    • Funny Funny x 1
