120mm & 35mm Resolution
Discussion in 'Film Discussion and Q & A' started by mrsifuentes, Apr 22, 2009.
  1. mrsifuentes
    mrsifuentes TPF Noob!
    Apr 10, 2009
    29
    San Antonio
    Seriously getting back into photography. Considering buying a Pentax 6&7 SLR/Rolleiflex for my 120 camera and Nikon/Pextax for my 35mm. Does 120mm film contain more resolution info than 35mm? Is there a huge difference when it comes to printing? What kind of scanner would I need for 120 film?
  2. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    120 will have less noticable grain, this works well for printing over 35mm. The grain is the same size so to speak but the larger format makes it seem smaller by scale. As for rezolution differences I dunno, I've yet to get my 120 cameras out and shoot them, Never been able to compare for my self. with 120 processing is at a premium though, many places process little more than 35mm, but you can find places to get the 120 done. and for scanning options, also don't know, I've been using a dedicated 35mm scanner for the past year or so.
  3. mrsifuentes
    Apr 10, 2009
    29
    San Antonio
    Thank you for the info Battou. The question came to mind after watching The Dark Knight which was shot on 70mm which holds more information than 35mm.
    Did some quick research. I believe this scanner does medium format Epson Perfection V500 Photo Flatbed Scanner with 35mm & Medium Format Film Holders | Freestyle Photographic Supplies
  4. blash
    blash TPF Noob!
    Nov 19, 2008
    599
    Point about 120 film is that it's the analogue equivalent of having more megapixels than 35mm film. This means either that, if you were to print 35mm and 120 at the same size, that the 120 print would have less noticeable grain (i.e. noise) because the image is being squashed to a smaller percentage of its relative size than the 35mm is (as Battou said) or that you can simply make larger prints without the grain getting too bad.
    Personally I print at 8x10 so I don't need Medium Format really (except maybe for ISO 400 but who cares). Since the film stock is the same between sizes and the only difference between 120 and 35mm is the size of the frame, so long as you have the proper-sized equipment (i.e. a spindle that can take 120 film), it's not going to cost you anything extra to process 120 film on your own (although some people will disagree, saying that the cost per negative goes up because you can't load as many 120 frames in at once as you could 35mm, but again, meh). For printing just scan - the V500 does have a good reputation, you should be good with that.
  5. Steph
    Steph No longer a newbie, moving up!
    Oct 18, 2006
    1,314
    Steventon, Oxfordshire, UK
    There is no doubt that 120 film will record more data than 35mm as the negative is larger. But there is more to it: image quality. If you make two 8x10 prints from a 35mm and a 6x7 negative you may not see a difference in perceived sharpness but the prints will look different. The transition between tones will be much smoother with the larger neg. It is hard to explain; you have to see prints side by side to appreciate that larger negatives are not just about more resolution.
    Another thing to consider is what you want to shoot. You did not say in your original post. MF is not suited to all types of photography. Sport is an example.
  6. Jeff Canes
    Jeff Canes No longer a newbie, moving up!
    May 19, 2003
    6,192
    22
    Hollywood, FLA USA
    What will you be doing with the negatives? Want type of work flow will you be using? With 35mm film you will have more & cheaper options in all the steps of processing than with 120. Have you priced and checked availability of film scanner?
  7. ully
    ully TPF Noob!
    Feb 19, 2007
    28
    Sammamish
    Why on earth would it, its the same film.
  8. conan.
    conan. TPF Noob!
    Jun 21, 2008
    13
    haha. ully, you are a "TPF Noob!" indeed.
  9. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
  10. blash
    blash TPF Noob!
    Nov 19, 2008
    599
  11. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    Here ya go. A 35mm black and white negative has nearly 40 billion silver halide (silver salt) crystals. When a silver halide crystal is exposed to light it converts to black metallic silver which, when developed, stays in the negative as the unexposed silver halides are washed away in the fix.
    A 35mm neg is 24mm x 36mm in size. That's 46.3 million crystals per square millimeter. A medium format negative, lets just use 645 format for example would contain at 46 million crystals per square millimeter a grand total of just over 124 billion crystals.
    Now, the 6x4.5 neg has three times the halides as the 35mm neg. However, when both are enlarged to the same size, say 8x10, you are focusing your negative image in the enlarger onto the paper. By doing so the grain in a properly focused 645 neg will be a third the size as that of a properly focused 35mm neg.
    And don't even get started on large format. By the numbers a 4x5 neg would have just under 600 billion crystals. 5x7 over a trilion. 16x20 . . . I boggles the mind.
  12. mrsifuentes
    Apr 10, 2009
    29
    San Antonio
    Hey Jeff. I did find a medium format scanner for about $200.00 . For the most part I want to print 8*12, 16*24 & 24*36 . I am still researching local print shops.
35mm vs 120
35mm vs 120mm size
35mm film vs 120mm
35mm vs 120 size film pictures
120mm vs 35mm
120 vs 35mm film
120 film vs 35mm film
120 mm vs 35 mm film
difference between 120 and 35mm film
what is the difference in developement times between 35mm and 120
