Discussion in 'Off Topic Chat' started by lostprophet, Oct 19, 2008.
  1. lostprophet
    lostprophet No longer a newbie, moving up!
    Feb 10, 2006
    11,770
    109
    10 PRINT "LP is great"
    20 GOTO 10
    run
  2. monkeykoder
    monkeykoder TPF Noob!
    Nov 19, 2007
    4,143
    Sacramento CA
    while (1)
    printf("I can does be more awesomer\n");
  3. tempra
    tempra TPF Noob!
    Feb 26, 2005
    1,669
    9
    Oxford, UK
    Thats a little basic
  4. bradster76
    bradster76 TPF Noob!
    Mar 19, 2008
    481
    US
    10 = Print
    20 = GoTo
    BEGIN
    LoopIf
    IF
    10 Appears < 1,
    lp is great,
    goto 20
    Print
    IF
    20 Appears< 1,
    GOTO 10
    END LOOP
    RUN
  5. Double H
    Double H TPF Noob!
    Nov 12, 2007
    550
    24
    Around the corner from the Turkey Hill, PA
    Dos run. See dos run. Run dos, run.
  6. PlasticSpanner
    PlasticSpanner TPF Noob!
    May 1, 2005
    4,125
    51
    Cheshire, England
    LP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is greatLP is
  7. PlasticSpanner
    May 1, 2005
    4,125
    51
    Cheshire, England
    I never knew there was a 1000 character limit to a post! :er:
  8. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    it was probably brought in after the last time LP tried this ;)
  9. polymoog
    polymoog TPF Noob!
    Aug 31, 2008
    1,283
    Meercat Manor
    <HTML>
    <HEAD>
    <STYLE type="text/css">
    P.paragraph {font-style: italic; color: blue; font-family: Verdana, Arial; height: 40px; width: 430px; border-top: 3px solid #666666; border-left: 3px solid #FFFFFF; border-bottom: 3px solid #666666; border-right: 3px solid #FFFFFF;}
    </STYLE>
    </HEAD>
    <BODY BGCOLOR="#000000" COLOR="#FFFFFF">
    <CENTER>
    <H1>
    <HR WIDTH="80%">
    <P class="paragraph">HELLO LOST PROPHET</P>
    </H1>
    <HR WIDTH="80%">
    </CENTER>
    </BODY>
    </HTML>
  10. Tangerini
    Tangerini TPF Noob!
    Jan 31, 2007
    2,886
    In my house :)
    :biglaugh:
