18-55IS worth an upgrade?
Discussion in 'Digital Discussion & Q&A' started by cactus waltz, Jan 30, 2008.
  1. cactus waltz
    cactus waltz TPF Noob!
    Oct 20, 2004
    170
    Hello,
    I recently acquired a Digital Rebel XTi (great camera!) with the kit lens and the 50mm 1,8.
    I have concidered upgrading the kit lens to the newer version that has IS. Would it be worth it, or should I just hang around and save up for something that is of higher quality?
  2. SCHNOOBS
    SCHNOOBS TPF Noob!
    Dec 29, 2007
    103
    T-Town Oklahoma
    I would save up for a higher quality and larger focal range.
    -always keep f/stop in mind
  3. Big Mike
    Dec 16, 2003
    33,843
    1,817
    Edmonton
    How much does that new lens cost? It's probably a better lens but that doesn't mean it's worth it.
    Have a look at the EF-S 17-85mm IS.
  4. ashadiow
    ashadiow TPF Noob!
    Jan 16, 2008
    96
    Duluth, MN
    I think it is like $185 at Adorama or Beach... It is crazy cheap and would be good if you can sell the non-IS for 80 and it was only $100 for the upgrade.
  5. photogincollege
    photogincollege TPF Noob!
    Aug 4, 2007
    706
    Grand Rapids, Michigan.
    But you have to think, on a lens of that range, 18-55, do you really need IS? Unless you have really shaky hands its not really a huge lens, and you have the 50 mm for lower light, so id say go with mikes suggestion.
  6. cactus waltz
    Oct 20, 2004
    170
    Well, it's also supposed to be plenty sharper than the original kit lens. So all in all, if I could sell the current kit lens and upgrade it might be worth it. On the other hand, yes, that could be a 100 dollars put into something even better.
  7. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
    I have the 24-105L and I think the IS isn't needed on such a range. Better to have that piece of string under your foot and attached to your camera that someone else posted.
