1st & 2nd curtain
Discussion in 'Beyond the Basics' started by jocose, Oct 20, 2005.
  1. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    I have a question about the above title. After playing with my camera a bit, I have discovered that one overexposes the scene more than the other.
    Can someone explain:
    1) what exactly is going on with the two
    2) when to use each
    3) historically, where the terms come from (sorry--I'm a bit of a history geek).
    Thanks.
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    The below article explains a lot in detail, but here's quick guess for you:
    First curtain is the shutter opening, second is it closing, giving you a window of time (usually about 1/125th) to fire the flash. It also gives you a literal window onto the film plane, hence curtain. Sometimes you want to take a picture in dark conditions and expose a fixed background naturally and a moving subject with the flash e.g. a portrait of someone in the dark.
    http://photonotes.org/articles/eos-flash/index2.html
  3. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    aaahhhh information overload :)
    I'm reading the link you sent...good stuff, but lots and lots and lots and lots of it !!
  4. hobbes28
    hobbes28 Incredible Supporting Member
    Jul 10, 2004
    4,807
    41
    at work...
    Summary is that 1st and 2nd shutter are flash synchs. It just means that you would rather the flash fire with the opening of the shutter or the closing. Usually, it fires in the middle so the first should operate as normal where the second should make the shutter stay open a bit longer and could potentially over expose your shot.
  5. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    so what are some practical examples of when you would use which?
    (BTW, for the record, the manual that came with my camera sucks!!)
  6. hobbes28
    Jul 10, 2004
    4,807
    41
    at work...
    Most manuals do... :D
    Best reason to use syncs is for light streaks. You can take a picture of cars going down the road and have either the tail lights streak and the flash fire to show the car at the end or you can have it fire and show the car and have the lights trail through. I'll see if I can find some examples so I don't sound like your manual. :D
  7. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Most cameras are 1st curtain. Some cameras/flashes have a 2nd curtain option. 1st curtain fires the flash just after the shutter opens. 2nd curtain fires the flash just before the shutter closes.
    For very short exposures it usually doesn't matter which you use. With longer exposures it can alter how movement is captured. Imagine you are shooting at night, and you have a car coming at you. With a longer exposure and 1st curtain the car would be frozen by the flash, but the headlights would continue towards the photographer because of the longer exposure. It would look like beams shooting out of the headlights. With 2nd curtain the headlights would go towards the photographer, and then the car would be frozen by the flash. The light trails would be dragging behind the car, which is how people tend to think motion looks.
    I don't know why your camera doesn't expose them the same. Somehow it must be metering them differently. Put the camera and the flash on the same manual exposure, and they should come out the same.
  8. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    Thanks, Manual Hobbes.
    OK, that didn't sound as dirty in my head as it does when I read it on the screet :lmao:
  9. hobbes28
    Jul 10, 2004
    4,807
    41
    at work...
    Um..er...*runs away...* :lmao:
    This is an example of rear sync by Nikon.
    [​IMG]
  10. jocose
    jocose TPF Noob!
    Sep 16, 2005
    3,059
    118
    dans la pissoir
    So you both use cars as your example, and it makes sense (Matt, I'm not sure I'm actually right about the different exposures...but to me one looked lighter than the other), but what else would you use it for? I mean, the idea couldn't have been created just to shoot car head and tail lights, could it?
    I so need to buy me a tripod!
    How do you get those kinds of shots...do you still use a lower shutterspeed, or does the 2nd curtain help make the effect?
  11. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    If the shutter is staying open longer than it's set to, then the camera is malfunctioning. 1/15th of a second is 1/15th of a second whether you are using no flash, 1st curtain, or 2nd curtain flash.
    Flash bulbs sort of fire in the middle of the exposure, and in some circumstances leaf shutter cameras/lenses the flash fire more in the middle, but with focal plane shutters (in almost all 35mm SLRs and DSLRs) it's definately either at the beginning or end of the exposure. Unless you are using something like the high speed sync feature like Canon flashes have, and then the flash is operating more like a flash bulb. In my example above, firing in the middle of the exposure would result in light trails extending both before the headlights, and trailing behind.
  12. hobbes28
    Jul 10, 2004
    4,807
    41
    at work...
    Some of the advanced p&s's out there adjust shutter speed when you tell it to rear curtain sync and I think that Jocose is using the Canon S1 IS which, as far as I can remember, does the same thing. If it were an SLR, I would agree 150% with the camera being messed up. I used to have a Kodak DX6490 and it slowed my shutter down with rear curtain and I thought it was broken until I contacted them and they told me otherwise.
how to fire flash on 1st and 2nd curtain
