1st attempt @ smoke (C&C Please)
Discussion in 'Photography Beginners' Forum' started by 7/24, Feb 23, 2010.
  1. 7/24
    7/24 TPF Noob!
    Feb 9, 2010
    55
  2. Clawed
    Clawed TPF Noob!
    Apr 29, 2009
    426
    20
    Arizona
    Do you mind if I ask what your settings were? In the first image there is a bit of noise evident, and that's common for smoke pics. I would suggest starting with an ISO of 100 if possible, and make sure to expose them properly. Use a snooted flash to control the intensity and direction of the flash if you can.
  3. Jacki
    Jacki TPF Noob!
    Nov 20, 2009
    235
    Northeastern Michigan
    I kind of like #1. They are kind of noisy, but great for your first try! :thumbsup:
  4. 7/24
    7/24 TPF Noob!
    Feb 9, 2010
    55
    Clawed... The ISO was 1600. I knew there would be a fair amount of noise. I do not have strobes yet, so I'm using hot lights at the moment (a 300w for this shot). Since this was my first attempt, I now know to go bigger next time. Any other comments or suggestions? Thank you.
  5. Clawed
    Clawed TPF Noob!
    Apr 29, 2009
    426
    20
    Arizona
    Actually, not too bad for 1600 ISO. I like the first, but how did you control the flow of smoke? I would suggest using a spoon over the smoke to see what kind of interesting patterns you can get. It's all about trial and error here since smoke can be so unpredictable.
  6. Clawed
    Clawed TPF Noob!
    Apr 29, 2009
    426
    20
    Arizona
    Also, you may try adding other elements to your smoke shots to make them really stand out. For example, I took this during my first smoke shoot, after taking way too many shots that all began to look the same after a while:
    [​IMG]
    And, hey, if you are a smoker, why not try to get in the frame yourself for what could turn out to be a great self-portrait?
