1st Macro shot
Discussion in 'Nature & Wildlife' started by DRATOM, Sep 26, 2008.
  1. DRATOM
    DRATOM TPF Noob!
    Aug 25, 2006
    165
    DFW
    No flash used, first attempt. What is lacking, what is needed to improve in this field of photography?
    [​IMG]
    Thanks for looking​
  2. Overread
    May 1, 2008
    23,676
    4,025
    UK - England
    Well this is very good for a first shot = especially without any flash aid!
    I think your focus is almost sport on focused on the eyes - good
    Composition is working very well with the shot
    Colours - a little dark, but without flash and not being able to use a slow shutter speed acceptable.
    Depth of field is a little weak I think in this - a smaller aperture would help, though of course then you would certainly need to be using a flash to get that light back.
    Certianly a good first shot - I look forward to seeing more !
  3. DRATOM
    DRATOM TPF Noob!
    Aug 25, 2006
    165
    DFW
    Thanks Overread! Do I need a ring flash for this, or use an off camera flash? As far as DOF I shot this at ƒ16. Should it have been in the 30s?
    Thanks,
    JD
  4. Overread
    May 1, 2008
    23,676
    4,025
    UK - England
    that is a lot smaller than I thought you were using! f14-16 is where I usually work with flash
    the bigger bugs are a pain and a lot of the time its more creative angles than super deep depths of field that people use (I am still learning effective angles to use). If you can get all the way to the 30s then give it a try!
    Flash wise I use a 580M2 with a softbox - Doenoe also uses a similar setup. As my kit is still being put together I went for a normal falsh since it will have a good use in many areas - a ring flash though can be a very good macro light source and if you can I would go for one - there are also the positional macro head flashes (where you have 2 mini flash heads on a ring mount) though I have no experience of using these.
  5. DRATOM
    DRATOM TPF Noob!
    Aug 25, 2006
    165
    DFW
    Thanks again Overread! You have been very helpful for the next time out.
  6. dwol
    dwol TPF Noob!
    Sep 28, 2008
    358
    Queensland, Australia
    whoa, that's pretty sweet! For your first macro shot i would have to say that you are spot on. cool photo.
