1st photo post, C&C please
Discussion in 'Photography Beginners' Forum' started by Mrs.Doe, Mar 3, 2009.
  1. Mrs.Doe
    Mrs.Doe TPF Noob!
    Mar 3, 2009
    22
    Calhoun County, IL
    I don't know why I'm so darned nervous to post a photo here. I'll never learn to shoot unless I jump in. I just got my camera a couple weeks ago and I know nothing. Help me!
    [​IMG]
  2. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Shot info:
    Camera - Sony DSC-H50
    ISO - 400
    Aperture - f/4.5
    Shutter Speed - 1/8
    Focal Length - 78mm
    Interesting image. Some noise in the sky. I would have stepped to the left so that the branch didn't fall across the moon...and all the other branches would frame the moon with a rough circle.
    The moon is actually over exposed...no details. But the picture is pretty cool.
  3. Mrs.Doe
    Mrs.Doe TPF Noob!
    Mar 3, 2009
    22
    Calhoun County, IL
    Thanks. I'll have to look through my other shots (done in burst). I might have the framing you suggest. Will also try the noise reduction in Photoscape.
    Edited to add another framing of the shot:
    [​IMG]
    What settings can I change to remedy overexposure of the moon?
    Thanks for your help!
  4. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    The composition is good... I agree that it might have been better framed without the branch across the edge....
    When you shoot the moon, it helps to keep in mind that it is being lighted by the Sun. In other words, the exposure is the same as any brightly lighted subject on earth, f-16, ISO 100 and shutter 1/100. To get the branch silhouette, you could have slowed the shutter down a bit, or opened the stop up some from that. Also, the shot would bee nicely exposed at twilight if possible, rather than at night. As it is, the photo is overexposed (from the moon perspective) and has more noise than necessary..
    I think that it is a good shot worth taking again..:thumbup:
  5. KylePeterson
    KylePeterson TPF Noob!
    Dec 31, 2008
    139
    Albert Lea, MN
    I really like the idea, and the shot turned out ok. The noise is really distracting to me
  6. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    The noise is not surprising since it will necessarily be underexposed in order to make the moon expose properly. (granted, I think the moon is overexposed) So, I wouldn't worry about the noise.
    You're not going to be able to take a hand-held shot of anything under 1/30th of a second with any real stability. 1/8th is really slow. You'll want to go faster or get a tripod, or both.
  7. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
    What are you trying to capture? The branches or the moon? With that phase moon, you cannot do both unless you do two separate exposures and merge them. To capture the moon, see my lunar photography guide.
    Edited to add: An example of this that I did a few years ago is the shot below. I used a 1/200-sec exposure with a very bright flash to illuminate the trees, then I stuck in a photo of the moon that I took at around 1/100-sec through a telescope.
    [​IMG]
