2 1/2 year old D76 Developer
Discussion in 'The Darkroom' started by tasman, May 31, 2006.
  1. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    Edmonton, Alberta, Canada
    I found a mixed bottle of D76 developer the other day that is probably about 2 1/2 years old and tried a test roll of B&W Plus-X Pan 125.
    Here is one of the pictures that I took.
    [​IMG]
    I was amazed that it was still good.
  2. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Wow, that's really impressive. What kind of conditions was it in?
  3. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    It was in a brown gallon container for darkroom chemicals that was almost full, stored in closet. I think I took about 16 oz out of it when I mixed it to develope a couple of rolls.
  4. terri
    terri Administrator Staff Member Supporting Member
    Sep 2, 2003
    27,363
    2,835
    In the mental ward of this forum
    I'm curious, as well. I doubt I would have tried it!
  5. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    I thought it would'nt hurt, if it didn't work I would dispose of it and mix a new batch. I would have lost nothing.
  6. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Developer goes 'off' mainly because it reacts with oxygen. If dev is in a sealed container with very little air and it's kept cool it will often work even after a year or two. The brown bottle helps as light, particularly UV, provides energy that can promote chemical reactions.
    The giveaway to a dev's condition is the colour. If it's anything from clear to pale yellow it should be OK. If it's gone dark brown then it's off. Anything between these may or may not work. Always do a test before committing yourself.
    The problem with old stock solution is that other components react and alter. This means that whilst it will still develop a film the results are not predictable and might not match the manufacturers specs so it shouldn't be used for important or critical work.
    A lot, of course, depends upon the particular developer and the storage conditions.
  7. hammy
    hammy TPF Noob!
    Aug 6, 2005
    149
    Hertz you say test it beforehand, but how? Use film leader clippings?
  8. Hertz van Rental
    Nov 8, 2004
    16,738
    46
    Where am I now?
    Exactly so. I usually just use the leader and process in daylight. Put it in the stock solution and if you see it turning black in a reasonably short space of time (about 1 min) then it's useable.
  9. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    It's much easier to test stuff if you shoot cut film.. LOL
  10. tasman
    tasman TPF Noob!
    May 7, 2006
    468
    In B&W I shoot bulk, so it is no big loss if I waste some for a test. I am still abit amazed that it lasted that long, I am giong to try and develope a couple more rolls today.
my d76 developer has turned yelllow
test d76 developer
year old d-76
